Results 1 to 14 of 14
    Sep 21 2008
    Toronto, Canada
    Relay 373, 219 and 395 function
    Hi Guys,
    I am trying to track down issues with a 2002 a4 1.8t quattro 5 spd...
    due to a crack int he ecu cover, these 3 relays are all rusted out, and caused the rad fan to blow until the battery died
    Does anyone know what the below relays do?
    Ran a bunch of searches and i'm getting nowhere...
    TIA!
    Relay 373
    8D0 951 253 A
    8K0 951 253
    Relay 219
    443 951 253 AA
    Relay 395
    8Z0 951 253
    7M0 951 253 C
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: Relay 373, 219 and 395 function
    Is your ECU getting a proper ground? Take the ECU out of the box but leave the harnesses attached and set the metal ECU box on the chasis (do all of this when the radiatior fans are on).
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Sep 21 2008
    Toronto, Canada
    i did notice that the ecu had no bracket on it... just was floating inside the box....
    I'll try grounding the ecu to see if that helps...
    but the relays are badly rusted, quite sure the insides are seized...
    can anyone tell me what the relays control???
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    The relays do control the radiator fans, I know that much...which relay, I am not too sure
    -Sami-
    Sep 21 2008
    Toronto, Canada
    help please!
    does anyone know???
    Aug 14 2007
    2002 Dodge Dakoto 4.7L & a 1990 Honda Accord that won't die
    Bellevue, WA
    Quote Originally Posted by kbjy11 View Post
    help please!
    does anyone know???
    What is your email address? I can send you some info in an attachment. Attachments don't work in PM's.
    Aug 18 2008
    Brandon, FL
    PM Sent for info too.
    2011 A4 2.0t Quattro Premuim Sport
    May 29 2009
    Richmond Hill
    i have the same problem i changed all the relays and now car wont start... ANY suggestions??
    Apr 28 2012
    maidstone
    Hallo guys I have the same problem with my audi a4 2002 can any one help me with ?
    Veteran Member Three Rings Audiguy1234's Avatar
    Aug 28 2011
    North Chicago
    Did you replace all the rusted relays? 219 is like a master relay, which controls the ignition coils I believe or something like that. I tried starting my car a bunch, but ended fouling my plugs. I replaced the 219 and waited a day or so for my cylinders and plugs were dry before trying to start it again.
    May 10 2022
    Usa
    Quote Originally Posted by audinaut View Post
    [email protected]
    Jan 24 2010
    Paramus,NJ USA
    Wait you expect a email 13 years later??
    Ziddy Autowerks
    Feb 26 2019
    B5.5 4Mo Passat Wagon A/T 2.8L - sold, '05 Titan CC 5.6L A/T - sold
    VT
    Quote Originally Posted by EuroxS4 View Post
    Ha. since I think I am having issues in the same place but with my SAI Pump. In a different thread EuroxS4 mentioned that it would be under the ECU. I am pretty sure one of them controls the SAI pump.
    I too would like to know the answer if anyone actually knows. Edit: Look what I found
    https://blog.wolfautoparts.com/audi-...ist-functions/
    Feb 26 2019
    VT
    anyone have any of these lying around? there are no more "pick & pulls" around me.
    I used to have a bunch of 373 and 219 when I had my b5.5 passat, but after that was sold my girlfriend who likes to throw shit out, talked me into chucking them. and honestly I am too poor to just go out and buy them off ebay or amazon right now, especially if my car is toast and I have to figure out a way to get a new one.
    I could also use a pig tail that would connect t the SAI pump so I could test that directly and apply power to it.
