Was driving around running errands and my battery light came on signaling my voltage was low. Look at the dial and it says my volts are down to roughly 10 when it usually reads 14v on average. I was like ah shit so I start driving toward home and all the lights in the world came on in my dash and my bezel lights became really dim. I have HID's and they were fine but everything else dimmed. When I pulled in and parked back at home the volts read 7. I'm thinking bad connection, battery is starting to go or my alternator (not in that order). Is there an easy fix i'm missing or is this one of the things I listed.
I have an OBDII Scanner and it spit out P1600 and for VW it means supply voltage is too low. Thanks Guys I really need some help.
