Results 1 to 34 of 34
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Weird whining noise only when moving...thoughts?
    A few days ago, I started to hear this very faint whining noise. Since then, the whining noise has gotten a little bit louder but still can only be heard with the radio off.
    When idle, there is no noise. It only whines when in motion. The whining seems to increase/decrease with speed. It starts at about 15-25 mph (not consistent when it starts happening). I can hear it up to about 45 mph. Once on the highway or above that speed, it's hard to hear due to road and tire noise. The best I can describe the noise is like a treadmill that is on with no one running on it, but slightly higher pitched. A squeaky belt sort of noise.
    I don't think it's a wheel bearing because it's not a groaning/humming/howling noise. I just rotated the tires today and checked for cupping or abnormal wear. The front two tires have slightly more inside tread wear than the rear tires. I took a drive after rotating, no change in noise. I can't pinpoint if it's coming from a specific corner or the center of the car. Could it be the drive shaft bearing making this type of noise? It has to be something that moves or spins since it only happens with movement.
    Any ideas would be great, thanks!
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: Weird whining noise only when moving...thoughts?
    is your girlfriend in the car?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    May 03 2005
    Boston
    Quote Originally Posted by mattman View Post
    ha ha very funny
    EPL S2 + TCU
    Previous Cars:
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Does it vary with RPM or with vehicle speed?
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    May 03 2005
    Boston
    Quote Originally Posted by bananas View Post
    With slower speeds, it makes a drawn out, long cyclical whining noise. As I speed up, the whining cycles are shorter.
    EPL S2 + TCU
    Previous Cars:
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Bearing?? Maybe clutch bearing? or Muffler bearing??? =) Nah but seriously sounds like some sort of bearing...
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    May 03 2005
    Boston
    Quote Originally Posted by Dan1969 View Post
    Haha, definitely sounds like some sort of bearing. Someone suggested it may be the drive shaft center support bearing.
    EPL S2 + TCU
    Previous Cars:
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by gdawg'05a4 View Post
    its a whining? not a buzzing?
    Meet Shanice...
    For Sale:
    Aug 26 2005
    Is there any evidence of oil seepage from the trans/center diff, or rear diff housings? If there is, check/change the oil/fill levels in the drivline.
    Veteran Member Three Rings Cronogr's Avatar
    Dec 14 2006
    Audi A4 B7 1.8TQM
    Greece
    Probably one of ur control arms gone bad ... check it dude most the of the "whining sounds" are ca related :/
    Audi A4 1.8 TQM B7 ~ Revo / Forge Dv / Sprint Booster / Apikol Snub Mount / Dtm Air Filter / Rs4 Sway Bar / Ebay SS / bbs s4 wheels
    Audi A4 1.6 FWD B5 ~ Koni sport / Eibach pro / Ebay ss mod to fit / Full Meyle CA kit / 034 motor,tranny mounts / 034 Strut mounts / Awe Dts Stabilizer / Apikol Snub mount / Neuspeed 28mm rear sway / Jhm shift knob / Momo e-brake / 17x7.5 oem b7 wheels
    Jun 30 2009
    Washington DC
    I got a similar problem. The sound sounds like the car hum from old race car games. Cannot hear it too much below 40mph, but from 40-70mph it gets really annoying. Not super loud, but lound enough to annoy the hell out of me.
    This problem just started on Friday and i am pretty sure it is coming from the driver side.
    What should i look for in the control arm to see if there is any damage? Any DIYs that might explain this?
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    I have the same noise i think, this is gonna sound a little weird, but can you sort of feel the vibration of the whining as it gets louder/softer? I hear mine sometimes before i warm up my car but then it goes away after that.
    May 03 2005
    Boston
    Yep, whining. Definitely not buzzing.
    I'll check on that. I know that there has been no fluids dripping onto the ground though.
    Quote Originally Posted by Cronogr View Post
    I had all 8 arms replaced recently. While I had the front tires off, I inspected the area and all looked fine.
    Quote Originally Posted by pkny View Post
    A humming noise may indicate that one of your wheel bearings going bad.
    Quote Originally Posted by Kwarner View Post
    I don't think I feel a vibration...I'll check more closely for this today.
    EPL S2 + TCU
    Previous Cars:
    Registered Member Two Rings sittinherebored's Avatar
    Aug 23 2009
    s.e.
    i would definitely check your transmission fluid levels. my trans whines a lil bit but its under warranty so i dont care much
    0-60 in... still waiting....
    May 03 2005
    Boston
    Quote Originally Posted by sittinherebored View Post
    The fluid was changed a few months ago so it should be pretty topped off. The only reason I don't think it's gear/transmission related is because if I put the car in neutral, clutch out and let it coast, it still makes the noise.
    EPL S2 + TCU
    Previous Cars:
    Mar 27 2005
    The Cold North
    greg - you probably already checked them. But are all the CV joints still in good condition? No tears or missing bolts on the flanges?
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    May 03 2005
    Boston
    Quote Originally Posted by EBG 18T View Post
    Hey Eric, yep, I checked them out last night. All looked to be fine.
    EPL S2 + TCU
    Previous Cars:
    Veteran Member Three Rings rpetral0's Avatar
    Jul 25 2009
    Not sure if it's the same issue or not but as soon as the outside temp drops to around 55 or lower I had a whining noise like the one you are describing. Also occurred while turning at low speeds. If that's the case and you already haven't checked it, then check your hydraulic fluid level. What I was told is that it should actually be filled up to the "M" in Max, not just the top of the fill section. As the temp drops these cars suck in all the fluid and if you don't have enough, it pulls air into the system which starts making that whine. Good luck!
    ...I'm listening
    Sep 18 2009
    in the sky
    bad turbo? if it starts up and u can hear it on idle then it might be it. just a thought.
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Check the rear diff fluid, it's still turning when you're in neutral and coasting. When the axle seals go it doesn't leak to the ground because of the guards, it just coats the surrounding parts with a thick dirt+grease cocktail.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    May 03 2005
    Boston
    Quote Originally Posted by b6noob View Post
    It doesn't happen at idle, only when the car is moving from 15-25mph and up. Definitely not the turbo.
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    Quote Originally Posted by nihil View Post
    I'll check it. The rear diff fluid was changed along with transmission fluid. It doesn't explain why it only starts happens at a certain speed. I would think if it's not enough fluid, it should happen as soon as I start moving.
    EPL S2 + TCU
    Previous Cars:
    Senior Member Two Rings combsatl's Avatar
    Jun 15 2009
    05 Lincoln Navigator, 01 BMW 330i 5MT
    North Atlanta, GA
    I didn't see anyone mention or ask this:
    Where is the sound coming from? If you think it's coming from the rear passenger area it could be a plugged fuel filter. The fuel pump is below the rear passenger seat and if the fuel filter gets plugged the pump has to work harder creating a terrible humming, whining noise. I had this when I bought my car (04 with 85k) and replaced the fuel filter which fixed it.
    Senior Member Three Rings akarol's Avatar
    May 09 2008
    2003 Audi A4 3.0 Cabriolet
    Orlando, FL
    Check your tires before anything. I had a very similar problem and it turned out I had some flat spots that led to this obscure noise. Since then, the car's been quiet.
    Sep 22 2007
    GTA
    Check you power steering fluid. Topping up mine fixed a similar issue I was having
    Make sure the engines cold before you check it
    May 03 2005
    Boston
    Quote Originally Posted by combsatl View Post
    Have not been able to pinpoint a specific area yet but it sounds like right under the car/front.
    I've been through a bad fuel filter before and it is not that loud humming noise from the rear right passenger area.
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    Quote Originally Posted by akarol View Post
    I rotated the tires the other night and inspected them. They looked fine and are at the proper pressure.
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    Quote Originally Posted by Jakun View Post
    P/S fluid level is good.
    EPL S2 + TCU
    Previous Cars:
    May 03 2005
    Boston
    An update for those who are interested...went to see my mechanic today about the noise. Driving around, he heard it as well. We put it up on the lift and drove it to reproduce the noise. Turns out it is the drive shaft center support bearing. With the B6s, there is no replacing just the bearing (unlike the B5s), it's the entire drive shaft (prop shaft) that needs replacement.
    Cost...$1084 from the dealer. That news was not the highlight of my day lol. I called Force5 (Audi/VW junk yard) and they had a good working prop shaft out of a B6, $275 with 30 days warranty! Ordered it so now just waiting for it to arrive at the shop.
    EPL S2 + TCU
    Previous Cars:
    May 21 2007
    Florida
    good find man!! where is force5 located?
    2018 Navarro Blue Q5
    May 03 2005
    Boston
    Quote Originally Posted by doublezero30 View Post
    They're in Concord NH.
    EPL S2 + TCU
    Previous Cars:
    Mar 27 2005
    The Cold North
    they are in concord Nh. but be careful they have pulled some sketchy stuff.
    2020 Chevy AEV ZR2
    Jun 30 2009
    Washington DC
    I am pretty ignorant when it comes to car parts, but what is the drive shaft center bearing?
    Is that the tube that connects the quattro system?
    May 03 2005
    Boston
    It's the metal shaft that connects the transmission to the rear axle.
    EPL S2 + TCU
    Previous Cars:
