Results 1 to 10 of 10
    Senior Member Two Rings ecbo0m's Avatar
    Aug 07 2009
    05 S4 Avant
    Dash air vent removal?
    The pieces for my left center air vent snapped, so I can't adjust the direction of airflow. Anyone know how to remove this vent, and where I can find a replacement? Thanks.
    Established Member Two Rings skian's Avatar
    Jun 08 2009
    2004 A4 Quattro 6spd
    Re: Dash air vent removal?
    Perfect op to install the awe boost gauge
    B6 A4 // APR stg2+ // Carbino CAI // Milltek Catback // Milltek DV // SB OFE SS Stage 4 and LWFW // RS4 rear sway bar // A.W.E. boost guage
    Aug 07 2009
    05 S4 Avant
    Quote Originally Posted by skian View Post
    Meh. Will i lose an air vent installing that guage? It'll be pretty damn hot on the drivers side...
    Plus, my A4 is completely stock... do I even need a boost gauge?
    Senior Member Two Rings ahaters46's Avatar
    Sep 03 2008
    99.5 1.8tqms
    dover new hampshire
    Quote Originally Posted by ecbo0m View Post
    bummer
    silver b5 on h&r coils
    Jun 08 2009
    It reduces some of the air flow, but doesn't block it.
    If your stock you don't really need it, but it will indicate if you have a boost/vacuum leak. Plus it helps to "learn" your turbo, so that your always in the optimum power range.
    Established Member Two Rings Ryan.'s Avatar
    Mar 08 2009
    '02 A4 3.0 6-Speed
    Roswell, GA
    And it will look way cooler than a broken vent
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    The vent just pulls out without taking off any screws, etc. Wrap a cloth around a flat-head screwdriver and pry it out. All louvers etc comes off easily and is easily reversible.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Apr 12 2007
    Milwaukee
    my vent is loose and i think the boost gauge is better than new vents
    Registered Member Two Rings
    Apr 11 2009
    MN
    I would recommend the CIM vent pod setup. Much better setup for the price!
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    ^^ Absolutely CIM FTW!!
    And i vote go boost gauge as well, it looks a heluva lot better than a vent!
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
