Originally Posted by
mholme
It sounds silly, but make sure when you turn up the Temp button, that it actually moves the degrees up. The buttons like to stick on the climate control. If the button is stuck on a previous cooler setting and you just crank up the fan speed, you'll still get nothing but cold air. Just a thought.
Not to thread jack, but my buttons have been slowly starting to stick in my 01 climate control unit in the dash.
I have found that if the car is cold inside, they are very hard to push and most of them either wont work or wont come back out when I push them in.
What do you suggest I clean the buttons with?
thanks and go on with the original OPs questions if you cant answer mine
