Results 1 to 7 of 7
    Senior Member Two Rings klhbeetle's Avatar
    Sep 15 2008
    Santa Fe
    Anyone Know Where the YAW Rate Sensor is located?
    Hey,
    My YAW Rate Sensor is going in and out and I want to check the connections. I've searched and found that it's located behind the airbag on the A6 2.7t. Another post said it was under the back seat. anybody know the location on our cars?
    I downloaded the Bentley Manual and still can't find it.
    thanks!
    '01 allroad 6mt stage3
    '08 Ford E350 Quigley 4x4 Powerstroke
    Sep 15 2008
    Santa Fe
    Re: Anyone Know Where the YAW Rate Sensor is located?
    Anybody have experience with the YAW sensor at all?
    Jul 11 2007
    Chicago
    I would assume under the dash under the knee bolster. Should be in there... but I could be wrong..
    Old "Casa - 01 S4 - Homebrew Stage X - K03/16 - FMIC - Autospeed Motor Mounts/Tranny Mounts/DTS - Stern Power Ring/Rear Differential Poly - XS Power Exhaust - JHM Shifter/Solid Link/Delrin/3rd Detent/Homebrew Shifter Knobbie weight - Homebrew SMOC -"
    New "07 Infiniti Black Sedan G35s 6MT"
    Sep 15 2008
    Santa Fe
    Thanks, I'll check bentley.
    Established Member Two Rings BlackS42002's Avatar
    May 06 2009
    85 Scirocco. 99.5 Jetta. 02 S4
    Delaware
    Check under the rear seat cushion kinda in the middle.
    Sep 15 2008
    Santa Fe
    My CEL went away, including YAW Sensor failure and EGT failure. This car just fixes itself! If they come back, I'll def. check under the back seat for that YAW sensor.
    Established Member Two Rings loomx's Avatar
    Aug 27 2008
    UK
    Its under the rear seat cushion, IIRC slightly to the left.
    If you unbolt it/redo it up it will need recalibrating because it wont be back in exactly the same place. Been in one car this was done to (not an audi) and it kept slamming the brake on one side and inducing a slide :S
