Results 1 to 40 of 57
    Oct 09 2008
    1.8T single exit exhaust
    I have been looking into exhausts now doing research on sound and built quality, all though I still have a few questions in my mind. The only single exit thread I have been able to find is for a 3.slow from two months ago.
    I have gotten a good quote on a 3'' turbo back mandrel bent single exit exhaust with magnaflow muffler. Now I kind of like the single exit idea (yes I know there will be a whole in the bumper, that will be taken care of)
    Lets talk about the pros and cons. I have heard that the velocity effects more then the back pressure, is this true? I understand that we need back pressure for the turbo to spool. Wouldn't a Single exit have more pressure along with a less disturbed flow of exhaust gasses? Also Would be saving weight. And a bit of uniqueness factor that other B6's dont have single
    Let me here your thoughts. I know im missing something.
    /flamesuit on.
    The Awesome™
    Apr 21 2009
    Santa Clara, CA
    Re: 1.8T single exit exhaust
    Less back pressure = more room for the turbo to spool. I was under the impression little to no back pressure is better for the turbo.
    Oct 09 2008
    Then wouldnt it be the best to just leave the back of the turbo open?
    The Awesome™
    Apr 21 2009
    Santa Clara, CA
    Yep.
    Oct 09 2008
    *taken from another thread
    Quote Originally Posted by SportSter View Post
    I put a dump in my exhaust not to far backfrom the DP...... Sounded a lot more beefy and LOUD, but in the end it hurt my performance. (no back pressure and the turbo only spooled a little)
    You need mufflers if not for noise control then to keep a little back pressure, and by little, i mean little.
    Whats the difference? Im not saying your wrong, just trying to get a better understanding by challenging.
    The Awesome™
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I run an open testpipe and the top-end pull is much better. The turbo also spools much quicker.
    2019 SQ5 Prestige
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Check audigeeks for "jeff"
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Here's a picture of my old car, doesn't answer any of your questions but oh well haha. If you have any questions on what I paid, the setup, or anything lmk.
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    ^^^what size piping and how much did that run you?
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    4 stroke motors see NO benefit from any amount of backpressure. Flow velocity and scavenging ARE useful to all 4 stroke engines and these are often confused with backpressure by people unfamiliar with the subject.
    FWIW: a long while ago, there was a thread on vortex that displayed all sorts of info on the subject; cliffnotes: a single 90* bend creates the minuscule amount of backpressure the turbo likes.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Senior Member Four Rings Jake39454's Avatar
    Mar 04 2009
    Horsepower injected Audis
    Richmond RI
    A larger downpipe/exhaust will spool the turbo QUICKER and it will produce MORE top end power...
    Oct 09 2008
    Thanks old guy, Ill hit him up. I like that look.
    UnknownA4 YGPM
    Thanks forcefeddub. So would a single exit provide better velocity? Im talking a full 3" set up. Or should I go bigger?
    Thanks DW garage. Is it at the expense of low end power though?
    The Awesome™
    Mar 04 2009
    Richmond RI
    Quote Originally Posted by JoshDub View Post
    No, you gain power everywhere...
    Aug 10 2008
    Denver, Colorado
    if you are sure you're never going BT, 2.5" is fine (even on some smaller BTs) if you are planning on going to a GT2871R or larger, go with 3". anything larger than that won't be helpful or necessary unless you are going for HUGE power.
    -Cam
    Oct 09 2008
    Quote Originally Posted by DW Garage View Post
    Okay thats good. I have seen alot of posts where people talk about loosing torque and what not.
    Force_fed_dub, I *may* go BT in the future, but not anytime soon. So going with 3'' now wont hurt anything, even if I eventually dont go BT?
    The Awesome™
    Oct 06 2005
    Soccer mom car
    South
    Quote Originally Posted by mrbacardi35 View Post
    3 inch I think (don't really remember it was a few years/cars ago.) Here's a video of it for those interested. Nothing but a magnaflow muffler(which could be taken off, no cats, resonators, ect.) and an open dump for the external wastegate.
    http://s16.photobucket.com/albums/b1...rent=Mycar.flv
    Aug 10 2008
    Denver, Colorado
    correct, 3" will not hurt performance on the stock turbo the reason to consider 2.5" if you're not going BT is that they are usually not as "boomy" and a tad cheaper. people have made 500+hp on 2.5" exhaust (but would probably make more with a 3")
    -Cam
    Senior Member Two Rings anderskt's Avatar
    Dec 14 2006
    03 a4 quattro
    i was considering this for my car based on weight savings alone...there is absolutely no need for dual exhaust on 1.8's
    dubaudi grüppe
    Oct 09 2008
    So it really seems as if there is no downside to going with a single exit?
    The Awesome™
    Oct 06 2005
    Soccer mom car
    South
    None at all
    Oct 09 2008
    Word, looks like im going single exit!
    The gas tank is more on the passanger side of a quattro correct? So I should put the single exit on the drivers side to kinda balance it out?
    The Awesome™
    Jun 29 2007
    Raleigh, NC
    I put mine on the drivers side so that it looks like every othe single side Audi.... B5's B8's etc. I have 3" catless from the turbo to a single magnaflow muffler with dual tips. My exhaust consists entirely of one pipe - vband at the turbo and two hangers. I'll put up some pics later if you want
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 27 2008
    Denver
    That's sweet^ I like that picture of that denim with single exit as well.
    Oct 09 2008
    Post the pics man! I would love to see it.
    The Awesome™
    Senior Member Three Rings poop_on_jdm's Avatar
    Apr 22 2009
    Newport News, VA
    can you buy a rear valence with one exhaust opening? it looks weird leaving one side open. Unless you had big money for super big ass turbo for a rear mount which is sick
    Jan 06 2009
    The only cons of 3" vs 2.5" is ground clearance and slight increase in noise.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jun 29 2007
    Raleigh, NC
    the euro TDI bumper has one cutout.
    see Jeff Lee's car above.
    or google TDI B6 A4
    The Awesome™
    Dec 03 2005
    2 pedals 1FG
    connecticut
    If I ever redid my exhaust I would do a single exit on the driver side like Jeff and Daniel and custom mold my S4 rear bumper. It will also cut down on the drone in the cabin of my Avant. Until then, dynomat the entire trunk...
    -Doug
    Apr 01 2007
    houston texas
    Quote Originally Posted by poop_on_jdm View Post
    We will keep the turbos under the hood, thanks
    2019 SQ5 Prestige
    Apr 01 2007
    houston texas
    I have always wanted to do a single side exit exhaust, but i doubt there is enough room. I would put the exit right behind the passenger side front tire.
    2019 SQ5 Prestige
    Jun 29 2007
    Raleigh, NC
    my 3" is quieter than my 2.5" was. idk why the hell people keep saying it's louder....
    anyways. here's pictures.
    The Awesome™
    Dec 03 2005
    2 pedals 1FG
    connecticut
    aluminized piping or stainless steel?
    -Doug
    Jun 29 2007
    Raleigh, NC
    aluminized. my whole exhaust (muffler and labor included) cost me like 250 or 300
    no rust to speak of cept the welds are discolored... but what do you expect?
    I suppose I could put some "rust converter" on them and then hit em with a high-heat paint... but im really not that concerned.
    that being said - my downpipe is stainless. shawn made that, and it's currently sleeved onto and welded to the rest of the exhaust lol
    The Awesome™
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    is that really like a 7' straight pipe?
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Jun 29 2007
    Raleigh, NC
    Quote Originally Posted by Haenszel20v View Post
    basically. can't think of anything simpler or less restrictive short of an open dump. (too loud, even for me...)
    do you see a problem with it? I'm a pretty big fan... 2 bolts and a hanger and the whole thing drops loose. (bolt on the muffler hanger, the hanger in the middle, and a bolt at the v-band on the turbo)
    The Awesome™
    Jan 06 2009
    Quote Originally Posted by B6Lovin View Post
    That looks perfect.
    I have made a few exhausts before (not for b6) and used a similar approach. It is definetly easier on a lift, I have always done it lying on my back.
    No issue using aluminized, it is cheaper and lighter than SS. Easier to weld and more forgiving on your cutting tools (SS is very hard). By the time it takes for aluminized piping to rust out you will have changed setups or sold the car.
    B7 2.0t
    Jun 29 2007
    Raleigh, NC
    Quote Originally Posted by adam_a4 View Post
    That looks perfect.
    danke
    The Awesome™
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    Oh for fucks sake, back pressure and air velocity are two different things... :tard:
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    vvIs that just an s4 bumper with the right hole patched??
    -Andrew
    Frankenturbo/GIAC
    Oct 09 2008
    I think I might be going with SS, I cant remember which he said for sure though. I plan on just patching the left hole and painting the lowers.
    The Awesome™
