Results 1 to 26 of 26
    Registered Member Two Rings
    Apr 14 2009
    Hacienda Heights, CA
    Question hand brake light flashing?!?!?
    sometimes randomly my hand brake light flashes beeps on the dashboard for just a few seconds then goes away
    does anyone know what these means?
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    Re: hand brake light flashing?!?!?
    your handbrake isn't completely down. something may be blocking it or the wire attached to the e-brake might be grounding itself due to it being stripped or pinched.
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    is it during hard acceleration? could be the belt slipping on the alternator.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Oct 15 2006
    From a few to one...
    Arlington, VA
    or you could be low on brake fluid. mine did that after i switched to b5 s4 fronts.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Apr 14 2009
    Quote Originally Posted by FORCE_FED_DUB View Post
    hmm i havent noticed if it was during hard acceleration but ill look out for it next time
    Apr 14 2009
    Quote Originally Posted by Jay B7 View Post
    how would i check?
    Oct 03 2007
    New York
    Quote Originally Posted by NyteEscape View Post
    *ding* or your sensor is going out in your brake reservoir.
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    It's your brake fluid. I had this problem for months, just recently figured it out.
    Apr 14 2009
    ok cool ill check it....any recomendations on what brake fluid to buy?
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by sunny.s. View Post
    when i first did my brakes, i just bought some from the dealership. kinda needed it in a hurry cuz i was freaking out about the light.
    after that, i flushed the system with motul rbf600.
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    Wow....the brake fluid is low....top it off with OEM fluid. This also means that the brake pads are low. Check the pads
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by spyder101 View Post
    if the pads are low, there is a specific warning that shows up in the DIS. i believe it looks like this:
    (O)
    or something along those lines.
    Jan 25 2009
    (O)
    I know there is a Brake pad warning indicator but, when brake fluid gets low, it will also trip the "brake" light because as the pads wear down, the piston on the caliper opens which allows for more fluid to travel in the brake lines. This interns to the fluid emptying out from the reservoir and thus tripping the low fluid sensor.
    Oct 15 2006
    Arlington, VA
    ahhh, i see. good call.
    Apr 14 2009
    yeah i kno my brake pad indicator hasnt come on yet but i believe i will be needing new pads soon cuz sometimes i hear the squeak when i stop
    but i will definitely top off my brake fluid
    thanks
    Apr 14 2009
    ok i got some new tires so i checked out my pads when the tires were off the car and my brake pads are fine
    there was a leak above the passenger from tire by the tie rod tho
    could that be a brake line? i do have a leak from my power steering rack so it could be that too
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    If you had a brake fluid lead you'll notice on the braking power and pedal feel as the brake system works under hight pressure. It might be your power steering rack, check all your fluids frequently and top them off as you need, also you might want to identify your leaks and try to repair them/replace the parts.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    low brake fluid doesnt mean low pads. Its a mineral based fluid and at times will evaporate.
    Gcc's blacksheep
    May 19 2009
    Alabama
    I think any DOT4 Fluid will work
    Gcc's blacksheep
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Blinker fluid is low. Add asap.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Quote Originally Posted by Tgr_Clw View Post
    ^ x2...
    Apr 14 2009
    whats the blinker fluid? location?
    May 08 2008
    SF Bay Area
    ohh that brake light. hahaha
    Jan 22 2009
    Culver City, CA
    Sorry to resurrect this from 2009 but when I jumped onto the freeway tonight I got a flashing brake on the dash and four beeps. And I just had the serp belt changed. The parking brake was not applied.
    Since I stabbed the gas I'd call it hard acceleration. But I've never before seen the brake sign or heard any beeps. My brake fluid appears to be fine. Why would the serp belt slip at all since it's brand new - and if it did, why would that trigger the brake light on the dash?
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    i don't know if this is the cause of your problem, but i'll add this to the thread for future search's sake. The fluid reservoir's filter could be pushed down too low. What do i mean? Open your brake fluid reservoir. You see a little filter at the top with a lip on it. That lip should be flush with the top of the reservoir. however, when filling fluid in and using a funnel, it's easy to push the filter down a bit. This pushes down the float which is attached to the sensor, trigerring the flashing BRAKE light thinking that the level of the fluid is too low. Happened to me the first time i did a brake bleed. Took forever to figure out the problem. all you need to do is to carefully pull it up using something like needle nose pliers.
    This doesn't sound like your problem Matt, but like i said, in case anybody else runs into this and cant figure it out...
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    do you know of a DIY on this? im not sure if i need to remove my flux capacator to get to the resevoir
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
