Results 1 to 21 of 21
    Senior Member Three Rings ElSabio182's Avatar
    Feb 26 2006
    Boston (formerly Rochester NY)
    Flex pipe - why do shops say it's so expensive?
    Hey guys, I know the flex pipe question has been asked to death...but i'm going to ask about it anyways....
    Everyone on the forums says:
    "You can get a cheap piece of flex-pipe for $50, bring it to any muffler shop, and they can just weld the thing on...$100-ish total cost"
    Every indy Euro shop I talk to says:
    "You need to take at least the Cat off the car to do a 360-degree weld on the pipe, and that's very labor-intensive. The Audi flex pipe doesn't come separate, I have to order an entire new Cat to get one. Either way, it will cost between $400-500 to do the job."
    What gives??
    TOTALED: 2001 A4 2.8L QST - RIP, April '07 (carnage pics)
    TOTALED: 2000 A4 2.8L QSM - RIP, Sept. '09 (Totaled...really??)
    TOTALED: 2001 A4 2.8L QSM - RIP, Aug. '13 AGAIN?!
    Current: 2001.5 A4 1.8T QSM - A8 front brakes / KW V2s / front-rear 034 swaybars & endlinks / JHM DTS / Valeo clutch / S4 tie-rods / S4 skirts / Sport Cloth seats
    Account Terminated Two Rings
    Oct 13 2009
    Oregon
    Re: Flex pipe - why do shops say it's so expensive?
    your shop is screwin ya...
    should honestly be like $50 for the flex section, and then like $25 to install...
    Dec 05 2007
    I don't know how the 2.8 is, but I think the shop is BSing you. They would just need the diameter of the piping, get the flex joint accordingly, remove the section of the exhaust system with the flex joint, cut old one out (accordingly with length of new flex joint), weld new one in. Done. The biggest issue may be the stock piping being some random number.
    http://vibrantperformance.com/catalo...1035_1064_1113
    Veteran Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    They are giving you the price if you went with the OEM flex pipe. You could even buy a clamp on style flex pipe and do it yourself if you have something to cut the old flex off with.
    Feb 26 2006
    Yeah...the last guy I talked to, I asked him about supplying a non-OEM flex piece. He gave me the line about still needing take the Cat off the car to weld all the way around the joint, and that's the high labor. That made sense to me, so I didn't push him on it...
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    Quote Originally Posted by ElSabio182 View Post
    they cant get the welder into the area above the pipe because of the trans tunnel
    -06 A4 2.0T
    -97 A4 1.8T
    Senior Member Two Rings This Is Epic's Avatar
    Jan 07 2008
    VA
    I need to get this done also, as I have a small exhaust leak.
    Everywhere I called said I have to bring the car in before pricing, are you calling local guys or places like Meineke?
    Senior Member Two Rings A4-Achtung's Avatar
    Oct 01 2008
    2.8 B5 A4 Quattro
    Austin, Texas - Third Coast
    You need to find a nice little Latino muffler shop that will charge you a six pack of Corona, they can make anything work LOL.
    2001.5 B5 A4 QTM - AVIC F700BT Mod'd 3.0 - GIAC-X Tune - Bailey DV36 - 3 in. TestPipe 2.5'' Back- Blacked Out Everything - 6000k DDM HID Headlights And Fogs - Slotted and Drilled Rotors - HAIL DAMAGE!!! -
    Veteran Member Three Rings Coopa's Avatar
    Apr 20 2009
    Mk4%20variant%2C%20mk2%2C%20s60r%2C%203%27%20forester.%20
    Longmont, Co.
    Quote Originally Posted by A4-Achtung View Post
    ....nooooooooooo! My baby was "latino" owned before myself. They had a "system" in it before I bought it. They sure "made it work". I soon discovered most of the wiring in the car was f^cked. Surprised it didn't have altezza tails. Anyone got a link to the clamp on style flexpipes?
    Apr 22 2007
    Riverbank, Ca
    Seriously find a cheap muffler shop looking for work. Get them to tack it in and if they'll let you undo the cat while its on the lift, YOU do the wrenchin they do the welding, you bolt it back in and call it a day... There is NO sense in going to euro shops for welding..
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Junior Member Two Rings
    Jun 21 2015
    '90 90 FWD beater, '02 A6 30.0L Avant Quattro
    Akron, Ohio
    Does anyone know:
    Are the O.E. exhaust flex pipes on a '02 A6 3.0L Quattro 1) Stainless braid both inside and outside, OR 2) Stainless braid outside & Interlock (looks like corrugated pipe) inside?
    Give the choices above, which would be the better, most durable for replacement?
    Dec 05 2007
    Why not research a better quality than OEM? Google something like "Most durable and long lasting flex joint". And...going to follow my own advice because my sh*t is leaking bad. Ha!
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    My fab guy swears by Vibrant stuff. Summit or Jegs has their flex sections for a decent price. I think the 3" one is like 50 or 60 bucks
    Sent from my LG-H815 using Tapatalk
    Senior Member Three Rings mfdk's Avatar
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    I ran into similar situation with most shops asking for $600 for both flex pipes, so then i went ahead and ordered the correct ones from eBay for $28 a piece, found a Latino shop that actually have been working on vw/audis and he charged me $80 for both sides, it took him about an hour and half and me watching them whils doing it. The only hard part if i may say was cutting the old ones out, after that everything was straightforward.
    01 a4 2.8 v6
    Jun 21 2015
    Akron, Ohio
    @ Seerlah & Believer, thank you for your input. The Vibrant (all stainless) is a stock item at my local Summit Racing store, and the construction appears to be good.
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Anybody know the diameter on a 1.8t downpipe. Mine are broke on both my cars
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Feb 26 2006
    Woah...my post from 2009 is back on the front page.
    It's like one of those Facebook Memories things.
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    If only he had waited 3 more days :(
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Bumping an old thread but I developed this exhaust leak coming from this flex part. Can any automotive store's generic flex part work here?
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Jun 30 2008
    Erie, Pennsylvania
    Looks like yours has already been replaced with an "automotive store generic" piece. I would recommend you pay for a good quality one, like Vibrant.
    Yes, it may cost twice as much. And it may take 3 days to get. But you won't have to replace it again in 2 years.
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Shameless plug
    Brand new polished stainless steel fp, $35 plus shipping pm if interested.
    [IMG][/IMG]
