Results 1 to 30 of 30
    Veteran Member Three Rings soundspeedstyle's Avatar
    Oct 01 2009
    Silver 2000 Audi S4 Vast stage 3
    Centralia, Washington
    Attempted to tint tail lights... Help?
    So I plan on Getting Black LED tail lights later but for now I thought I would tint my stock ones.
    The tint I bought is for headlights/tail lights. It says it is to be applied dry. Well I just tried it four times and each time there were 5-7 bubbles....
    Any one have any ideas on how to avoid this?!?!
    I used a "squeegee" and a blowdryer.. no success.
    It looks really good besides the bubbles and would really appreciate some advice so I can get this job done!
    2001 A4 1.8t Quattro stage 2 - sold
    2000 s4 stage 3 - sold
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Re: Attempted to tint tail lights... Help?
    you can try to clean them first. there may be some small amounts of dirt still on them causing your bubling.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Apr 22 2007
    Riverbank, Ca
    Start by applying it wet to the headlight, use a heat gun to get the tint to shape properly as well as a squeege. Let it dry in the sun to retain its shape. Peal it off and clean everything properly. Use a little water and some soap and squeegie it on. Start from the center and work your way out.
    Good luck! Might want to just spray them.. (tinting spray.. not paint)
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Oct 01 2009
    Originally I was going to do it like i tint everything else... A good cleaning... 2 sprays of windex then squeege out the windex. and use a blow dryer on it for 5 mins. Then let it sit for an hour and bam works perfect... Stupid a$$ instructions told me to apply it dry.
    Well I ordered some more. If it turns out bubbly again ima say Fl_lCK it and get some spray. The tint is so perfect though lol I really want it to work. This time I am doing it my way god damnit lol
    I was just wondering if anyone else knew a way.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    VHT Nite Shades is what everyone around my area uses. Its a spray tint, and you can pick up at most parts stores.
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    I used window tint to do mine previously. I took em off ..
    Here is how i did mine.. Start by removing the light assembly from the car, cut the tint to length. Before peeling the protective film from the glued side, use the heat gun and mold the tint to the shape of the light.
    Next use baby shampoo diluted well. Spray the tail light generously apply the tint and use the squeege to apply the tint on, working from the center out. Use the heat gun to mold it to fit.
    If you have bubbles what I did was use a small sewing needle and poped them very carefully and let the air/solution drain out. Then heat gunned it to seal it up
    Stand back and enjoy ( and post pix!)
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    Oct 01 2009
    Quote Originally Posted by discontained View Post
    I will try again when the shipment gets in. I did Center out but my dad said start at the edge... I knew that was wrong lol. I after I give it a go with windex and paint my trunk rings black I will post pix
    why did you remove it?
    Jul 09 2007
    '01 A4 1.8t
    GA
    to much black in the back. I used to have tinted windows (10%) and tinted lights on a black car. Didnt like the look after a week, so i pulled my tint off the car .. windows and all, the red adds a nice contrast
    Oct 01 2009
    I wish I would have bought a black a4 I would smoke tails headlights, black out everything... black rotors, calipers, wheels EVERYTHING lol. I love that look
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Maybe just tint the white part.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Your cars silver just do some tasteful black mods. black wheels, roof, tint and rings if you must it will look really good. taillights are overkill in my opinion unless they are lightly smoked.
    Oct 01 2009
    this is my goal
    CF hood, Black roof, CF trunk, Tinted Tails, Black Wheels, Black Calipers, Black rotors
    Jul 07 2009
    Socal/IE
    Thumbs up Re: Attempted to tint tail lights... Help?
    Too much in my opinion, But its your car and your money do what makes you happy.
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    Quote Originally Posted by soundspeedstyle View Post
    this is my goal
    I like how that sounds. Has anyone painted the little part under the taillight black too? Or wrap it in cf? I mean, obviously only if you have a cf/black trunk... Oooorrrrr, paint the bottom of the trunk silver on a cf trunk (under the little ridge where the bottom of the taillight is)? Wondering if anyone has done it and has pics Could look absolutely brutal, would just like to see it...
    -Jeff
    Oct 01 2009
    one thing I have been realllllly tempted to try is...
    CF;
    Hood, front bumper, Fenders, all doors.
    Paint the middle of the cf hood silver, leave the roof, trunk and rear quarter panels silver. But i want to photoshop it first before i spend $2,000 on doors lol
    Veteran Member Four Rings ThatA4T's Avatar
    Jun 10 2009
    98 A4 1.8T Quattro, 66 vw bug Rat Rod
    Denver CO
    i wanna tint just the reverse light portion of my tail lights... anyone done this?
    If I hit the switch, I can make that ass drop.
    Oct 01 2009
    I would use spray... Tape off the rest. I dont think that tint would turn out verywell in that case.
    I wanted to do that in my civic but didn't get around to it before it was stolen.
    Jun 10 2009
    Denver CO
    haha im glad your civic got stolen
    Oct 01 2009
    ass lol... I JUST got rid of the turbo kit for that thing 2 weeks ago and I still am finding parts for it... OH and I have NSX seats in my room now because I have no honda to put them in!!!!!!!!
    Can't sell the seats to save my life, Part of the reason why I am considering buying another lol
    Jun 10 2009
    Denver CO
    haha sorry i just hate hondas.... nothing against them its just personal opinion... they run forever and they are great cars but just look at it haha id much rather get into my $5k audi than a honda any day.
    Oct 01 2009
    5k.. i hate u lol 7.7k stock
    Jun 10 2009
    Denver CO
    5k stock 119k miles... but i got a 98... and then another 2-2500 when i wrecked it... and that was right after i got the hood and bumpers painted
    Oct 01 2009
    alright that makes me feel a tiny bit better lol
    Jun 10 2009
    Denver CO
    haha so i basically paid 7500 for a 98 with a blue hood and bumper haha but it was worth re building it for sure
    Jul 14 2009
    phoenix md
    dont use windex, the alcohol in it causes it not to stick as well.. use baby shampoo and water (told that is the best) but dish soap works very well too..
    Oct 01 2009
    Quote Originally Posted by cdowns13 View Post
    thanks for the input didnt realize that! appreciate it!
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    this is my goal
    black rotors, eh?
    what happened to this forum....
    and yea, dont use windex on your tinted windows, it will cause them to bubble. so using windex immediately before applying the tint to the taillights is definantly not going to be beneficial.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Oct 01 2009
    adams rotors :)
    Established Member Two Rings A4 Jarrid's Avatar
    Oct 25 2009
    RI
    There is a lot of judging going on in this forum lol dish soap and water for the win
    Established Member Two Rings DS1LLAR1's Avatar
    Oct 21 2009
    2000 Audi A4 1.8TQM, 1995 Dodge Viper rt/10
    boston, MA
    some pictures are gone but here is the idea on how to do them, i did it came out like it was professionally done, the wet dry sanding is the most important part that makes them like a mirror. http://forums.vwvortex.com/zerothread?id=2181389
