Results 1 to 8 of 8
    Veteran Member Four Rings Nght&Day-B8's Avatar
    Aug 05 2009
    Miami, Fl
    5x112 bolt pattern to 5x120?
    Heard today from someone who works for a reputable company down here in miami (German Motoring) that BBS has CH-Rs in 19" for a BMW bolt pattern. I doubted him so hes going to look it up tomorrow and let me know if its for sure. But the bolt patterns are different, is there anything i can do about this? Anything that goes on like a spacer but with a different bolt pattern?
    May 16 2009
    Maine aka Canada Jr.
    Re: 5x112 bolt pattern to 5x120?
    yep its called a hub adapter... and I thought BMW was 5x114.3?
    Aug 05 2009
    Miami, Fl
    i actually thought it was 5x100 but they said 5x120
    Mar 02 2007
    Fresno, CA
    Adapters will only work if the offset is high enough.
    Veteran Member Two Rings latte's Avatar
    Aug 09 2004
    2008 A4 Avant 2.0T, 2014 Honda Odyssey
    San Diego
    BMW is 5x120. Where would one gets these hub adapters, I'm a BMW owner and want to get a 2010 A4 Avant.. would be great if I was able to keep my HRE's and put them on the avant?
    Aug 10 2009
    what is the bolt pattern for the A4 B8?
    Aug 10 2009
    5x112 im guessing?
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    the adapter comes in all configs. but you need 20mm minimum to use one. so if your et is 60....then with adapter you get 40. porche cayene 20x9 et60s with adapter become 20x9 et40....perfect for a b8 a4.
    very few rims have 60et though
