I've had this issue ever since I put in my new fuel filter in. At a constant throttle input in just about every gear gear my car bucks and hesitates sporaticly at about the 2-3 mile mark (same spot EVERYDAY) from cold startup. It loses power and regains it quickly, it cannot keep a smooth crusing speed and it lasts for about 15 seconds or so and it won't do it again until the next 'cold' start. I was thinking about a failing fuel pump that sporatically stops delivering fuel and causing this loss in power, but has perfect A/F in logs. Maybe Maf? I'm dumbfounded right now.
some other symptoms and helpful info:
-only happens once after a cold start at about 5 minutes into the initial drive
-at constant throttle, the car will feel like its accelerating on its own just enough to cause the vacuum to fluctuate from 10mmhg to about 6mmhg and then decel
-the only engine code I am getting is an implausible signal and lower limit exceeded for the MAP sensor. (replaced)
-took it to eurocode and that was no help....
Any thoughts?
