Page 1 of 10 123 ... LastLast
Results 1 to 40 of 384
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    adam's rotors: the famous. the legendary. the world renowned...the best!
    BUILD YOUR CUSTOM ORDER | MACHINE PATTERN, ZINC FINISH, HUB COATING, METALLURGY, & BRAKE PAD/STAINLESS STEEL LINE/FLUID PKGS.
    WWW.ADAMSROTORS.COM
    adam's rotors inc. started out small and remains that way...a tight knit, self-owned & operated company established & going strong since 2006.
    the small outfit and one-on-one interaction creates only the best service w/quick response & even faster made-to-order set-ups. with top notch products, this lends hand to our success thus far.
    working 24/7 throughout the day, any and all questions are answered within the hour to the best of our ability, if not instantly.
    being an online company we do business direct via email, instant message, PM, and over the web in our ever growing threads...we're always here ready to reply!
    we are a fully made-to-order, replacement disc brake, rotor manufacturer...we offer only factory fit, OE spec, plug n' play discs.
    WE CATER TO THE CAR ENTHUSIAST WHO NOT ONLY NEEDS NEW BRAKE ROTORS, BUT WANTS SOMETHING DIFFERENT BEHIND A NICE SET OF WHEELS.
    be it looks or performance, adam's rotors is the only company to bring you over 20+ machine pattern variations (most of which are exclusive to AR), 3 zinc finish offerings, and 5 ceramic-silica hub coating options.
    YOU PICK, WHAT YOU WANT AT AN ALL-INCLUSIVE PRICE | COMPLIMENTARY CORROSION PREVENTION, FREE SHIPPING, CHOICE OF DRILLING, SLOTTING, AND/OR DIMPLING, ALL LOADED INTO OUR WEBSTORE.
    adam's rotors expertise is in the VW/audi market, but do set-ups for ANY make/models car/truck/van…check to our store!
    WHY ADAM’S ROTORS? WE’RE DIFFERENT!
    because we do what no one else does. AR is a customizable product, having managed to turn a boring replacement product into something different. it's a have-it-your-way, made-to-order modification item ideal for any enthusiast. now, instead of just picking 1 of 1-3 drilled or slotted rotor styles from off-the-shelf inventory, we offer over 20+ patterns for your choice/taste, how YOU want them. after that pick a zinc for corrosion prevention...silver? gold? maybe black? thereafter you can even add one of our coated hub colors in a satin ceramic finish to finalize your set and truly give them polished, unique look. we now even offer upgraded metallurgy, to a stronger premium grade high carbon iron if you so wish. we at AR believe a rotor ISN'T just a plain ol' service part...rather a fun, custom, cool way to not only enhance the look of your car, but add performance, protection, and something different to your build, with a ton of bang for your buck!
    oh yeh...and they actually perform!!!
    track tested, endurance race team approved; check it out HERE.
    QUALITY, IT'S ALL IN THE DETAILS...
    we chamfer each drill hole and pay extreme attention to how we lay down our machining…taking meticulous measures to avoid each and every vent rib; the internal cooling veins in most modern vented brake rotors. AR will not drill a rotor we are unable to do so with and thus unlike most, never have issues. this is another reason why unlike many, we also offer dimples and unique slot patterns, ways of avoiding this and offering better, longer lasting, quality products when we see possible issues with venting. lastly each set is made for YOU without the limitations of pattern & finish pre-made, “in stock”, off-the-shelf parts have. instead, we start each order upon payment & cater to your needs/wants for your car.
    HOW IT WORKS:these are customized by you & made per order; you'll have them in about 2-3 weeks...
    (this takes in account ordering raw material, ship time to the shop, pattern machining, zinc finishing, hub coating & curing, packaging, & shipment pick-up!)
    we hold NO inventory & are held to the same final sale terms as our policy.
    we make ONLY factory fit replacement rotors to OE spec. plug n' play original fitment.
    whatever one-off size you may be after other than what your car came with, will need to be based off another application's rotor that already exists.
    in some cases, we can open up hub bore and modify bolt-patterns (within reason) but we need to discuss via email, first.
    YOU TELL US HOW YOU WANT THEM!
    1. dimpled
    2. drilled
    3. slotted
    4. dimpled/slotted
    5. drilled/slotted
    6. dimple/dimple/slot
    7. drill/drill/slot
    8. AR race (exclusive double slot)
    9. AR street (exclusive double slot/drill)
    10. AR track (exclusive double slot/dimple)
    11. AR sport I (exclusive over-dimple)
    12. AR sport II (exclusive over-slot)
    13. AR speed (exclusive multi-slot)
    14. AR dift I (exclusive triple curve)
    15. AR drift II (exclusive triple curve/slot)
    16. AR drag I (exclusive cross-hatch/slot)
    17. AR drag II (exclusive cross-hatch/double slot)
    18. NEW: AR sport III (exclusive radial dimple)
    19. NEW: AR sport III (exclusive radial slot)
    20. NEW: AR hex (exclusive honeycomb w/radial slot inner face)
    silver zinc, for brilliant rust-free finish is STANDARD on all orders, is a corrosion prevention process/measure, BUT...
    *COLORED ZINC FINISH:
    gold zinc or black zinc finishes are a subtle, unique, aesthetic touch for your rotors, very few offer!
    also...
    *HUBS COATINGS:
    this gives the rotor a nice clean, tailored, finished look.
    the rotor is still standard silver zinc dipped, with a high temp, satin, ceramic-silica finish.
    available in 5 colors…we can do some custom colors, so let us know what you need/want.
    or
    *G4000 HIGH CARBON IRON METTALURGY UPGRADE:
    we have started to offer a premium grade cast iron option, available for most all applications.
    standard grade G3000 is great and more than sufficient for most any use, but in some scenario's, a stronger iron is beneficial.
    reports of longer lasting rotors have been found, ideal for high mileage cars, haulers, or even heavy track goers who really beat up their brakes.
    it also greatly reduces the worry of pad squeal in cases of high friction with high performance brake pads.
    the harder iron is stronger and fights warping and cracking concerns, and higher carbon & chromium levels aid in oxidation resistance.
    another great benefit to the G4000 upgrade, is the price includes a premium black coating on the rotor at no charge.
    WWW.ADAMSROTORS.COM
    ONE (1) YEAR exchange warranty for:
    manufacture defects (cracking) per rotor...on all orders!!!
    EVERY ORDERS IS FINAL-SALE, ONCE PROCESSED | NO EXCEPTIONS.
    again, we hold NO inventory & are held to the same final sale terms as our policy.
    if there is EVER any issue with fitment/error on OUR end, we will ALWAYS make it right!
    AR EXCLUSIVES-
    *NEW: AR sport III & IIII [radial dimple & radial slot] & AR hex [honeycomb w/radial slot inner face]:
    [must be ordered with coated hubs]
    AR drift I [triple curve] &
    AR drift II [triple curve/slot]:
    AR drag I [cross-hatch/slot] &
    AR drag II [cross-hatch/double slot]:
    coated hubs]
    AR sport I [over-dimple] &
    AR sport II [over-slot]:
    coated hubs]
    AR race [double slot] &
    AR street [double slot/drill]:
    coated hubs]
    AR speed [multi-slot] & AR track [double slot/dimple]:
    coated hubs]
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Sep 20 2009
    1998 323is
    Re: adam's rotors: the famous. the legendary. the world renowned...the best!
    bump for a real quality set of rotors and a good guy!
    May 21 2009
    San Jose, CA
    I got these rotors on my car... I gotta say, EVERYTHING about this transaction from start to finish was crystal clear and the way it should be done. I love my rotors, the look and feel GREAT!!!
    Y'all need to forget about any other option you had and get with this dude Adam...
    my local homies...thank you and glad you enjoy em!
    Veteran Member Three Rings the4ringer's Avatar
    Oct 23 2007
    IKE, The '08 5dr Coupe
    SF East Bay
    bump for legit guy
    2008 A3 2.0T | Ocean Blue | Open Sky | iPod | S-Line
    [||||||||||] 99.99% Complete
    "Dont turn heads... Break necks"
    ..::The IKE & Audizine Build-Up Show::..
    updated 09.30.009
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    need rotors?...adam's rotors
    Feb 02 2009
    2002 Stage 2 Turbo'd Ecotec Cavalier
    Lehighton
    looks like i will be placing my order before the 15. i was going to wait but gotta get on it now.
    Established Member Two Rings hiphoppopotamus's Avatar
    Apr 12 2008
    2008 A4 B7 Avant; 2009 MKV GTI; 2006 A4 B6
    Carlsbad, CA
    BUMP! I've had two sets of adam's rotors on my B6 A4, and they have NEVER let me down! adam is hands down the most knowledgeable, responsive, and capable salesman i have EVER dealt with in purchasing auto parts.
    REVO Stage II :: Neuspeed Catback 70mm :: 034 HFC :: Neuspeed Sport Springs :: H&R Spacers 15f/20r :: OEM+
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    def gonna do this soon! bump for awesome quality
    -Grant
    ig: g_strachan
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    BiG BUMP for Adam. He has hooked me up and many of my boys on the East coast. I rock his rotors on my R32 and so do alot of other Dubbers. Adam is great to deal with and his stuff is Quality. Bump for you bud!!! Showin some East Coast Lovin...
    email me: [email protected]
    Established Member Two Rings Idrive's Avatar
    Apr 09 2007
    2001 Santorin A4 Avant 1.8tQm
    LB, CA
    just put an order in! This is so exciting
    ^ processing now!
    Established Member Two Rings nicheracing's Avatar
    Jun 08 2008
    2004 A4 Ultrasport 6spd
    Phoenix
    Just ordered! Sweet promo too w/ the black hub upgrade, had to get front and rear!
    Shawn
    2004 A4 Ultrasport Arctic White
    2004 VW Touareg V8 Silver
    Aug 21 2008
    09 S60 R-Design, 88 Fiero GT
    Quad Cities
    E-mail sent.
    --Allen
    emails only please: [email protected]
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    emailed
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Apr 09 2007
    LB, CA
    Just got these bad boys in today. Super happy with everything, thanks a lot Adam!
    Now I just can't wait to put them on..
    proud to announce, adam's rotors transportation:
    http://www.youtube.com/watch?v=W7_ocr0od8E
    focused-fotos
    new product photos are up...have a look!
    Jun 08 2008
    Phoenix
    Sick Adam! Love the CC. Just got the rotors this week. Look awesome, waiting for pads and get my baby to stop again!
    Veteran Member Three Rings dubless's Avatar
    Apr 15 2005
    Carlsbad, CA
    email sent.
    DTM....FTW!!!!
    ^ replied a while ago
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    email sent, and hopefully an order will be placed soon!
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    back atcha
    adam's rotors on yelp!
    http://www.yelp.com/biz/adams-rotors-san-jose
    any of you customers with a set on your car now, i encourage you to please leave a review and help spread the word!
    i'd really appreciate it and hope to keep growing this audizine born business onto all makes & models in the modding world!
    Senior Member Two Rings pja0750's Avatar
    Jan 25 2007
    B5 A4 1.8T, 56 Ford Customline
    plymouth, minnesota
    do you make 332mm rotors? cause i need some new ones for my stage III set up for B5 A4 1.8TQ
    B5 A4 1.8TQ, soon to be BAT set up
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    adam, you've got a PM coming your way.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Quote Originally Posted by pja0750 View Post
    ^ to answer this question, as posted:
    these are one-piece units, built to OEM spec, top quality pieces, PER vehicle.
    ...i ONLY make to OEM standard, so i build the units to a particular vehicle, based on year, model, engine, drive, etc. from a spec book.
    my rotors are ALL built to OEM spec, YOU tell me what application you want.
    i often DO sell b5s4 set-ups for other cars/applications (larger rotors) to those who have already sourced the caliper/carrier set-up needed for a "OEM+ bbk" but is still an OEM set-up and works only on compatible applications.
    you would have to have the caliper/carrier to accept the larger rotors...same with adding a8's or tt or 3.0 rotors being modded/added to a base model b6a4...the carrier is needed.
    this is a mod...or upgrade. the only time its plug n play or direct bolt on, is an OEM based kit made for YOUR car...
    im happy to build a set up larger for you, but its your responsibility and requirement to do your own HW/sourcing for the rest of the components needed, and in the end i must be building to an OEM spec. final sale, built to order.
    as for the PM, replied...shoot me an email tho please. thanks!
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Adam, looks like I might have to try some of these famous things.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    ^ haha...you got the wrong guy bud.
    either way tho, shoot me an email about the rotors. i'll take care of you...
    you may not remember, but i'm remembertofocus back in our b6 days!
    Mar 31 2004
    CA
    Quote Originally Posted by Adam@SPP View Post
    ohhhhhhhhhh ahahahahah... thought you were someone else with the name.
    ya im going to hit you up for some though.. about to redo the brakes... gotta get this avant done.
    Account Terminated Two Rings
    Dec 09 2009
    How much would it be for a set of C32 front rotors and a6 rear rotors? They would just need to be OEM C32 to be used with the cayenne conversion.
    email me this if you could?
    need exact year/make/model/motor to quote accurately.
    [email protected] and I'll reply there when I can quote you a set-up...thanks!
    *edit: jccollins, i sent you a PM...did some guesswork/HW and got you a quote. reply in an email for me and we can knock this out!
    new numbers, better product, same great service!
    www.adamsrotors.com
    now offering set-ups for B8S4s!
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    i sent you an e-mail about an order i want to make for a B7 A4 A.S.A.P.
    cross drilled and slotted
    ^ i've got no email unless i replied and YOU didn't get it.
    try resending or peep your junk mail. i reply within minutes...
    *edit: i just sent you one to be sure. check your mail.
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    hey man any update about my rotor?
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
