Results 1 to 10 of 10
    Sep 14 2006
    castrol syntec 5w-30 vs 5w-40
    I know Castrol Syntec 5W-40 is on the approved list, but Castrol Syntec 5W-30 is not. Would using 5W-30 have any adverse affects?
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    Re: castrol syntec 5w-30 vs 5w-40
    No
    I just saved you 1 minute of searching.
    E85!
    "I got four cylinders when I need them and four cylinders when I don't"
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Use the castrol 0w-30 it's made in Germany and is a real synthetic unlike the other two.
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Registered User Three Rings Dan@EuropaParts's Avatar
    Sep 06 2009
    Piscataway, New Jersey
    Nothing bad would happen but I would still go with what's recommended in the manual and that is Castrol Syntec 5W40 (or any other Audi certified 5W40)
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    I used Mobil One 5w30 for the first nine years I had my B5 with no ill effects. I do use 0w40 Mobile One for the last few years now though.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Lubro 5W40 FTW..hehe
    Mar 27 2005
    The Cold North
    Quote Originally Posted by mrbacardi35 View Post
    same here. Better than m1 or the us castrol syntec
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Two Rings ecbo0m's Avatar
    Aug 07 2009
    05 S4 Avant
    Quote Originally Posted by EBG 18T View Post
    Would i be able to feel a difference switching from M1 5w-30 to LM 5w-40? It's getting cold here in NJ and I feel like my engine isn't running as smooth.
    Sep 13 2008
    Western Chicago Burbs
    Quote Originally Posted by ecbo0m View Post
    Huuuge difference. Lubro-Moly is the shit. i swiched to it from M1 0-40 and the differences were incredible. i no longer get that chattering sound when i first start the car. this is due to the oil sticking to the cams and everythin else. with castrol and m1 it all seeps down to the oil pan overnight and then when you start your car in the morning, all of that stuff is not lubricated for the first few seconds. it also feels a lot smoother at high rpm's
    lubro moly is 100% synthetic and it is made from high quality base stock. m1 and castrol are not real sunthetics. for a manufacture to claim that it is "synthetic" it only has to be 43% synthetic or something like that. might be 38%. cant remember. also, the s4 guys and hardcore german tuners sweat by lubro moly.
    it goes for about 33-40 bucks for a 5L jug of it. you can get it at napa
    Aug 07 2009
    05 S4 Avant
    Quote Originally Posted by B6JoeA4 View Post
    Exactly what i was asking. It does feel a little rough at startup, and i can't put this eloquently, but with M1 5w-30 it feels like the gears are "grinding" at high RPMs - it's just not smooth. Perhaps lubro-moly can alleviate that issue.
