Results 1 to 9 of 9
    Established Member Two Rings jettin123's Avatar
    Feb 03 2009
    Richmond, VA
    Will 235/40/17 tires work on stock rims?
    I found a deal on these tires, but will they work okay?
    Thanks
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Re: Will 235/40/17 tires work on stock rims?
    Quote Originally Posted by jettin123 View Post
    Thanks
    I ran the B7 twin 5 spoke wheels with the 235/45 17 Conti tires on my B5 A4 with no problems. Hope that helps.
    2014 A4Q Red w/ black optic black interior
    Senior Member Two Rings madman1234509's Avatar
    Mar 20 2009
    2002 A6 2.7t 6mt
    mayfield ny
    http://www.miata.net/garage/tirecalc.html
    that link will help a ton with tire sizing.... stock tires for my a6 with 17" rims was 235/45/r17 i think 235/40 the hieght of the tire itself will be smaller so compared to whatever your stock size was your speedo might be off a bit, check the link out it will help
    C5 Union
    Vast Stage2+
    (SOLD) '02 a6 black sport pkg 6MT, EVOMs intake, Custom 3" DPs, Custom 2.5" w/ borla mufflers & test pipes, RS4 clutch and PP, Samco TBB, Forge007 DVs, ER SMIC's, VAST w/m, dynotune digital boost gauge,
    5% tint, In.pro chrome mirrors
    '08 Black crew cab/short bed F-350 6.4l twin turbo. 5" exhaust, 6" tip. AFE intake, Spartan custom tuned. 35X12.5R20. 2.5" lift.
    600hp/1200ftlbs
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    I'm running 245x40x17 on the stock wheel and I'm lowered on H&R coilovers.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    I have 235's on stock 17" avus rims, works fine
    My car is fast
    Established Member Two Rings DYT937 S4's Avatar
    Sep 22 2009
    Dayton Ohio
    I think he's really asking if the height of the tire would be ok. Id imagine it would be fine but a thinner sidewall tire without bigger wheels or lowering the car will increase the gap between your fender and the tire. I used to have a DSM and when I bought the thing it had 215/35/17's but the car wasn't lowered at all and it looked ridiculous.
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    it will work 100%, I have B5 S4 wheels with 235/40 Toyos as track tires and the clearance is minimal, but its there.
    May 07 2007
    Quote Originally Posted by DYT937 S4 View Post
    the height difference between 225/45 and 235/40 is minimal, you wouldnt even really notice it.
    Sep 22 2009
    Dayton Ohio
    Ah yes I meant 225/40's sorry.
