Results 1 to 27 of 27
    Veteran Member Three Rings A4twin's Avatar
    Jun 02 2007
    2016 SQ5 2021 VW Tiguan
    Pasadena, Tx
    N75 with external wastegate
    Well i'm getting ready to do my install in a couple of weeks (GT3076). How do i hook up the n75 since i will be getting rid of my TIP. This is so far what i've come up with.
    TIA
    2016 SQ5 APR OBD11
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: N75 with external wastegate
    that would have to go in the TIP that you make.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Veteran Member Four Rings a408's Avatar
    Nov 06 2008
    Orange County, CA
    im in the same situation as we speak.
    the n75 goes to the turbo(boost) tip (have to make a fitting, and wastegate.
    i have one made for my tip, and the wategate. but im not sure what to do with the 3rd hose
    @Boden_AutoHaus
    2021 Merlin Purple RS6 Avant
    2021 Grigio Scuro F8 tributo
    2020 Aston Martin Vantage
    Nov 06 2008
    Orange County, CA
    i have a full gt2871r btw.
    @Boden_AutoHaus
    Dec 03 2005
    2 pedals 1FG
    connecticut
    N75 connections:
    1 - wastegate
    2 - boost source line
    3 - TIP or atmosphere
    -Doug
    Jun 02 2007
    Pasadena, Tx
    N75 connections:
    1 - wastegate
    1. on the pic the one that i have label "top of wastegate" is that labeled right?
    2. so the other label to "side of wastegate" is that label right?
    3. the third nipple can just be left open to atmosphere.
    TIA
    2016 SQ5 APR OBD11
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by A4twin View Post
    TIA
    No.
    The N75 gets hooked up the same way no matter what your wastegate design is.
    In your pic..
    The bottom that is labeled "now where does this go" is your boost source line from your compressor housing
    The left goes to the wastegate
    The right (longer side of the 't') goes to the TIP or atmosphere.
    I don't know what the requirements are for your wastegate. Post up the schematics for your wastegate and we can go from there.
    -Doug
    Jun 02 2007
    Pasadena, Tx
    No.
    In your pic..
    OK, still confused on where i need to connect "for my boost source" since my gt3076 doesn't have anywhere i can tell to connect to. on my k04 i see where it connects but don't see anywhere for me to connect on my gt3076 (will post a pic of the gt3076 turbo later today)
    As for my wastegate will post up a pic little later today.
    TIA, really appreciate the help...
    2016 SQ5 APR OBD11
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    For you 30-76 you will need to tap the compressor housing or you can tap the turbo outlet pipe just after the turbo. You can vent the line that reroutes into the TIP to atmospher, or you can send it to the top of the wastegate to assist in closing it.
    Jun 02 2007
    Pasadena, Tx
    Quote Originally Posted by 400HPA4 View Post
    Here is several pics of the turbo, can you point to where i can tap thanks, sorry for such annoying questions, want to get this right the first time...
    2016 SQ5 APR OBD11
    Jun 02 2007
    Pasadena, Tx
    getting the car ready for the big day...just got did the vacuum delete from absolutegtr...was actually pretty easy...anybody know where i can get a the T that comes off the back of valve cover connect to crankcase breather to valve cover and vents to atmosphere ()
    2016 SQ5 APR OBD11
    Veteran Member Three Rings A4DRIVR's Avatar
    Sep 08 2009
    2001 Golf GLS 1.8T
    Loveland, OH
    Are talking about the factory rubber Y type pipe?
    Also, is this thing running yet?
    It's SOLD!... 2001 B5A4 QMT BAT: Used to be... My BAT Build
    "When life gives you lemons, paint that shit gold!"
    Jun 02 2007
    Pasadena, Tx
    Quote Originally Posted by A4DRIVR View Post
    Yes the factor y type pipe: 034 motorsports sells them, but i just rigged it for now, until i put it my oil catch can, then i'll do it right and get the 034 motorsports replacement.
    Car has been running for almost 2 months now running strong currently set at 14lbs , it runs great just no balls under 3K. do have a CEL since i started it up the first time. Will check out the CEL once ecstuning sends me my stuff, i love how they say "will be shipped in 1-3 days" it's been now 12 days and won't be shipped out until the 18th. For some reason i can't get my vag-com to work on my car, i've spent hours on end trying to figure it out but can't get it to work.
    2016 SQ5 APR OBD11
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    replace "greddy" with "N75" -- boost source IN on right, and "outlet" on left.
    Also according to the "NO" and "NC" usual hook up manner, and my guess on the configuration of the N75... the "tip" barb needs to be plugged for this to work correctly.
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Sep 08 2009
    2001 Golf GLS 1.8T
    Loveland, OH
    Quote Originally Posted by Haenszel20v View Post
    It seems to me like this routing would allow the boost pressure (relative to the WG spring) to open the WG sooner??? It appears that Tialsport agrees with the majority of what you're saying with exception of blocking off the TIP port. Their schematic shows a vent between the top of the WG and the N75 (or whatever you're going to use) which equates to both the N75 and WG being open to atmosphere. SEE HERE
    But I'm a little confused...
    Why wouldn't you just run the routing as the factory did, but leaving the "nipple" which originally entered the TIP open to atmosphere?
    Oct 05 2008
    Buffalo, NY
    You can, but I always set mine up according to how all the NHRA SFWD guys set theirs up... which in my experience works a lot better, is a lot smoother, allows for WAY more boost to be held on a lower spring and is a lot more controllable. Granted, I'm not using an n75.... but all the n75 is is a duty cycle valve anyways.
    A normal EBC duty valve has 3 ports... in, normally open, and normally closed...... which from my "guess" is exactly how the n75 ports work also.
    Sep 08 2009
    2001 Golf GLS 1.8T
    Loveland, OH
    I can't argue with that...
    I wonder how I would determine if the TIP port should be blocked or not? I'm guessing that it shouldn't be blocked since I will be applying pressures it was never designed for to begin with...
    Here's what I'm thinking:
    UPDATE: THIS CONNECTION METHOD RESULTED IN SEVERE OVER-BOOST CONDITIONS.
    Sep 08 2009
    2001 Golf GLS 1.8T
    Loveland, OH
    After further research... looks like my diagram above is incorrect... don't use it!
    Jun 02 2007
    Pasadena, Tx
    been having issues lately with inconsistent boost currently run a n75 with a MBC. one run i'll hold 20lbs of boost until redline in 3rd gear. then another run i'll maybe get 15 lbs of boost in 3rd gear. i'm thinking my wastegate is "bleeding" will doin the above as suggested by 400HPA4 help this issue or getting stiffer springs for my wastegate help out. just not sure what to do next.
    TIA
    2016 SQ5 APR OBD11
    Sep 12 2008
    South Central PA
    Have you tried replacing your N75 valve with a friends?
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jun 02 2007
    Pasadena, Tx
    Quote Originally Posted by Dan[FN]5857 View Post
    i have not yet... also i run a manual boost controller, if that makes a different.
    2016 SQ5 APR OBD11
    Sep 12 2008
    South Central PA
    if you have the manual boost controller set at 15psi, that would pretty much solidify that your N75 is on the way out
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jun 02 2007
    Pasadena, Tx
    have MBC set at 20, one run i'll boost 20 lbs to redline then later i'll boost 15lbs to redline. then later that day it will boost 20lbs to redline.
    2016 SQ5 APR OBD11
    Sep 12 2008
    South Central PA
    hmmm... what software? what DV?
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jun 02 2007
    Pasadena, Tx
    Eurodyne 630cc mafless file. Stock DV
    2016 SQ5 APR OBD11
    Sep 12 2008
    South Central PA
    I bet your DV is dying.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jun 02 2007
    Pasadena, Tx
    Will try that. I have an extra one laying around somewhere.
    2016 SQ5 APR OBD11
