Results 1 to 35 of 35
    Veteran Member Three Rings parimal's Avatar
    Oct 20 2008
    Glendale, AZ / Danbury, CT
    B6 and B7 Headlight Wiring Diagram
    Does anyone have the diagram for the pins on the b6 AND b7 headlight connectors (10 pin Halogens)?
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: B6 and B7 Headlight Wiring Diagram
    I need that anybody has one? I just need DRL and ground (which should be obvious)
    Sep 14 2007
    Valley Stream, NY
    Bump, I want to tap into DRL and not sure which one that is, I assume it is brown (DRL) and black for ground. Can anybody verify confirm?
    I saw some russian schematic for allroad and it appears to be grey/red or grey/black, and brown for ground. Now I'm puzzled.
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    I believe Brown is always ground on our cars
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Oct 20 2008
    Got the B7 wiring diagram for the helix headlights, just need the b6 pin out!
    Current: 2016 S4 Monsoon Grey
    Past: 2009 2.0T Prestige | RIP Old Ride: Totaled )'04 B6 1.8T B7 {RS4} Front Conversion -
    Oct 20 2008
    OK so no one replied, but eventually found out the pinouts for both b6 and b7. Thanks to helix!
    Hopes this helps anyone doing a conversion or adding leds to their headlights!
    Apr 21 2009
    Atlanta
    Old post… but did you ever find the b6 diagram? I need it
    02 B6 1.8tqm - APR stealth, RAI testpipe, Carbonio, VMaxx, RS4 sway, Joey mod, HID's top and bottom, 19x8.5/9.5 et 30 lorinser reps, 235/265 general UHP
    Coming>>> Revo 2, awe intercooler
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    Quote Originally Posted by bleach8484 View Post
    did you read the thread
    it's the post above your's
    Apr 21 2009
    Atlanta
    jesus, guess i should use a regular comp instead of tiny iphone screen haha... thanks!
    Senior Member Two Rings KR_A4's Avatar
    Aug 10 2010
    Toronto, ON
    Thank you very much Parimal. Huge help.
    Oct 20 2008
    Quote Originally Posted by KR_A4 View Post
    glad it helped!
    Apr 12 2011
    LI NY NE
    thanks dude this help me convert my b6 to b7 in the front
    Jul 12 2009
    San Francisco
    does anybody have xenon lights on b7 and can confirm where wires go ? I'm looking for pinout of xenon headlights so I can connect wires from halogen plug into xenon plug?
    B6/B7 owners: Buy my OEM suspension for $50 4 springs + 4 Struts
    Oct 20 2008
    Quote Originally Posted by null View Post
    for that just get this adapter.... http://kufatec.com/index.php?main_pa...roducts_id=334
    Jul 12 2009
    San Francisco
    I want to try to not have extra adapter I want to have a harness as if car had xenon to begin with.
    I want to disassemble stock halogen harness and plug in terminals from it to xenon harness
    and then run repair wire part from pin 11 to where ever it has to go in connector in cabin
    but I need to know where each wire from haligen goes into xenon harness
    anyone?
    Established Member Two Rings liberux's Avatar
    Jul 14 2011
    B6/B7 A4 Quattro 6MT
    Los Angeles/ San Fer
    Parimal, one quick question... I also bought some LED for my car.. Is there any way I can set them up so that I can just have the LEDs running, then LEDs plus regular lights? Sorry it may sound dumb this question but I'm a begginer doing this type of mods....
    Thanks
    1992 Acura integra(gone)
    1999 VW Passat 1.8t
    2003 A4 Quattro 3.0 b6/b7 f/e conversion ....coming soon 18 rs4 rep, beesix mod
    Oct 20 2008
    Quote Originally Posted by liberux View Post
    Thanks
    Yea just wire them with your drl lights/parking lights I believe the wire going to pin 7.
    Veteran Member Three Rings hbodo08's Avatar
    Apr 06 2009
    04' a4 3.0 ** 02' envoy slt--85' iroc z 28 (7400 original miles) 2010 Mercedes e350 4 matic
    The ville, Ohio Akron, Ohio
    Quote Originally Posted by Lusticles View Post
    is this the same diagram that can be used for the stock headlight with hid's i need to add resistors so my turn signals work so i was just wondering. i have a 04 b6 a4 ?
    I drive it like i stole it , then again
    /____________________\
    [_oo_\===0000===/_oo_]
    \_o___[HMB-30A4Q]___o_/
    Jul 14 2011
    If I'm not mistaken, it is the same for stock headlights
    1999 VW Passat 1.8t
    Senior Member Two Rings Mi1lion's Avatar
    Sep 30 2009
    Ducati 1199 Panigale ; D4 A8L
    WESTON,FL
    what about 12-pin (xenon) anyone have that
    Lexus RC-F
    Lexus NX-F
    Maserati Ghibli S
    Lexus GS-F- SOLD
    B6 A4 USP- SOLD
    Ducati 1198- SOLD
    Yamaha R1- SOLD
    Kawi Ultra 250x- SOLD
    Oct 20 2008
    Quote Originally Posted by hbodo08 View Post
    Yes
    Apr 06 2009
    Quote Originally Posted by parimal View Post
    Yes
    ok thank you does anyone know what color the wires are for the positive on each side im assuming brown is negative like always but im sure each side for the turns are a different color and maybe striped
    Feb 12 2012
    rochdale uk
    Hi everyone, i am a newbie here. and not so tecnecaly minded, so please please be bear that in mind...
    i am trying to fit after market drl's to my a4 cab and saw this thred pop up on google,
    my drl's have an auto dim (dims but not go out with headlight on) and a indicator function on them, i want to wire then up so they com on with the ignition on, dim when the lights are on and flash with the indicators, i know what wire duz what on the drl's , but dont have a clue on how to wire them to the pins in the head light plugs, any help on this would be wonderfull. thanks a lot ;-)
    Feb 12 2012
    rochdale uk
    ok guess nobody whant to talk to me.....
    seing the responde i got from the thred i did on turbo sound you can all ..well you know the rest, i will joine somwhere a little more friendly... thanks for nothing, and heres me thinking we were all audi fans and tryd to help eachother,,,,, guess NOT!!!
    Jul 14 2011
    Saxonblue:
    Don't get upset if they don't reply to you in like 5 seconds, LOL, especially people will less likely to reply to you if they see you throwing a fit.
    Now regarding your question, the only way to make the dlrs blink with the turn signal would be to have them conected to the turning signal connections, I am not quite sure how to have them dim when the lighs are on, maybe running a seperate switch to have them off once you turn on the lights...
    1999 VW Passat 1.8t
    Apr 05 2012
    Sterling/VA
    is there any chance some one on this post can provide the b7 headlight connectors (14 pin bi-xenon with auto adjust headlights - RS4 2007)?
    Apr 21 2012
    Michigan, United States
    I have an 2007 Audi A6 Quattro and I purchased the Spyder projector headlights with the DRL LED lights for my car. The low beam, high beam, and indicators all work except for LED lights. Any suggestions on what I should do? I am not sure on how to get power to the LED lights.
    Here is the item I purchased: http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
    Thanks a lot!
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Currently trying to dig up specific info on lighting diagrams. Will post back when I do.
    Oct 20 2008
    Quote Originally Posted by aniketarora27 View Post
    Thanks a lot!
    Should be plug n play. Did you have halogens to begin with? They should turn on when you turn on drl.
    Veteran Member Four Rings Jermunji's Avatar
    Jun 11 2013
    2006 Lexus “Landcruiser” LX470| 2001 GTI | 1987 bmw 325is
    The Mines, CO
    I know I'm raising this oldthread back up out of the grave but I picked up a pair of those switchback Type 1 Leds turn signals and I'm wondering which wires do I splice into from the diagram to get the load resistors working?
    "If you don't look back at your car while walking away, you bought the wrong car."- Anonymous
    "Us enthusiasts are numb to cost efficiency, otherwise we'd all be driving FRs or Imprezas"- Atid
    Oct 17 2014
    poconos pennsylvania
    hey does anyone here have the a4b7 12/14 pinout diagram?
    German Satisfaction
    2005.5 Audi A4B7 2.0t APR Stage 2
    Color: Laker Gold
    Wheels: 20in Zenetti Capri Wheels 225/30/20 SLAMMED on KSport Coils Stiff
    Instagram @LieFocals
    Active Member Two Rings storm4200's Avatar
    Feb 01 2010
    09 DUCATI 1198 (Red), 05 Ford F-150 FX4 (black)
    New Jersey
    Is there a headlight pinout diagram for the B8 A4?
    Apr 15 2014
    Ottawa/Gatineau Canada
    Quote Originally Posted by janam4u View Post
    Please do not do this :(
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Luxus Panzer View Post
    LOL!! It may be a little late since that was 5 years ago....
    Junior Member One Ring
    Jul 11 2019
    Huntersville, NC
    Does anyone have pictures of the headlight wiring going into the couplers for Xenon? I replaced the couplers by removing the wires and terminals, and then re-inserted into the new coupler. I only took a picture of one side of the coupler beforehand so I want to be sure I got both sides re-installed correctly. I would appreciate pictures or a chart showing terminal # and wire color. I really only need the R/S headlight (passengers).
