Results 1 to 33 of 33
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Specs: quick list of torque specs fot 1.8T engine
    You know how it is when you build your motor, you need the torque spec for something in the engine but you don't have the Bentley or you are not home etc etc...Well, not anymore, I put together this list with most of the torque specs used in a 1.8t motor build...If I missed something feel free to add
    ADMIN's Move it to the appropriate location
    here it is
    1.8t torque specs
    Carrillo conrods- 55lb/ft
    Brute conrods- 50 lb/ft
    ARP main studs- 65 lb/ft. ARP bolts are coated with a protective oil, not lubricant. Clean with solvent and use the lube provided by ARP.
    Cam caps- 10Nm-7.37 lb/ft
    Cam gear- 65Nm- 47.94 lb/ft
    Cam pos. sensor- 25Nm-18.44 lb/ft
    Raceware head studs- 3 steps-25, 40 then 55 lb/ft- using factory sequence.
    Attention!! Use motor oil to lubricate the threads. Heat cycle and retorque to 55lb/ft
    Knock sensors- 20Nm-14.75 lb/ft. Attention!! Knock sensors are sensitive to tightening torque.
    Trigger wheel- 10Nm-7.37 lb/ft +1/4 turn. Attention!! If removed use new wheel and bolts.Use red loctite.
    Crank gear- 90Nm-66.37 lb/ft+1/4 turn. Most people use red loctite and an impact gun on this.
    Oil squirter- 27Nm-19.91 lb/ft
    Water pump- 15Nm-11.06 lb/ft
    Spark plugs- 30Nm- 22.12 lb/ft
    Oil pan- M7- 15Nm-11.06 lb/ft
    - M10- 40Nm-29.50 lb/ft
    Sealing flanges- 10Nm-7.37 lb/ft
    Toothed belt tensioner- 15Nm-11.06 lb/ft
    Tensioner roller- 27Nm-19.91 lb/ft
    Flywheel bolts:
    depending on the model there are 2 types of bolts identified by their length. Use red loctite.
    1.Screw length 43mm- 60Nm-44.25 lb/ft+ 180 turn
    2.Screw length 22.5mm- 60Nm-44.25 lb/ft+90 turn
    3.ARP flywheel bolts: 75lb/ft no washers, make sure the holes in the flywheel are chamfered for the arp bolts
    Dampener 10Nm and 90deg turn. Always replace bolts.
    BetaAlphaTau member #19
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Re: quick list of torque specs, 1.8t engine
    boss
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Nov 24 2004
    MOntreal
    to the top we need this sticky
    Aug 09 2009
    Garden Grove California
    thank you..this is very useful.
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    Good shit bro!
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    May 24 2007
    Southern California
    good stuff. very useful for everyone.
    you can probably throw in flywheel bolts too.
    Kyle
    2.0L Revo GTRS Eliminator
    Nov 24 2004
    MOntreal
    Quote Originally Posted by A4natomical View Post
    yes soon Oem as well as the new arp flywheel bolts from 034 wich I will install monday
    Nov 24 2004
    MOntreal
    updated with flywheel specs
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    This needs to go to the DIY section.
    E85!
    "I got four cylinders when I need them and four cylinders when I don't"
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    Any updates to this?
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Nov 24 2004
    MOntreal
    Quote Originally Posted by nein-reis View Post
    what is you need??
    Sep 15 2008
    CO
    I was thinking.... Can we make this a sticky, format it a little better (organize it), and add fluid amounts (engine oil, diff oils, power steering, etc)? This could be a great resource.
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    Awesome, i'm trying to find the specs on the 4, 5mm bolts on the Throttle Body...
    Previous
    USP B6 A4
    Jul 14 2009
    Pasadena
    sticky!
    IG: @matthewee
    Mar 27 2010
    Slippery Rock, PA
    Anything for cat to turbo on '02 A4 Quattro, 1.8T?
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by 401jeeper View Post
    real tight
    Veteran Member Four Rings 3vom's Avatar
    Aug 26 2009
    Quote Originally Posted by [email protected]. View Post
    real tight
    Lock Tite!
    I need the ARP Flywheel bolts torque spec actually :\
    I love boost.
    Aug 26 2009
    Quote Originally Posted by 3vom View Post
    Lock Tite!
    Anyyone?
    I love boost.
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    thanks for posting this
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    ARP head bolt specs?
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Sep 12 2008
    South Central PA
    Thank You!! this is awesome, I was wondering what the cam caps were supposed to be torqued to...... i think i might have over done it a bit.... lol
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Sep 12 2008
    South Central PA
    Quote Originally Posted by AudiHere04 View Post
    step one: 45 ft lbs
    step two: turn an additional 90 degrees
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    Buy My Parts!
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    I'm going to revive this because wtf is the spec for exh Mani to head? Can't find that anywhere
    2010 VW GTI
    Previous cars:
    2003 A4 1.8T APR Stage 1+
    Nov 24 2004
    MOntreal
    Quote Originally Posted by Casius View Post
    I never torqued them, it's hard to get a torque wrench on some of them with the manifold I have....Put them by hand, use the copper nuts that have a lock, that is enough, I never had them come loose
    Veteran Member Four Rings lunamarA4's Avatar
    Feb 25 2004
    lots of tools and spare parts
    San Diego, CA
    do these differ when using ARP bolts?
    4 SALE B6/B7 parts
    RafE |2004 BT White A4 Avant|
    |2002 S8 6spd - fully overhauled + 6 spd|
    |1988 E30 S52 Pandem Kit|
    |1991 E30 M20 Touring|
    Nov 24 2004
    MOntreal
    Quote Originally Posted by lunamarA4 View Post
    which ones exactly?? Arp should come with their own instructions...
    Aug 19 2013
    minnesota
    Any one know the torque spec for the rear main seal b6 a4 1.8? Update: its 15nm
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Timing belt tensioner mounting bolts: (Allen, 6mm?) torque?
    http://www.audizine.com/gallery/data...ion_pulley.JPG
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    Dont think i saw the ARP flywheel bolt specs?
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Feb 20 2010
    Brighton, MI
    ARP provides their own specs, or? None included in package?
    05 Golf TDI
    Apr 13 2022
    Michigan
    What about OEM connecting rods?
    OEM main cap bolts?
    Nov 24 2004
    MOntreal
    Quote Originally Posted by djcusick View Post
    OEM main cap bolts?
    oem con rods are 30Nm plus 90 deg/ 1/4 turn
    oem Main bolts are 65Nm plus 90 deg/ 1/4 turn
    https://cardiagn.com/audi-a4-8e8e28e...anuals-wiring/
