Results 1 to 32 of 32
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Hood Latch Release Cable Broken - How to open hood?
    So ive been reading people's threads via the search and google, but I am wondering if anyone can give me a definite answer...
    Hood Latch cable on my B5 S4 broke, and I need to open my hood to add some oil and coolant. I have tried going from underneath with a long extension and flashlight, but the latch is not budging and I cant get enough leverage. Some threads say you can pop of the grill and do it that way.
    Is this true? I just bought my OEM RS4 grill and don't particularly want to bust the tabs on it just to find out it didn't help.
    Thanks.
    EDIT: Read below for solution, best way is to go at the latch from underneath with a 2 foot long socket extension or something along those lines. Move it from passenger side to driverside.
    The Best Things in Life Are Free... Or Heavily Discounted!
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Re: Hood Latch Release Cable Broken - How to open hood?
    I guess you can do it that way, but if you want to be safe, you can remove the front bumper, then loosen the radiator and see if you can manipulate the hood latch release then, its a PITA, but its safer than popping off the grill and sticking a screw driver in to try and unlock the release..
    Only safe course of action I can think of at the moment.
    Hope this helps. Good luck.
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
    Mar 22 2009
    Norcal
    Quote Originally Posted by NYEuroTuner View Post
    I read of someone removing the front bumper, but then another person said that didn't really help in the end. Sounds like its worth a try. Hopefully I can fashion a new cable too... as I imagine the dealership wants some ridiculous price for it.
    Oct 24 2008
    Quote Originally Posted by Raacerx View Post
    Well check your local junkyard, you never know what you may find. I would assume a hood cable from an B5 A4 would also work. Check n see if you can find either an s4 or a4 in the junk yard..
    But as far as getting your hood open, removing the front bumper & loosening your radiator is the only option I can think of that would work.
    Also, check the CA regional section here on audizine and see if any s4 owners have any spare parts they could sell you...
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Mar 22 2009
    Norcal
    PHEW!!! After 3 hours, I finally got it. I was able to safely remove my RS4 grill, and got 2 of the 3 10mm bolts that hold the last to the hood... however the 3rd was absolutely impossible. I then borrowed a jack (dont have mine) and was able ot get underneath and after another hour, I was finally able to pop the hood release from below.
    FROM BELOW IS THE WAY TO DO IT. I could have probably done it in about 5-10 minutes if I had the right setup and an understanding of the situation. The latch mechanism has to move from passenger to driverside, doesnt take much force.
    Cable is in tact... it had fallen off the latch.
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Good to hear. I was in a similar predicament as you last weekend. Luckily, my headlight was out, so I just pushed it through there, real quick.
    But the sad part, It took me most the day to realize it. Sad.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Oct 24 2008
    Nice!!!!!
    Glad to hear it all worked out.!
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    this happened to me the other week i unbolted the bumper and loostened the t45s all 4
    then i pushed the rad foward n held it so i had enough room to get my hand up in their after cursing and cutting my arm i positioned the cable back in place and pulled the latch!
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    wish i would have seen this earlier, This happened to me bout a month ago, took me about 15 minutes to get it, stuck a wire hanger up there with a loop at the end (wrapped around the wire so it woudlnt pull loose) Found the hinge, placed it on there, pulled the wire towards the driver side and i was good to go.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Mar 22 2009
    Norcal
    yeah, I really wish I would have just tried to move the latch from beneath in the first place, but I only had my emergency jack. Its a very small space to work with, but I could have saved a lot of frustration. Plus I bent my hood a little getting angry, LOL!
    I am going to snap a picture if I can of the latch from under the car, for future peoples problems, cause I couldn't find a diagram online and most threads I saw just suggested I remove the bumper or pull a headlight out. I didn't want to remove my bumper cause its partially ziptied and my headlamps are completely ziptied in since all tabs are broken.
    Veteran Member Three Rings 2kblacks4's Avatar
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    I am working on mine now where do i press? here is a pic of what i am looking at.
    4:11 posi track out back, 750 double pumper, edelbrock intakes, bored over 30, 11 to 1 pop up pistons, turbo jet 390 horse power, where talking some fucking muscle!!
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    I know your spouse to come in from the passenger side and push on something but dont know what.
    Mar 22 2009
    Norcal
    Quote Originally Posted by 2kblacks4 View Post
    go from underneath with the 2+ foot socket extension with a socket on the end for a sharp edge. I went from the passengerside of the snub mount, up between the radiator and fan, and then that silver piece in your picture will move to the driverside. I had to wedge a flashlight in there and use both hands. if you imagine that the cable has to pull on something, you are just going to push sideways on that thing.
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    Are you referring to this tab? it looks like the wire has popped out of the hold. Yes i am trying to come from the other side of the snub mount as well i am using a 2ft re-bar poll. Will i have to push the thing with the ball back in?
    Mar 22 2009
    Norcal
    its hard ot tell from your picture, but essentially, that plastic piece attaches to a piece of metal that does not move, then the ball with the cable pulls a seperate lever. You need to push the lever where the ball would go. You should be able to see it with a flashlight; it is a thin piece of metal with a slot cut out of it for the cable to slide up through. It should be easily without much effort.
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    Sweet just got it. Thanks for the help.
    Might try to make a write up for people in the future.
    Established Member Two Rings resiew's Avatar
    Apr 01 2010
    S4 2001.5 6spd
    qc
    Very usefull thread. I was able to do it but had to check on another car first.
    Mar 22 2009
    Norcal
    I ended up having to do that procedure like 6 times before I ziptied the cable so it wouldn't pop off...
    Glad my frustration is still helping folks, lol.
    Veteran Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    NYC auditioning.
    I got my last bolt with a small wrench lol it is difficult for sure!
    Established Member Two Rings B Dot's Avatar
    May 03 2013
    DFW
    I just broke my hood release hatch (I suspect it needed to be lubed and I used too much force to attempt to open it) and need to get under my hood to change my hid bulbs... Does anyone have the pics of this thread by a chance? I have a lift at my disposal and would like to fix this handle issue this weekend. I still have the broken handle and was wondering if I need to source another one? Or would a properly lubed latch still pop with a glued handle.. Thanks in advance!
    Veteran Member Three Rings tosh2.7's Avatar
    Sep 12 2009
    Nogaro stg 3- 00' S4(dead but being rebuilt), Silver stg 3 00 S4 GF 2010 civic
    new york
    you can simple get it from underneath. Remove the belly shield and look up you'll see the latch hinge.
    Vast tested. Driver approved
    BUY my BBS REs
    tosh2_7 on instagram: Get at me
    -RAY-
    Apr 07 2012
    PA
    Guess now its my turn... my boss had to be the nice guy and closed my hood
    Sep 29 2007
    02 S4 /07 S4 / 11 Q5 / 16 S3
    Clarkston, MI
    I screwed around with mine tonight and had no luck doing this :(
    Does anyone have pics of this ? I can see the cable but i cant see anything to pull on
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    I replied in your other thread.
    Its easiest on a lift, but I'm sure it can be done on jackstands.
    Slide under the car, look up, you'll see the hood latch. Get a big screw driver or crowbar, find the tab on your hood latch and push to the left(left if you under the car right if your looking at it)
    Hood will pop.
    EDIT: Just re read this thread, there are better descriptions on how to get it. If you still can't I suggest selling your S4. 5 minutes top.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Veteran Member Three Rings gear_head81's Avatar
    Apr 08 2008
    empty for now
    Lexington, KY
    I got an extra cable and latch assembly if you brake your.
    Sent from my iPhone using Tapatalk - now Free
    A.R.M. Member - Military 4 Rings Member (Veteran)
    Mar 09 2013
    Saraosta/Florida
    Had this happen. Had a buddy do timing belt for me and when I went to pick the car up he was all proud to show me.... Then we tried to open the hood. The cable wasn't broken but had slipped out of its housing. We then spent the next 2 hours fighting it (and waiting for the engine to cool down, he had just taken it on a decent sized test drive)
    Jan 31 2008
    2 hours? How were you trying to go at it. I threw it up on a lift and pushed over the lever with a giant crowbar in 5 minutes. First 3 minutes were how I was going to attack it.
    Tekkie-It really is simple, just look up until you see the latch(flash light is a nice feature here) Once you see it just play around up there with a crowbar pushing from passenger to driver side. It should pop fairly easy.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If you are in a hurry...
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Necro bump on this thread. However there is an easy way to do it. The Grille is only held on by clips. Gently pry it loose and you'll have access to the two torx bolts that hold the striker assembly on. Get them out and the hood opens. This is on a B6 S4 (or A4).
    I had to do it tonight after I had put the car into service position and the cable fell out of the latch assembly.
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    Quote Originally Posted by ZimbutheMonkey View Post
    doesn't at all count. the B5 s4 grill is held in but V shaped tabs all around the grill that will break if you just pull it out
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Dude bumped a 6 yr old thread to give info about a b6. Shame!
    Jul 15 2015
    Rochester NY
    A6 C4 (1995) - same latch arrangement as the B5 - drove it up on ramps so 12" higher, removed belly pan, slid my arm up between the front crank pulley and the A/C hose, grabbed hold of the cable ( two tabs holding the cable back against the lock broke) and pulled one way for one latch, and then the other way for the other latch. Total - about two minutes. I closed the hood on a bottle cap and pulling the hood release was too much for the 26 year old plastic tabs.... will replace with some stainless tabs
