View Poll Results: Do you use a torque wrench on spark plugs?
Voters
55. You may not vote on this poll
  • Yes - I torque to exactly 22 ft lbs
    24 43.64%
  • No - I snug it up by feel
    31 56.36%
Results 1 to 40 of 40
    Established Member Two Rings jackp311's Avatar
    Feb 18 2007
    Las Vegas, NV
    Torque Wrench for Spark Plugs?
    Curious how many of you actually use a torque wrench when tightening spark plugs. Please answer yes if you use a torque wrench or no if you tighten by hand.
    Established Member Two Rings JoMiDo88's Avatar
    Jun 08 2009
    2001.5 Audi S4
    Dutchess County, NY
    Re: Torque Wrench for Spark Plugs?
    i never have. should i?
    Established Member Two Rings eweu's Avatar
    Aug 25 2008
    Silicon Valley, CA
    Why wouldn't one use a torque wrench? It's an easy way to make sure you've completed the job perfectly.
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by eweu View Post
    Agreed...
    My sense for most nuts and bolts is to tighten it "tight" and most of the time for general items I overtighten.
    Overtightening spark plugs could result in breakage and worst yet snap-off into the block.
    Conversely, undertightening could result in vacuum issues and misfires.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Feb 18 2007
    Las Vegas, NV
    Quote Originally Posted by Eddie Man View Post
    Agreed...
    I have always done it by hand. I twist the extension by hand and then come back at the end and torque them down by going about another 3/8's of a turn or so.
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    In my opinion plugs should always be torqued to mfg's specs. Especially with aluminum heads. It's pretty easy to overtighten the plugs,not using a torque wrench,stripping out the threads. Carefully thread them by hand,but they should always be torqued to spec,imo.
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Mar 04 2009
    Memphis, TN
    Yes
    Feb 18 2007
    Las Vegas, NV
    Quote Originally Posted by mad70sx View Post
    Well, I will be purchasing a torque wrench soon. I will always use it from now on. Provided the plugs come back out okay, is there any unseen damage that I might have caused? I have always done them this way on my 1.8T and never had any problems. That is an aluminum head as well.
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    very experienced mechanics i know do it by hand/feel and has never had a sparkplug break on them.
    CT4952
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Quote Originally Posted by Siggiepop View Post
    Ding,ding,ding!!! We have a winner!
    Someone not as experienced,imo,should carefully thread them in by hand and then torque to spec. I've seen many a novice wrench spinner strip the threads by overtightening or crossthreading.
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Quote Originally Posted by jackp311 View Post
    I would imagine that you would know if you damaged the threads after taking the plugs out. I would think they would be difficult to back out of the threads were damaged.
    I'm not saying you have to use a torque wrench. If you are comfortable not using one,then don't.
    Registered Member Two Rings
    Oct 21 2006
    '07 Audi RS4; '98 240SX Turbo
    In the O.C., baby
    "experienced mechanics" LOL Doing warranty claims analysis for NGK for six years taught me one thing: all the experience in the world does little to combat laziness. 99% of engine damage that seemed to focus around spark plugs was the result of an incorrectly torqued plug.
    Overtighten means a cracked insulator, or breached seal leading to poor heat transfer, over heating of the plug tip, detonation and cylinder damage.
    Under tightened means all of the above, except a cracked insulator and more rapid damage.
    Remember: spark plugs REMOVE heat, they do NOT create it. Anything that impairs a plug's ability to remove heat effectively (including incorrect heat range or gap) WILL have consequences.
    Living my dreams...
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Nah, I only have a Snap-On 1/2" torque wrench at home and it starts at 50 ft/lbs. I normally tighten it until I feel that crush washer stretch out and then a little bit more.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Hand tighten
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Senior Member Two Rings D.K's Avatar
    Jul 16 2008
    <--- does not use a torque wrench.
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    You can feel the washer crush, and it stops. Some plugs give you directions on the box, 1/2 to 3/4 turn after washer contacts head. Of course, things were different before I did it for a living. I would definitely recommend one to more inexperienced DIY's.
    Veteran Member Three Rings szinkuti's Avatar
    Oct 06 2008
    Allroad Truck aka Uber UTE
    Grand Prairie, Texas
    have replaced thousands of plugs....all vw/audi and have never used a torque wrench.....you get the "feeling" for it.....but for someone who is not familiar i would highly recommend a torque wrench.....
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    I don't see why you wouldn't use a torque wrench if the manufacturer gives you specifications? Laziness? I mean, you have to use SOME kind of wrench, why not the one that gives you the most piece of mind?
    Feb 18 2007
    Las Vegas, NV
    So mixed answers. But, it seems as though the majority of people do not use a wrench. So, for those folks and for me, if the plug comes back out. Is there any risk I had of over torquing them? In other words, is there some unseen unnoticed damage that I might have caused?
    Veteran Member Three Rings handyvorb's Avatar
    Jan 31 2009
    '04 S4, '95 Eagle Talon MSnS
    Huntsville, AL
    Just a little interesting thing to think about, the most accurate method of tightening a bolt is by measuring degrees of rotation, not torque applied. This is why Audi head bolts and other very sensitive bolts have you use this method.
    As already mentioned NGK labels their box with amount of rotation to tighten the plug and not a torque.
    Anyone having to ask this question better be using a torque wrench, as this is one expensive engine to quickly f' up making a mistake here. The only people I've ever seen damage cylinder head threads tightening a spark plug are newbies however, still not worth the risk.
    Joel Baldridge
    Stage 4 Audi Technician (Master Guild Certified)
    I use a torque wrench on plugs, but i set it to 20ft pounds instead of 22ft pds. You have to be really careful when torquing spark plugs. The last thing you want to do is snap the head off a plug.
    Mar 01 2004
    Northern NJ
    Worst case is pulling the threads out of the head. But youd have to really go nuts on them.
    Feb 18 2007
    Las Vegas, NV
    Quote Originally Posted by Audi0s View Post
    Alright. So, next plug change, if all is well, then no damage done, right?
    Jan 31 2009
    Huntsville, AL
    If you can torque your new plugs to spec then all is well.
    Joel Baldridge
    Senior Member Two Rings Mr. Goodwood's Avatar
    Aug 23 2009
    Torque everything to spec.
    If you have torque wench why not use it. takes the guess work out.
    Sep 24 2007
    Chicago
    I know this is semantics and you meant torque wrench, but my previous point was that you have to use some kind of socket wrench to get down in there. If you have a torque wrench, why wouldn't you just pick that one up, set it to 22 lb's, and use that instead of a standard 3/8" socket wrench?
    You're talking about 15 more seconds of your life to adjust the wrench to whatever setting it needs to be on.
    Feb 18 2007
    Las Vegas, NV
    Quote Originally Posted by Lugi20 View Post
    At this point, it has been a case of not owning one. Not wanting to buy cheap things, I am holding out to get a nice torque wrench.
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    Q7 TDI | B6 S4 Avant MT | 84 Adventurewagen | 53 Ford Jubilee
    MI
    Quote Originally Posted by Mr. Goodwood View Post
    Because not everything that has a specific torque is easily accessible with a big ass torque wrench. Maybe the spark plugs aren't a good example but the control arms sure as hell are. The uppers call for a similar torque as the plugs but there is no way you're getting a torque wrench in there while the control arms are at curb weight.
    Once you start throwing extensions and universal joints in the mix, the torque you are applying to the wrench is not going to be the same as the torque applied to the threads.
    -justin
    Aug 14 2008
    Camp Pendleton, CA , Boston
    What would be a good torque wrench for sparks?
    Are these good any good?
    Craftsman Professional Torque Wrench, 3/8 in. Drive 15 to 75 ft./lbs.
    http://www.sears.com/shc/s/p_10153_1...orque+Wrenches
    SK 3/8" 50 ft.lb. Dial Torque Wrench
    Veteran Member Three Rings Speedymon's Avatar
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    Quote Originally Posted by joeycuccaro View Post
    Is this right? I thought the correct torque was much lower? Or at least measured in in/lbs
    Imola_Jon's supervisor...
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Quote Originally Posted by Speedymon View Post
    http://www.audizine.com/wiki/index.p...Specifications
    or
    30 newton meter = 22.126864418 pound foot
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Always use a torque wrench. I don't understand why this needs to be a poll. Audi doesn't specify torque specs for fun...
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Mar 01 2004
    Northern NJ
    Evil, either wrench will work, and both are decent wrenches. Unless you have an SK tool guy, Id just run down to sears and grab the Craftsman. Also, while storing it, turn the wrenchs torque settings all the way down, it will keep it accurate for longer.
    Aug 14 2008
    Audi0s: thanks bro. Sears dont even sell the one i link in store. I have to order it online. Just curious, how much can a sk tool guy hook up on tools.... like 20 percent off retail or something? Also!, whats your opinion on digital t-wrenches?
    this one sells around the same price as the sears clicker
    http://www.northerntool.com/webapp/w...5177_200365177
    Apr 24 2009
    Frisco, TX
    Avoid cheap ones. They're horribly inaccurate, fall out of calibration quickly, and just feel cheap. I prefer a non-digital one...less to break, easier to care for.
    Jan 31 2009
    Huntsville, AL
    Quote Originally Posted by dparm View Post
    I second this.
    The only digital torque wrench I would use is Snap-on (cost approx. $600).
    For the hobbyist Craftsman click type FTW. I have a Craftsman 3/8" click type for at home that shows both newton meters and ft. lbs, easy to read whole numbers. It cost like $89.
    Joel Baldridge
    Apr 24 2009
    Frisco, TX
    That's the exact one I use. :-)
    Aug 14 2008
    kool. the 80 dollar craftman's range is 25-250 ft-lb, tho. I just bought that one too and im about to return it to get the 0-50 ft-lb one...
    Mar 01 2004
    Northern NJ
    Haha tool guys rarely do good deals. Sometimes Snap On has "sales" but stuff is still really, really expensive. I guess Im a tool snob, I can never say no lol. That 1/2" electric impact guy kicks ass.
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    I always use a torque wrench when working with aluminum components. The "Professionals" who don't might not have noticed any problems, but the threads they weakened by over tightening usually fail eventually. Manuals have pages with Torque spec's for a reason, not just to waist paper.
    If you can afford it get two, a 0-50 and 25-250 then your covered
