hi everyone...
im still having issues with my boost and power on my car. above all my boost guage needle shakes uncontrollablyand my boost creeps up past 25psi while it shaking (when i say shaking its more like bouncing back an forth really quickly)
previously my car had a slightly leaky valvecover gakset and a slight gushing sound under full boost (sounded like a boost leak but would come and go). Power was feeling pitiful at around 300whp. Couldnt find any physical boost leaks while doing a leak check.
Recently had my valve cover gaskets and cam seals re done. the car felt a heap better for a short while (even though my brand new N75 was causing it to boost up to 30psi so i was having to back off the throttle slightly)
after a short while the car has been making a gushing sound again but louder and with even less power. very similar to the one i had prior to the gasket change. noticed some oil leaking out of the rear of the valve cover again, (obviously wasnted sealed properly) so i can only assume its that.
However i have not heard that leaking valve covers would cause boost leak or considerable hp loss. Any ideas guys? this has been going on for over a year and it is ridiculously fustrating.
P.S also needing to install a oil catch can asap as i noticed that it is very greasy in the Y-pipe and samco hoses. And that cant help power one bit either.
