Results 1 to 40 of 42
    Oct 16 2008
    South Florida - Ft Lauderdale
    DIY: EVAP Fault Code Fix
    I am trying to resolve this issue for 3 weeks now and still can't figure it out . Ran the codes a month ago and the famous P1093 was there . I spent endless hours on different forums but no luck.
    I would like to pick your brain on this one:
    Codes cleared. When cold, I drive the car for 10mn and if I have to stop, I can feel a RPM drop for a split second to about 750 RPM but no cell. If I run the OBD, code is back.
    What I already did:
    Replaced main fuel filter
    Checked Fuel Pump and replaced Cam follower (3000 miles ago but to make sure, I will pull the pump again this WE)
    Ran the pressure test as suggested on Ross Tech (to be honnest, I am not sure what I am looking for), everything seems OK.
    Checked engine bay for fuel leaks, cracked hoses - none found
    Is my last solution going to the stealer, no warranty here.
    Thank you for your time and your help
    Phil
    Possible Symptoms
    Power Loss
    Misfire(s)
    Stalling
    Possible Causes
    Fuel Pressure insufficient/exceed/fluctuating
    Fuel Pump (High Pressure System) faulty
    Fuel Pressure Regulator Valve (N276) faulty
    Possible Solutions
    Check Fuel Pressure (on FSI engines High and Low Fuel Pressure System)
    Check Fuel Pump (High Pressure System)
    Check Fuel Pressure Regulator Valve (N276)
    Check Fuel Filter and Filter in Fuel Pump Casing
    Special Notes
    When found in 2.0l TFSI:
    Check Fuel Pressure
    Check TSB/TPL 2008753, incompatibility between Fuel Pressure Regulator Valve (N276) and ECU software.
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    Re: Can't figure it out!!
    I am useless here but i will say that i have had issues similar and it ended up being this: Fuel Pump (High Pressure System) faulty
    so im not sure what you are looking at as far as that goes but just my,.02 based on my own issues.
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    Oct 16 2008
    Thank you Man for sharing your experience
    Phil
    Oct 16 2008
    Woaw......
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    From a quick search about the net, everything is pointing to the dreaded camshaft failure Usually found with other codes though?
    Pull that pump again and have a look around....
    http://www.audizine.com/forum/showthread.php?t=295208
    http://www.awe-tuning.com/media/pdf/...FP_Upgrade.pdf
    Hope others here have better news,
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Established Member Two Rings euro20th's Avatar
    Nov 27 2008
    07' A4 , 03' BMW M3, 07' STI
    lake in the hills
    could be the throttle body, possible causes front the throttle plate opening and closing a lot slower than usual! try cleaning that out
    H&R, Lorenzo, Votex, GIAC, Magnaflow...whats next??
    Oct 16 2008
    Quote Originally Posted by euro20th View Post
    Did that already, just forgot to mention it
    Phil
    Oct 16 2008
    Quote Originally Posted by RVT View Post
    Vince
    Agree Vince but my problem is only happening at iddle, when the fuel supply is minimum. Going to pull the pump again this WE but I doubt it's the root cause.
    phil
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    any fuel leaks at the fuel filter area?
    Oct 16 2008
    Quote Originally Posted by illegitimus View Post
    Nope, dry like a bone
    Phil
    Dec 07 2008
    Harrisburg, PA
    Try this did some research could be the front 02 sensor check out this post over on the VW forum. http://forums.vwvortex.com/zerothread?id=3478058
    Oct 16 2008
    Quote Originally Posted by JRMSLINEA4 View Post
    Hey Man,
    Thank you for the link + Props to you
    Interesting enough, I have a brand new O2 sensor in stock because few months ago, I had the code here below. It is for the S2 sensor (after Cat) but I guess, just in case, I will take the time to replace it this WE
    phil
    000313 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
    P0139 - 004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 2
    Time Indication: 0
    Freeze Frame:
    RPM: 1368 /min
    Load: 12.2 %
    Speed: 65.0 km/h
    Temperature: 80.0°C
    Temperature: 32.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.843 V
    Dec 07 2008
    Harrisburg, PA
    Hey Man,
    phil
    No problem, glad I can help. I know how fustrating it can be with many stored codes.
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    I hope those issues had something to be with leds or headlights or tailights or something light that, I am sure you would fix them in a few seconds!!
    Good luck man, let us know how it goes.
    A4 B9 Tango Red Sline FWD
    Veteran Member Four Rings CBRmatt600's Avatar
    Mar 15 2009
    2011 S4 / 2008 BMW X3
    Atlanta
    I am at the point with this car where I am just going to drive it hard until it literally explodes, and then have them replace everything. Since the dealer is essentially useless and can't diagnose or fix my fueling problems, I don't have many other options. And I no longer really care.
    Good luck though!
    Past: 2008 S-Line A4 6MT, Brilliant Red APR Stage II
    Present: 2011 S4 6MT,Phantom Black: GIAC Tune/APR Exhaust/Strat Intake/Stasis Touring Suspension/Alu Kreuz/E-Codes/Passport Hardwire
    Oct 16 2008
    ^^ I am not there yet.
    I will keep you posted with my findings
    Phil
    Established Member Two Rings Murre R's Avatar
    Sep 22 2008
    Sweden
    I had a similar problem a couple of months ago.. The RPM drops and jump around between 750 and 1500 when you stop for an intersection or something like that, went to the dealer several times without luck. At this point I thought it was the flap motor but I were wrong.. The problem just got worse and worse, and finally they changed the crankcase PCV valve (hope I spell it out the right way here) and the problem was solved.
    Dunno if this will help you but I'll shoot it to you anyway.
    Martin
    Phantom Black A4 Avant 2,0TQ -05 Prosport.
    Oct 16 2008
    Quote Originally Posted by Murre R View Post
    Thank you Man for the feedback.
    I am going to check into that as well since the OEM part is not that expensive
    Phil
    Sep 22 2008
    Sweden
    Cool, let us know how it works out.
    Martin
    Veteran Member Three Rings NastyNate's Avatar
    May 26 2009
    Phil, just because the intake flap motor wasn't the fix for this guy doesn't mean it's not your problem. I've got problems with mine (part on order) and it behaves like you described.
    Oct 16 2008
    Quote Originally Posted by NJTurboB7 View Post
    Thanks Man. I'll chack into that at well
    Phil
    Oct 17 2009
    Lexington, KY
    Hey all you guys with the flap motors......you do know the "stealers" as you call us have a software update for that problem. On a lot of 2.0T's is actually a campaign.
    I would call on any you have and check.
    As far as the PCV valve, there's also a problem with the oil separator valves on the top of the intake for leaking oil and causing all kinds of idle related problems. It's a recall also on most 2.0T's.
    Hell, if it helps, PM me your VIN and I'll run it for you. I don't care where you live. Just hate seeing these babies not running right!
    Hope this helps. Have a great night!
    Oct 16 2008
    ^^ possible but no luck when you are out of Warranty
    Phil
    Jan 13 2009
    Any more news after a weekend of poking about? Did you pull that pump?
    V
    Oct 16 2008
    V
    After this WE:
    1/ After Cat O2 sensor replaced. I have posted a DIY here: http://www.audizine.com/forum/showthread.php?t=322073
    2/ Pulled the pumped, everything is fine: Camshaft and follower are like new
    Drove the car (about 100 miles) no further issue at time time. Low Idle seems to be much more stable. I'll pull the codes again at the end of the week end and let you know.
    However, this code showed up (but no MIL light)
    001109 - EVAP System: Large Leak Detected
    P0455 - 001 - Upper Limit Exceeded
    Because I replaced my gas tank cap less than a month ago, I am down to this now:
    On order:
    1/ Hose from top of crankcase (a locking tab was worn) 06F 133 781 D ($60 for a stupid plastic hose )
    2/ EVAP valve: she is really noisy and only $17 - 06E 906 517 A
    Phil
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    any update with the P0455
    Oct 16 2008
    Yes and I will post some pics this WE (I am in CA at this time for business reasons)
    While hunting down any possible leak, I found a broken locking collar on the hose coming off the canshaft case. Got the part from the Dealer and the replacement unit look like a freaking spider!! I understand why it cost me $60 for the spare.
    Ain't going to be easy to replace but I will post a DIY this WE when I'm back to base
    Phil
    Oct 16 2008
    As promised, here is an update:
    While troubleshooting the famous EVAP fault code, I found a broken clip in one of the line
    Because the new part looks like a spider
    I had to remove few items: PCV, Flap, etc.. and because the N80 valve was so cheap ($17) I decided to replace it as well
    PCV
    N80
    and here is the spider
    Removal and install is pretty straight forward, just couple clamps. The only PITA is a small screw under the diverter already installed with the lines (Pic #2)
    New line in place and now clips on like a dream
    New N80 (and the new one is much less noisy. I guess the original one was worn)
    Cleared the code once again with WAGCOM and will see if this takes care of my issue. By the way, already noticed the Idle is much more stable
    Phil
    Feb 19 2007
    Louisiana
    thats sucks!! You have to pay 60 bucks for just a broken clip
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Mods need to add a DIY sticky for B7 people. Plenty of writeups here. It's awesome!
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Fuel pressure sensor? That is known to go bad. APR lost mine so I had to go buy another one. $55 dollars from the dealer.
    I'm posting this because your code was fuel-related, but the symptoms don't really point towards it all that much, so I would wait on buying it until you've exhausted other options.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Dec 07 2008
    Harrisburg, PA
    Sounds good, looks like your 02 sensor code is solved.
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    Hey Sorry to bring this post back up from the dead:) But you say when you replaced the N80 that the new one is much less noisy. Can you describe the noise the old one was making? I have an odd noise that I am trying to track down and it very well could be this.
    Jan 16 2008
    bosnia and herzegovina
    Hi Tusin,
    I just want to say that I had some issues with the n80 valve and I have replaced it.
    It was very loud, and after removing it from its place, I wanted to compare it with the new one which was very cheap so I blew in it. I could blow through the old one and I could not blow the air through the new on. I think the why this valve is loud is some kind of a diagram inside is broken.
    Anyway, I had issues when filling the gas on station, and wanting to start the car. I needed to pump the gas pedal for some time while putting it in ignition mode by key before it starts....
    Dec 27 2005
    New Orleans
    do you happen to have the part numbers..I pulled the same large leak evap codes
    Feb 19 2007
    Louisiana
    Quote Originally Posted by a4b7 View Post
    do you happen to have the part numbers..i pulled the same large leak evap codes
    06e 906 517 a
    Dec 27 2005
    New Orleans
    thanks..i should have read the thread more closely..didnt realize it was posted before the pictures..thanks anyway!
    Senior Member Two Rings pierranchis's Avatar
    Nov 18 2009
    2007 A4 FWD 6sp, 02 R6
    Pompano Beach FL
    Phil,
    Might not help as much now as it could have before you bought all the stuff but maybe this can be of some help. My moms boyfriend is a salesman at Holman Audi in Pembroke Pines and granted that your car is out of warranty, he can probably get a tech to look at your car and give you some options or even a solution, computer reading, things like that for free if your up for the 15 minute drive. I'm sure my moms bf wouldn't mind helping you get any additional parts at his price neither. Just say that you know me (Pierre), and he will try to be as much help as possible. His name is Carlos Suarez. I just stumbled upon your post and thought this could help now as much as in the future. Always good to have someone on the inside you can trust.
    Senior Member Two Rings reggaemylitis's Avatar
    Apr 19 2008
    06 A4 Avant 2.0TQM
    South Lake Tahoe, CA
    Thanks for the research and DIY on this! Just took care of this N80 valve, and my check engine light went off after about 10 miles of driving! FINALLY! I have had the trouble starting after a gas fill up and gas cap CEL for a while now. Wish I hadn't wasted money on a new gas cap before I found out this was the problem!
    Oct 01 2007
    S. Florida
    For the last couple of weeks I've been trying to determine what is causing my car to be seem a bit jerky, particularly at low RPM around 2000-2500 rpm, when just slightly accelerating or when tipping in the throttle. It felt like a misfire, and wasn't consistent, but it was there often enough to bother me. It's been there for a couple of months. I've tried a lot of things, including replacing the Diverter Valve (it needed it), new spark plugs and coils, new PCV valve. The timing belt and water pump were done about 15k miles ago. I didn't have a CEL, or any codes, but something was not right.
    Today I finally got to replacing the N80 Purge valve, the car has 100k miles so I thought why not. Well, I think that did the trick. After just a brief drive I can tell the car is running smoother. I'll give it a few days to be sure, but early indications are good so far.
    For reference, the valve in there was the original - it was date stamped 10/16/2005, and my car's build date is 11/2005. I don't know how it lasted 100k miles, but... it's gone now. Incidentally, those one-time use clamps are a nightmare! I finally had to get my Dremmel with a cutting wheel to get it off.
    FYI - I was impatient and went to the dealer to buy the part, cost $30 with tax. FCP sells it for $14, literally half the price.
