Results 1 to 29 of 29
    Feb 23 2009
    Vancouver
    B7 S4 Front Brakes on B7 A4 DIY?
    Hi All,
    I've searched and not found a DIY on upgrading the front brakes on my B7 A4 to B7 S4 brakes. I have all the parts need and from some reading it seems to be a direct "bolt-on" swap, is this correct?
    Any help would be greatly appreciated!!
    p.s. I may have an extra pair of front S4 Carriers after :)
    Sep 13 2008
    Western Chicago Burbs
    Re: B7 S4 Front Brakes on B7 A4 DIY?
    correct me if im wrong, but aren't the b7 s4 and b7 a4 brakes the EXACT same thing.
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    The caliper is the same but the S4 uses a longer carrier which fits a larger rotor, 345m on the S4. The stock B7 A4 rotor is 320somthing IIRC.
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    no real point in doing the swap in my oppinion. the b7 has much better brakes then the b6 and besides the 20mm difference is just reaction time or good pads. ur just adding weight. what u have is good enough just dont cheap out on parts to support. get stainless lines. good pads.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Feb 23 2009
    Vancouver
    Quote Originally Posted by 05A$SE View Post
    Fair enough, but I'm due for Full front brakes and acquired a complete B7 S4 front brake kit (rotors, calipers, carriers, pads, etc) with only 5000 miles on them for an extremely good price. The S4 Caliper looks alot better as well and braking will improve........yes you are correct the only downside is that I will be adding a bit of weight with the larger rotor........
    but back to my question
    Veteran Member Three Rings Silververtu's Avatar
    Sep 26 2005
    DMV
    Do S4 brakes fit into stock 17" rims?
    Current:
    2019 Porsche Cayenne Turbo
    Gone but not forgotten:
    2006 2.0T A4 Avant 2007 BMW Z4 Roadster 3.0si 2006 BMW M Roadster 2013 BMW 550i M Sport 2015 Porsche Cayman S 2015 BMW X5 50i M Sport
    Apr 09 2009
    montreal
    not true, kinetic energy is transfered into heat by braking. larger brakes can handle more heat and stay efficient longer. thats like saying theres no difference between vented and none vented disks
    for the price/upgrade imo its worth it if you have to replace your disks anyways
    http://www.ecstuning.com/Audi-B7_A4-...ke_OEM/ES6241/
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    so, when installing that kit...you can use the same pads as a B7 A4?
    "The important thing is not to stop questioning. -Albert Einstein"
    "Treat everyone like a million bucks; and always have a plan to kill them"
    2007 A4: APR, STaSIS/Alcon, Avant Garde, Hankook, Ohlins
    Apr 09 2009
    montreal
    yup ur not changing ur caliper just the carrier to get larger disks. nothing is stopping u from getting some hawk hps or something tho :) might as well at that point.
    upgrading carriers and disks were VERY popular on mk4 gen vw golf/jetta people would use the 337/20th setup.
    Established Member Two Rings positiv_rate's Avatar
    Apr 26 2008
    '15 Audi S4 // ‘04 BMW E46 M3 // ‘22 Audi SQ7 // '12 BMW E91 328xi
    Montreal, QC
    I got a deal on some 345mm S4 rotors & carriers... it's a direct swap for a B7 A4: they both use the same caliper...
    Makes for a nice OEM+ upgrade. You increase your braking torque because of the longer arm your same clamping force (same caliper) is acting upon: (345mm - 320mm= 20mm difference in diameter/2= 10mm arm difference. You also benefit from the greater heat absorbing/dissipating capacity of the larger rotor.
    Add to that some good fluid (i.e.: Motul RBF600 or Pentosin Racing fluid) and better pads (Hawk HP-PLUS if you don't mind some noise/dust) and you'll have a relatively cheap brake upgrade. Throw in some SS lines for good measure (and better pedal feel!) and your good.
    I go lapping on a pretty tight 1.1 mile course (for a 4000 lbs porker that is!) and I still have the stock pads. But as I gain confidence, I can start to overheat them... the modding never ends!!
    Cheers!
    2015 S4 // Technik+ // Mythos Black // 6MT // Sport Diff // Bose
    APR Stage 2 DP | APR Open Carbon Intake | AWE S/C inlet hose | JHM short shifter | Eurocode headers | JHM baffled hi-flo cat downpipes | 034 drivetrain mount inserts | 034 rear swaybar | CR-15 | ECS SS brake & clutch lines | ECS 8mm/12mm spacers | Tyrolsport caliper stiffening kit
    2022 SQ7 Technik | Daytona Grey Pearl/Black Optics & badges | Arras Red | Red Calipers | Black Alcantara Headliner | Tow Package
    Feb 23 2009
    Vancouver
    So, as I mentioned, has anyone done this upgrade? I am doing it tomorrow along with my 034 HFC, I'm hoping it's a straight swap!!
    if anyone can chime in with some experience doing the S4 brake upgrade, I would really appreciate it!!
    cheers,
    DUH! an Audi
    los angeles, CA
    hmm figured i posted in here...
    easy:
    remove the caliper, remove the carriers, remove rotor. put new carrier, rotor and stock caliper.
    umm, caliper has torx bolts holding it, carrier is like a 13mm bolt, rotor is a hex screw, roughly the same one as the headlight.
    Sorry, nothing specific, if yuo need help shoot me a pm with your number I can walk you through it.
    -randy
    Feb 23 2009
    Vancouver
    Quote Originally Posted by Quattro View Post
    easy:
    -randy
    Thanks Quattro,
    I think we share a similar interest or style in our cars
    it was a straight swap, done in 3 hours (taking my time), thanks for chiming in!!
    034 HFC is a great "bang for buck" upgrade, now onto my GSG FMIC
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    I know, old thread, new post... But curious to know, the stock B7 S-line rotor size is ?, and the S4 rotor size is ?. I ask because I am running 19" rims and I want to fill them with as much braking as I can. From what I have been reading the S4 rotors add about 25mm or so while still using the stock B7 calipers, all I need to do is swap out the carriers. But if I want better braking, I need to get the stock S4 calipers as well as the carriers, rotors and associated hardware. (RS4 swap out of the budget at this time...)
    I have been searching/reading about doing the S4 swap for a while now and am quite interested in doing this, especially since the near disaster at 120mph on the roadway by some dumb ass, but regardless... Has anyone done a DIY of the S4 full brake swap to a B7 yet? If so I have not found it.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    No diy necessary. For front, remove the two slider bolts to remove the caliper. Then remove the two carrier 3/4" bolts to remove the carrier. Remove old rotor with 25 or 30 torx set screw. Place new 345 S4 rotor of choice. Replace carrier with the new S4 carrier in reverse order. Replace new pads and then resecure the slider bolts. Some versions of the A4 calipers need minor grinding to clear the greater diameter rotors, mine didn't
    S-line A4 only beefs up the dampners and rear sway bar. No brake differences from normal A4 with 320 rotor.
    Rears are same process. The e-brake hardware is compatible and can be straight swapped over without messing the cable beyond unlatching it.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Apr 08 2016
    Mission Viejo, CA
    Maybe DIY is a wrong choice of words... I can do brakes, done at least a thousand brake jobs. I guess what I should have asked is has anyone done a write-up of the necessary parts needed to do a full front & rear swap from a B7 to a S4 kit? With 19" rims, the rotors just look minuscule.
    My stock S-line RSB was like 16 or 18mm, I swapped in a 22mm from a S4 and it feels great.
    2008 Audi B7
    2003 Ford F250 XLT
    Oct 24 2015
    Perth, WA
    I did it a few weekends ago.
    Remove tyre.
    Clamp (old) brake lines to prevent leakage (replace with braided is a good way to go here).
    Remove caliper bolts (front) or guide pin bolts rear. Remove caliper.
    Remove pads and carrier.
    Remove rotor.
    Clean with brake cleaner and wipe down.
    Clean new rotor with brake cleaner and wipe down.
    Install new rotor.
    Reverse install for new gear.
    Bleed brakes.
    Break in pads.
    My respray thread
    Jun 04 2011
    Clayton, CA
    A thousand brake jobs is alot of brake jobs!
    Parts list:
    S4 rotors x2
    S4 caliper carriers x2
    S4 shields
    Ps, S4 rear sway bar is only 20mm, S-line is 18 and stock is 16mm. RS4 is 22mm. 034 motorsport is 25.4mm
    Build Thread
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    Quote Originally Posted by rongeur View Post
    I got the S-line package and the front brakes are bigger, rotors and calipers. Rears are stock B7 though
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Apr 08 2016
    Mission Viejo, CA
    Parts list:
    S4 rotors x2
    S4 shields
    Ok, maybe not a thousand, but well into the hundreds, (I use to be a mechanic and we did probably 4 brake jobs a week, plus my own vehicles for 40 years).
    My stock RSB was only 16mm and I have a S-Line, the one I installed is 22mm.
    Anyone know if the S4 rear brakes are the same size as the stock B7?
    2008 Audi B7
    2003 Ford F250 XLT
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    Quote Originally Posted by mgfranz View Post
    They are not. They are larger and a popular upgrade for B7 A4's with a big brake kit upfront
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
    Deactivated Four Rings
    Jun 23 2011
    The S4 shields are not needed either. I have been running my set up with the stock B7A4 splash shields for about 200k miles and never had any wet brake issues due to rain/puddles, etc.
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by Chris@EPL View Post
    Maybe up front, but it looks like the rear shields are needed if they are swapped for the larger S4 rears.
    If I do the rears as well, all I need is the rotors, carriers, calipers and shields right?
    2008 Audi B7
    2003 Ford F250 XLT
    Jun 23 2011
    Correct I was just talking about the front S4 brakes
    Jun 04 2011
    Clayton, CA
    I have S4 rears on the same A4 shield. Fits fine.
    Build Thread
    Jun 17 2013
    jersey city nj
    I was thinking about doing the rear S4 rear caliper mode with these http://www.audizine.com/forum/showth...S4-Rear-Brakes. But wanted to know do you feel a difference with the braking ?
    Jun 04 2011
    Clayton, CA
    I am not sure if it is a daily driving perceivable difference but I do feel that the S4 has a more balanced braking setup and to only upgrade the fronts leaves you in the middle of the OEM upgrade. Rear vented rotors over the solid rotors of the A4 is worth it as well as long as you find them for a reasonable price.
    Build Thread
    Jun 17 2013
    jersey city nj
    for the input
    Nov 15 2011
    Montreal | I sell in USD
    Rear S4 dust shield holes wong line up with the holes on an A4. You either mod the S4 shields or keep the A4 dust shields.
    *****I sell in USD*****
