Results 1 to 16 of 16
    Jul 08 2009
    Wisconsin
    How to pack scissor jack in trunk
    Well, used the frightening scissor jack in the trunk of my 2008 A4 to put some 18" Titanium wheels on my ride (they look great!). I got all the other tools back in the two plastic containers next to the spare except for the jack.
    Does anyone know or have pictures of how the darn little jack gets packed in the right side plastic box? It's the handle that is giving me fits and doesn't seem to fit. Thanks!
    p.s. has anyone used some of those slotted jack pads that fit on our A4 jacking space on the pinch weld?
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Re: How to pack scissor jack in trunk
    Throw it in the trash.
    First of all, it's called the widow maker for a reason.
    Second, you'll never get it back in there, trust me.
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    This is how I fit it. You have to press in on the cover a little to get it close behind the handle.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    I spent like 15 minutes trying to figure out how to get that bastard to fit!
    Finally, I just said f*ck it and tossed it in there without getting it packed away all nice.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Jul 08 2009
    Wisconsin
    Thanks all!
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    I slammed the handle next to the wheel and it worked..its the most annoying thing ever
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Jan 13 2009
    Jaguar XK, Galant VR4, Mitsubishi Starion, GMC Beau James, Yamaha 650 Turbo
    Pacific Northwest, USA
    peace
    Vince
    Current = 2007 Jaguar XK
    RIP Brilliant Red 2005.5 A4Q 2.0T, TIP. Premium, Lighting, Shade, Cold weather, and Audio packages.
    Mods: Shift Paddles added, Enkie PF01, Eibach Pro, Koni FSD, H&R 20mm Sway, USP Stainless brake lines, Tint, APR stage 1, K&N, Stern Adjustables.
    MP3 is the McDonnalds equivalent of music. Both have their place, but neither cater to quality.
    Senior Member Two Rings Big Nodge's Avatar
    Aug 12 2009
    New Hampshire
    nice, glad i'm not the only one who struggled with that fing thing. i hate that jack.
    Veteran Member Three Rings NERO Quattro's Avatar
    May 28 2009
    Brilliant Black B7 A4 2TQ
    Quote Originally Posted by Big Nodge View Post
    ^^X2 ha ha I almost threw mine away! but I did get it in....... the closet.
    Senior Member Two Rings Rosinbag's Avatar
    Jan 27 2009
    TX
    OMG...that b@stard makes the Rubix Cube seem like tic-tac-toe....hate that thing...
    The Rosinbag
    '13 All Road P+
    Sep 20 2013
    I did it!!!
    This picture is a bit misleading unless the case is different than mine. There was no way that I could close the case with the jack in this position because the handle is sticking outside of the case.
    The position of the Jack in the picture is correct, but the position of the handle is not.
    The trick (which I saw somewhere else on this thread) is to position the handle in the back of the case (not the front as pictured). The black part of the handle should be touching the back of the Jack. Next... add 10 minutes of screwing around with it until it finally pops in. It is a very tight fit. Once I got it in, I was able to put the top of the case back on and it fit.
    Sep 20 2013
    [IMG][/QUOTE][/IMG]
    This picture is incorrect. The position of the jack itself is correct, but the handle needs to be in the back, not the front has this picture shows. The black knob of the handle should be positioned so that it is touching the back of the jack (no force should be necessary).
    Veteran Member Three Rings kloeb2's Avatar
    Oct 14 2011
    2007 A4, 2024 S4
    Chicago
    Haha I've struggled with this fuckin widow maker for so long too. Thanks for the pics :)
    Kevin
    07 6MT B7
    GTX2863R
    Maestro
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Two things....
    1. This post is crazy old and it makes me laugh.
    2. Least the person searched for the info they needed.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Three Rings Stea1th's Avatar
    Aug 25 2009
    New York
    worst thing i ever did was open that thing...i still can't close it.
    Mar 24 2013
    Oakdale, CT
    Been there, done that. It took me about an hour to figure out how to put the damn thing back.
    -Adam
