Results 1 to 12 of 12
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Recommended Strobe Accessories?
    I picked up and wireless flash last summer and have barely been putting it to use... Maybe a dozen shoots with it in more than a year. Mostly because i dont much about using it, but partially i think because it isnt much good without methods of reflecting the light and such.
    What do you all use? I dont shoot in a studio, obviously considering i hardly use my wireless. So I've been thinking flash mounted bouncers and mini softbox type setups. What might be some good options? Also snoots?
    Recommend some kind of trigger other than the setup it uses already? Its and Olympus fl-36r. I know she wont fire unless its in the line of the on body flash, which can be an inconvenience...
    Thanks for the help!!!
    Jul 06 2007
    Bremerton, WA
    Re: Recommended Strobe Accessories?
    you guys got nothing? i know i've seen a bunch of externally lit shots from you guys up, what are you using?
    Senior Member Three Rings MartyinCO's Avatar
    Sep 21 2008
    Ducati Monster 900
    Thornton Colorado
    Top secret....
    It's so much easier to suggest solutions when you don't know too much about the problem.
    Malcolm Forbes
    Jul 06 2007
    Bremerton, WA
    nothing?
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    I just picked this little kit up today... However, it's a continuous output setup.
    http://www.adorama.com/LTSP7.html
    I've never had or tried a lighting setup like that before, but I have a few people that are paying me to take some shots for them so I figured this should help me out with lighting. I also have a Nikon SB-600 flash that has worked pretty well for me, but like you, I haven't used it all that much.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Oct 13 2009
    o
    what's your budget..?
    I use elinchrom studio flash but, it is relatively expensive. I try to use it all the time because I love lighting.
    I can give you some recommendations if you give me a ballpark idea of what you want to spend.
    You can use reflectors to bounce light back but, you will need a studio stand. If you want to use an umbrella there is a bracket which hold the umbrella and the flash the flash that you already have. My understanding is that your flash is not 100% wireless.
    Just read the B&H catalog on your FL-36R that it is 100% wireless. You need to look in the camera menu to set it up.
    http://www.bhphotovideo.com/c/produc...tra_Small.html
    http://www.bhphotovideo.com/c/search...tialSearch=yes
    http://www.bhphotovideo.com/c/produc...uto_Flash.html
    Sep 21 2008
    Ducati Monster 900
    Thornton Colorado
    My wireless consists of http://www.pocketwizard.com/
    But it really depends on your budget...
    Malcolm Forbes
    Jul 06 2007
    Bremerton, WA
    The first link you posted richard is right around my budget. its tough to have a budget when you dont know what youre shopping for. definitely dont have too much more than that. but yes the flash is totally wireless, it just has to be in sight of the pop up flash to fire.
    Oct 13 2009
    o
    http://www.bhphotovideo.com/c/produc...ight_Set_.html
    Westcott Apollo Speedlight Set
    ok, I think you will be better off with the Westcott Apollo Speedlight Set. Reasons being, the flash "light" goes back into the softbox and then comes out so you will get a much more even light. The first one I showed you, the flash just comes straight out - not so even which means hot spots. The Westcott one does not come with a stand however but, you can check craigslist - i've seen some for about $10 - $20. Or, $40 for an 8' stand at B&H. The next thing to think about is the size of the softbox. What are you going to be shooting. The Westcott is 28" square. I like it because you can take the front baffle out for a harder light. Check out the reviews.
    http://www.bhphotovideo.com/c/produc...lla_Mount.html
    http://www.bhphotovideo.com/c/produc...ack_Stand.html
    http://www.bhphotovideo.com/c/buy/Ai...0/N/4294550961
    http://www.bhphotovideo.com/c/buy/Um...5/N/4294550875
    Oct 13 2009
    o
    Hey guys,
    Check out this place. Interfit. They're known for being a bit cheepo, but they sure are innovative.
    http://www.interfitphotographic.com/index.htm
    strobies XS bracket, portrait kit,
    Jul 06 2007
    Bremerton, WA
    ^^ they seem to have some kits that cover all the bases. too bad they dont have any retailers within like 100 miles of me. but thanks for the links, I'll definitely be expanding my kit soon and getting some fresh shots coming in.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    I use the nikon SB900 with a GaryFong diffuser on top:
    www.GaryFong.com
    Josh
