Results 1 to 4 of 4
    Veteran Member Three Rings manhattanprjkt8's Avatar
    Jun 22 2008
    Lots of blown out mounain bikes
    pennsyltucky
    Wheel Bolt Pattern 5x112 = 5x4.5" ?
    I am on the hunt for a pair of steelies for my s4 as a winter set and think i found them but want to make sure of something:
    is a 5x112 = 5x4.5" bolt pattern
    I know that 1 inch = 25.4 millimeters so that nets out to 114.3 (which isnt exactly 112)
    How exact is this? It looks like the american measurement won't quite fit...
    Anyone?
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: Wheel Bolt Pattern 5x112 = 5x4.5" ?
    Use wobble bolts
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    or pass and get cheap oem's or reps for winter...
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    It is not a good idea to get wobbly. I have seen some idiots drill out a 114.3 (Honda) to a 115 (GM)... how is that safe?
    Also, you might want to double check your caliper clearance on steelies. Definitely better to go with a rashed/beat up set of alloys or reps than rocking the steelies with wrong bolt pattern.
    FS: Audi TT 225Q Roadster
