Results 1 to 13 of 13
    Established Member Two Rings SpiderBy's Avatar
    Mar 20 2009
    2008 BMW 535i Manual
    where to buy 17mm hex bit and 12pt triple square bit?
    Hi guys,
    Realized my CV outer joint boot is torn and leaking.
    I am sure I noticed that just in time and all I need is to replace the boot, not the joint or the axle.
    Got the CV boot kit today from germanautoparts (the brand is Rein aka CRV)
    Read two great write-up in the AW tech zone and eager to start.
    Needed 17mm allen hex and 12pt triple square bits so tried today one Autozone, one Pepboys, one Advance Auto Parts and finally Sears and no luck to find these VW/Audi species.
    Tried to search online and not so many choices for these tools at reasonable cost with shipping either .
    I just found this - could anyone confirm it would work?
    Any pointers to the right B&M or online stores with quick shipping would be greatly appreciated!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: where to buy 17mm hex bit and 12pt triple square bit?
    www.germanautoparts.com they are great and I highly recommend them.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    May 09 2009
    Syracuse, NY
    Quote Originally Posted by SpiderBy View Post
    Hi guys,
    Yes that bit is what you need. Those are a bitch too get out though. I got my 17mm hex at Harbor Freight. They've got a set of hex sockets for real cheap.
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Autozone does carry the 12pt tool, it comes in a 4 pack, that's where I got mine from. 12 bucks.
    Established Member Two Rings Fukenfast's Avatar
    Sep 22 2009
    2001 Audi A4 1.8t FWD
    Tucson, AZ
    Home Depot or Lowe's both carry these
    Veteran Member Four Rings danphines's Avatar
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    sears
    Unitronic stage 2, 3 inch turboback, Stasis SS coils...
    Dec 05 2007
    Autozone carries the 17mm allen bit. It is the same thing as a 17mm hex bit.
    Mar 20 2009
    well, checked Harbor Freight, they have 17mm hex bit in a 9-piece set only
    Thanks, guys, I got some options, I will try some other Autozone and Sears stores in my area (not quite sure Home Depot or Lowe's would help).
    In the worst case i will just make another order to germanautoparts - they have both things here and I guess it would cost me around 30 bucks shipped.
    Jun 19 2008
    Coquitlam, BC
    Any Automotive jobber " should" be able to order these. Problem is when you get a chain store that hires minimum wage people and they don't have a clue as to what they are doing.
    Napa should handle KC Tools. They are one of the largest makers of Automotive specialty tools in NA. Then there is OTC Tools, Gray Tools, Westwood Tools etc etc.
    My local independent store has a full selection of high quality sockets, wrenches, allen sockets, etc etc...in both Metric and SAE.
    Quite frankly....I've never shopped at an Automotive jobber that didn't have a huge selection of these tools on hand.
    A 17mm Hex socket and 12 point Triple Squares ( Rimac's ) are not rare items.
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    sears.
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Jun 19 2008
    Coquitlam, BC
    One other tip... When you go to a Napa, Autozone or a local independant store, always look for the cranky old farts. They are usually the ones with a wealth of knowledge in there heads and can answer the difficult questions.
    Once you find a good Partsman...hang onto him like GOLD!! They are every bit as valuable as a good mechanic.
    Jun 14 2005
    Anaheim, CA
    Home Depot and Lowes have always had the tools I need, try calling all the auto parts / home improvement stores in your area and you'll definitely find what you're looking for.
    Brandon @ VMR Wheels
    Mar 20 2009
    Guys, thanks all for the tips.
    I liked most the one about a good Partsman :)
    Finally, I got both things.
    8mm 12pt triple square bit I bought in NAPA for $7.5 and 17mm allen bit I found in one of Autozone in a 3-piece set (about $13 with NY tax).
    Here is the tools photo just in sake of the follow-up:
    Thanks, AZ community!
