Results 1 to 17 of 17
    Active Member Two Rings piroozp's Avatar
    Jun 10 2007
    San Francisco
    Air filter leading to check engine light?
    Took my 06 3.2 to the dealership today & they're saying my Spectre air filter is the reason for my check engine light being...and they can't clear the light without installing the stock filter back on.
    Anyone hear of this before?
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Re: Air filter leading to check engine light?
    not unless it being on there is causing a vacuum leak. Take it to autozone or another parts store they can clear it
    Gcc's blacksheep
    Jun 10 2007
    San Francisco
    So audi could clear it but they won't because it's a VAG part?
    May 19 2009
    Alabama
    for safety and liability reasons they wont...
    Gcc's blacksheep
    Aug 18 2009
    A Unicorn
    Portland, OR
    If the filter is the oiled type it's possible that your MAF got filter oil on it and that caused it.
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    My CEL went on immediately after the drop in as well. I figured the non-clogged filter may have scared the ECU a bit. Who knows. I just disconnected the battery for ten minutes and then re-connected and fired the car up. No CEL, meaning no recurring problem.
    Haven't had issues. I used a AFE dry filter btw.
    Justin
    DTM S4 Sprint Blue
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Would be nice to know exactly what code was thrown.
    Mike
    Jun 10 2007
    San Francisco
    Just left the dealership. According to them, metal air filters do nothing but harm the engine & the factory "clean air" filter is best for the car. He kinda has to say that doesn't he?
    Jun 10 2007
    San Francisco
    I'm getting the codes faxed to me hopefully tomorrow
    Senior Member Three Rings Hammer's Avatar
    Mar 03 2009
    Quote Originally Posted by elwigglero View Post
    Two questions. Firstly, at what mileage did you change your filter? Secondly, any difference noticeable from the AFE Dry?
    Former Audi Cars: 2005.5 A4 2.0T Quattro 6MT, 2018 S4, 2016 A4 2.0T Quattro 8AT, 2008 A4 2.0T SE CVT
    Jun 10 2007
    San Francisco
    The codes pulled by the Audi guys were P0068, P0571 and P307A.
    "airflow in intake system too low."
    Veteran Member Three Rings ryan_sn's Avatar
    Jun 01 2008
    2016 Audi S3 Daytona Grey
    Ontario, Canada
    Hmm that's weird. I have a K&N air filter and don't have any issues at all. I'm gonna need to take it out soon and clean it though, so we'll see what happens.
    2007 Audi A4 2.0TQ Quartz Grey
    2012 A4 Quattro 2.0TQ Monsoon Grey
    Present:
    Future:
    2023 BMW M3 Competition xDrive - Toronto Red
    Sep 04 2008
    Lansdale, PA
    Quote Originally Posted by Hammer View Post
    22k or so. Some sound at higher rpm, but no performance gain. I went with the AFE because you clean it by smacking it against your hand.
    Justin
    DTM S4 Sprint Blue
    Mar 03 2009
    The easy clean feature is certainly a plus. Any difference in throttle response?
    Sep 04 2008
    Lansdale, PA
    Maybe a small amount, but nothing I could noticeably feel. It was more a mod because I knew the stockie was dirty and this was going to be last one I'd have to buy because it was easy to clean and re-use. Our intakes are pretty decent from factory and don't benefit much from drop-ins.
    Justin
    DTM S4 Sprint Blue
    Mar 03 2009
    Thank you!
    DUH! an Audi
    los angeles, CA
    how long you had the filter on??
