Results 1 to 10 of 10
    Veteran Member Three Rings allroadstomtl's Avatar
    May 25 2009
    '12 Avant P+, '16 GSW
    Montreal
    Who does Rustproofing in Montreal, should it be done ?
    Has anyone done rustproofing in the Montreal area and by whom ?
    '12 A4 Avant P+, S-Line 3 Spoke, S-Line Stone Guards,
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Re: Who does Rustproofing in Montreal, should it be done ?
    I did for 2yrs then stop. Used Krown Rust.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Veteran Member Four Rings 'mk4-turbo's Avatar
    Oct 02 2007
    Montreal
    wont this interfere with Audi's warranty?
    Established Member Two Rings Badcopnodonut's Avatar
    Sep 28 2009
    Brossard/Qc
    Quote Originally Posted by 'mk4-turbo View Post
    The factory warranty is 12 years against perforation .
    If you do a rustproofing treatment it will void your warranty.
    But if your car is older than 12 years why not ?
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    my car started to rust
    i called audi
    they said that because i didnt rust proof it was not covered under warranty
    Sep 28 2009
    Brossard/Qc
    Quote Originally Posted by anthony911 View Post
    i called audi
    It s against perforation only
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Quote Originally Posted by Badcopnodonut View Post
    01.5 A4 1.8t sport
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    yup that was my thing too ??? against what?
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    If you do this, you need to ensure that the little holes underneath are not plugged up. The holes are there to let the water drain out. Block the holes and you'll end up getting rust to form from the inside-out and by the time you see the rust, it's already too late.
    Mike
    Jan 06 2009
    Quote Originally Posted by m5racer View Post
    Rust is technically not covered under warranty, what is covered is if the rust causes a perforation (ie. visible hole) through any metal surface.
    So normal surface rust is not covered, only gaping holes are. Kind of missleading.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
