Does anyone in this fucking thread know what grammar and punctuation are? Jesus...
Either A) Your valve is installed incorrectly (it's a pretty easy mistake to make, I did it myself)
Or B) It's a bad valve. Call or e-mail Forge, explain the situation, and ask if they can replace it for you (9 times out of 10 they will). Their customer service is great.
Make sure the BOV and DV ports aren't mixed up. Remove the horn and the DV flange. Reinstall them to match the picture in the instructions. You could also switch it to full DV and see if that helps your problem.
I know you said you used the Forge instructions, but just double check it. The valve should be upright, with the bottom port going to your charge pipe and the side DV port going back to your TIP. The top vacuum line should obviously go into some sort of vacuum source like your intake manifold. Start at around 20 clicks and adjust from there, monitoring with VAG-COM and boost gauge, and see how it changes. If it keeps dying you might have some sort of boost/vacuum leak or something like that.
