Originally Posted by
iaonbb
Everyone on this board should just start PM'ing you since you ALWAYS the answers..you're the man! I'm running out of creative ways to thank you bro ;)
Out to deflate now....pssssss.....
I don't know everything, but definitely like to share info when I can. It's my pleasure.
ItsDubC
My tires feel a little bit like they need to get filled, though my TPMS sensor hasn't come on yet. I noticed that the cap has an N on it. What is everyone's thoughts on filling tires with nitrogen? Is it worth it?
The way it was explained to me, Nitrogen can only be truly effective if the tires are FULLY inflated with it. Since there is already a decent amount of air in the tires before they are inflated with nitrogen, your pressures will still fluctuate pretty close to normal with temperature. I've seen plenty of so-called independent tests that indicate no real long term benefit from using nitrogen, but never actually tried it myself since I check my pressure regularly and have an air compressor at home. It wouldn't make sense to top nitrogen filled tires with "regular air."
