16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 001 - Upper Limit Exceeded - Intermittent
Hey guys.
This fault code has popped up a few times since putting on a full F.I. exhaust. Pops back up a couple of days after clearing it.
I searched the forums on this fault code,indicating it is O2 sensor related,correct? I assume O2 spacer will be needed. Which sensor(s) does this fault code point to? Should I just put a spacer on all 4? Is one spacer as good as the next? Any spacer in particular that you guys would recommend?
Thanks.
