Results 1 to 16 of 16
    Senior Member Three Rings mianol's Avatar
    Jan 19 2008
    windows 7 + adobe cs4
    any1 here has cs4 installed on windows 7? I upgraded to win7 and the setup file wont even launch. googled and tried everything....guess i can give it a shot here too.
    07 A3 S-Line, DSG, APR stage II+, ATP dp, NEUSPEED intake, BBS ta rep, alpine deck, 2x alpine amp, JL 10", black badgessold
    2011 DGM STi
    Registered User Three Rings Dan@EuropaParts's Avatar
    Sep 06 2009
    Piscataway, New Jersey
    Re: windows 7 + adobe cs4
    I am on Win 7 and its runs CS4 Master fine. Did you do a clean install of Win 7 or upgraded? That may have messed things up...
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    I'm on 7 and CS4. No issues so far.....
    Love Windows 7!
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Sep 06 2009
    WOW I don't think I've ever heard "Windows" and "Love" in one sentence :)
    Veteran Member Three Rings RenoAudiNV's Avatar
    Feb 10 2007
    Reno, Nevada
    Win 7 Ultimate + CS4 (clean install) no problems. I also am lovin Windows7.
    Silver 2004 S4 Avant
    --Current Setup--
    Fast Intentions Downpipes || Fast Intentions Perf Core Resonated XPipe 2.5" Catback || RNS-E || Sirius || 19" BBS CH || 235/35ZR19 Bridgestone Potenza SA050 Pole Position || Bilstein Coil Over PSS9 || Carbonio CAI || V1 Hardwired || VAGCOM || Votex Rear Spoiler || Oettinger Front Grille
    http://www.youtube.com/RenoAudiNV http://www.flickr.com/photos/davidcarrico/
    Jan 19 2008
    i did a fresh format on 7, master wont start installin.....maybe i should burn it instead of mounting?
    2011 DGM STi
    Sep 06 2009
    hmmm. what are u mounting it with? MagicISO? also, try running it as administrator.
    Jan 19 2008
    i tried daemon/magiciso/poweriso, tried runnin as admin, tried admin command prompt and then started everything in services still no go.
    2011 DGM STi
    Sep 06 2009
    you sure it's not an expired beta CS4 version? I once had that problem only to realize the installer had a time-bomb
    Jan 19 2008
    im pretty sure its not the beta version..... >.< but how to i double check?
    2011 DGM STi
    Sep 06 2009
    it maybe hard but try right clicking on the setup.exe and see if it says anywhere there. also, trying burning a physical disc.
    Jan 19 2008
    man....there goes my last dual layer lol same thing as a mounting it
    2011 DGM STi
    Senior Member Two Rings gaogi's Avatar
    May 08 2005
    2008 S4 Avant 6MT
    Irvine, CA
    Try mounting the image, then copy everything to your hard drive and run from there. I had issues with trying to install from a mounted image with Vista. Once I copied the whole directory structure onto hard drive, it ran fine.
    2024 Glacier White RS3
    B6 ('02) -> C6 ('06) -> B7 ('08) -> MK6 ('11) -> 8V ('15) -> 8Y ('24)
    Jan 19 2008
    haha thanks for all your help guys, in the end i got another iso (actually the same one again) and it worked...i guess something went corrupt with the old file >.<
    2011 DGM STi
    Jan 19 2008
    Quote Originally Posted by dellsmaith View Post
    Hi EuropaParts.com
    If you want to upgrade window 7 than you have just write keyword "Torrent: Upgrade Window 7 component" in google site. This is the query which can helps you to find complete window 7 OS. you will just get torrent file of window 7 which can works only on utorrent software. if you get more problem after doing this tell me. I will try my best to solve your problem.
    lol WHAT?
    2011 DGM STi
    Veteran Member Three Rings SDchargers's Avatar
    Jul 01 2007
    2006 E320 CDi, 2002 S4, 1992 Galant VR-4
    San Diego, Cali
    ^ It looks like another bot. There seems to be an increase in fake accounts here lately.
    -emmel "за себя, за себя!"
