Results 1 to 34 of 34
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Loud whistle/whining noise from front of motor. 34k
    belt tensioner? It's like a supercharger whine.. Very loud and has gotten a lot worse in the past 5k miles. Or alternator whine? What do you guys think?
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    Re: Loud whistle/whining noise from front of motor. 34k
    Hmmm not a 100% diagnosis but maybe power steering?
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Yeah, it could be a lot of things. Changes with RPM "like a supercharger," I assume?
    Veteran Member Four Rings mad70sx's Avatar
    Mar 12 2009
    Silver '04 S4
    North Central CT
    Low on power steering fluid?
    I have the same noise,possibly. Can you pinpoint where in front the noise is coming from? I hear mine the loudest if I put my ear right in front of the passenger side headlight. Dealership said I might be low on power steering fluid,which it wasn't. When I had them look at it,they of course said it was normal. It sounds like the serpentine belt or tensioner to me. I will be replacing the belt some time soon and hopefully the noise will go away.
    Funny you mentioned it sounds like its supercharged. Mine is so loud I actually had a dude pull up beside me asking if it was. I was tempted to lie.
    JHM Tune ~ JHM Intake Manifold ~ JHM Version 2 Headers ~ FI/JHM 2.5" Exhaust ~ JHM 40/60 Rear Diff ~ JHM LSD Rear Diff ~ KW V3 Coilovers ~ Porsche 18Z calipers ~ BBS CH
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    One way to diangnose is to remove the belt to see if the whine goes away. (Remove belt, start car & lsiten). Sucks to do that much work but it will answer your question. Unless it is a bearing slowly going bad (if it's an idler pulley, harmonic balancer etc, you'll know from removing the belt as well. )
    I had this issue with one of my previous cars (2001 E55). Thought it was the belt...it was actually my cams! Not the bearings either, the lobes had developed weird grooves on them (no cllue how, no debris was found anywhere in the engine) and the whine got pregressivly worse. I had them swapped out and the whine was gone. Was an expensive fix for me at the time...since i was out of warranty.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Senior Member Two Rings BLK_A4's Avatar
    Dec 22 2008
    Fox River Grove, IL
    Just tell people you have a supper charger.... But my guess would be belt tensoner. Dose it squeal while idile?
    Mar 11 2008
    Pierceton, Indiana
    Quote Originally Posted by BLK_A4 View Post
    I know what squeals sound like, but it sounds more like a rrrr at idle with a slight whistle and then when revved its a LOUD whistle.
    Its def not power steering bc i know what that sounds like. and it doesnt sound like a classic SQUEEEEEEL belt tensioner going like on other cars that ive dealt with.. its simply a whine/whistle like a s/c... and it deff sounds like it has an s/c.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    accidental PES install?
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    My alt belt tensioner whistles like that only on cold start, with temps below 50. Most likely that, simple fix if youre inclined.
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Belt tensioner is my guess
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    I'm having the exact same problem and have had it in twice. From googling the crap out of it most people say their serpentine belt was the fix.
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Quote Originally Posted by sakimano View Post
    Ha Ha... that is funny.
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    Jan 24 2008
    West Coast
    You can hear it outside specifically? Or is it inside only that you're hearing it? That makes a bit of difference. If you are hearing it inside, not out, I'd say more of an electrical issue, otherwise hit up the belt and see if that's the trick.
    Moderator
    Senior Member Three Rings Philosophyy's Avatar
    Apr 21 2009
    2008 Sprint Blue S4
    Long Island/ ASU Tempe
    Whistle Tips?
    Whooo Whoooo
    Sep 10 2009
    SC
    I recently replaced my serpentine belt on my 04 S4, 47K Miles. I have been hearing the whine intermittently as well. My guess would be belt/tensioner. BUT, I wouldnt say it was a bad belt b/c mine is brand new. Maybe I misadjusted the tensioner ...??
    Senior Member Two Rings KrunkMan's Avatar
    Jul 26 2009
    Minneapolis
    Quote Originally Posted by Philosophyy View Post
    Whistle Tips?
    Whooo Whoooo
    It's only in da monin
    Veteran Member Four Rings rlarsen462's Avatar
    Jul 07 2009
    Varies
    LMFAO Bubb Rubb.
    Veteran Member Three Rings jsquillz22's Avatar
    Feb 22 2009
    b5 s4
    Chicago
    that was my guess
    OEM+
    Who Cares?
    Belt Tensioner. I have come across a few of these that needed replaced on a couple of S4's.
    Oct 11 2007
    Suburbia
    lol
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Established Member Two Rings avant1's Avatar
    Jun 20 2009
    97gtivr6T, 97jettavr6,95jettavr6,95cabrio
    New Jersey
    had the same problem. started with a cool supercharger whine noise. till one day my alternator light came on! looked in the engine bay and my serpentine belt was shredded.
    took the fornt end apart to replace the belt and found out that the idler pulley seized and melted the plastic roller. the only thing that was left was the seized bearing.
    goodluck!
    Established Member Two Rings Bfiver's Avatar
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    I wonder if you could check this out by spraying some lubricant on the pully or the tensioner or even the belt ?? I also have this ghost supercharger!
    C-Lo
    Senior Member Three Rings Sunny4's Avatar
    Aug 01 2008
    Mt. Prospect, IL....CHICAGO
    I went out of town for thanks giving weekend and came back to start my car this morning. Be it, I live in Chicago and it finally got to like 35 degree's. I had this S/C whining noise this morning...it went away after the car warmed up. I wonder if its the belt tensioner? First time hearing this too.
    Apr 29 2008
    2001 audi a4 1.8t
    CENTRAL~NY
    yea i live in central new york and i havnt really heard this until the temps started to drop
    C-Lo
    Jan 14 2009
    Audi's
    http://www.youtube.com/watch?v=Nnzw_i4YmKk
    whooooooooooo woooooooooooo
    Jan 14 2009
    Audi's
    Quote Originally Posted by Bfiver View Post
    Where you live????
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    only in da moanin....LOL
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    LOL
    +1 rep for the lols!!!!!!!
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    you're supposed to be up anyways cookin breakfast
    my guess is a seized belt tensioner. take a gander at your serp belt. my old 3.0 seized, wined, then later broke on me.
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Power steering fluid. If it is low it would cause the whine, especially on start up and turning at low speeds. Just something to check.
    Veteran Member Three Rings manhattanprjkt8's Avatar
    Jun 22 2008
    Lots of blown out mounain bikes
    pennsyltucky
    its the serp belt and pulley, i had a similar issue ended in a snapped belt and smoke flying all over the place...
    it's not a terrible thing to fix, about $400 parts and labor (with new pulley)
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    Spraying stuff on the belt/pully/tensioner is not a good idea.
    Senior Member Three Rings MonkeyBiz's Avatar
    Feb 27 2009
    Nashua, NH
    Quote Originally Posted by nimski62 View Post
    Tea pot mod...gotta be. 100%...
    2004 B6 S4 6-Speed MT - Black w/Alcantara
    | ~ JHM ~ Magnaflow ~ Hotchkis ~ Hawk ~ Hankook ~ Hartmann ~ more to come...|
    Established Member Two Rings timeboy's Avatar
    Jul 12 2008
    B8 A4, X5 4.4i, B7 S4
    South Bend/ IN
    Quote Originally Posted by Sunny4 View Post
    I have the exact same issue..
