Results 1 to 11 of 11
    Veteran Member Four Rings fanuvbrak's Avatar
    Sep 22 2004
    1999 Audi A4 1.8TQT
    Philadelphia, PA
    Windshield Washer Reservoir
    Yesterday, my washer fluid was barely squirting, so i filled it up last night. i was surprised that it took an entire gallon. i came out later and saw a decent puddle of washer fluid beneath the car. i made sure that all the hoses were on and checked the reservoir for cracks, but everything seems okay. i didn't spill any fluid, but there was probably a quart on the floor.
    i'm thinking the reservoir is cracked and i just don't see it. is this available as after market? i'm thinking the dealer will want a ton of money for this.
    btw, it's a 99 A41.8T tip with 69,000 miles on it.
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    around 50 bucks to replace from dealer.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    It might be ok...I panicked when I saw washer fluid on the ground when I first got my car...turns out when the headlightwashers kick on it gets washer fluid behind the bumper and then it drips on the ground.
    Otherwise if it's more serious than that it's common for the lower washer pump to crack and leak....but if that was the problem more than likely your feet would have been wet from trying to fill the washer reservoir.
    FYI my washer reservoir take close to 2 gallons....but I know some of the newer cars have a much smaller reservoir but I'm not sure what year they changed them.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Dec 07 2004
    Jersey City, NJ
    Mine is leaking again now. Dealer charged me $75 to replace it a year and half ago. Damn 1 year warranty past.
    Registered Member Two Rings jam101's Avatar
    Sep 05 2004
    Houston
    Yeah i had to change my headlight washed pump and patch a hole in the tank, so look and see if the headlight washer is gone
    http://tinypic.com/pnksg
    A6 Shocks gone now... bilsteins all round
    Mar 17 2004
    01 A4 1.8T
    Vancouver
    apparently the leaky pump is a common problem. I just had mine replaced about a month ago. The guy who replaced it for me said that there had been a couple of cars coming in with the same problem.
    oh btw, I have a 2001.5
    Veteran Member Four Rings Audi_Sniper's Avatar
    01 & 04 Audi A4 1.8t quattro
    Buffalo, New York
    My washer pump for the headlights blew up on me yesterday. You should see the thing it has a huge crack down the middle of it....
    Got the new one on order and it should be around $45 for all the parts I need.
    One thing after another with this POS..
    I'm 2001.5
    Bringing the Great Lakes Regions Together
    http://www.greatlakeseuros.com
    BetaAlphaTau Member # 30
    The toys:
    01 Audi A4 quattro APR stage III (Fast and tight like some of your little sisters)
    04 Audi A4 quattro (Der neue tägliche Treiber)
    Veteran Member Two Rings KMHPaladin's Avatar
    Dec 12 2004
    North Jersey
    there's a tech article on Audiworld that details removing the reservoir and replacing the faulty pump. It's under the S4 section. It should enable you to fix either a cracked reservoir or broken pump.
    Current: 2016 S3 Sepang Blue | 2006 Lotus Exige Storm Titanium
    Previous : 2006 A4 2.0tqm Quartz Gray | 1997 A4 2.8qm Europa Blue
    Sep 05 2004
    Houston
    I got my washer pump for like $15 from a VW specialist
    GTA, Canada
    I'm hoping mine is alright, seemed to work yesterday. The other day when the temp dropped like crazy I drove away and there was a huge pile of washer fluid in the snow on my driveway.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Dec 06 2004
    Honolulu, Hawaii
    I have one off of a '97 i can sell for $20 + shipping... Motor included. email me for pics at [email protected].
