Results 1 to 19 of 19
    Active Member Two Rings STaSiSnRI's Avatar
    Oct 30 2007
    2019%20Audi%20SQ5
    Southeastern MA
    Digital Speedometer
    Is there any way to have the "DIS" Drivers information display show a digital Speedo like the Audi A3 and TT and 2008 and forward A6's do??? I believe that the Later years of the B7 A4's have this with certain packages... I have an "06 A4 Avant with Lighting package and the digital Speedo would be a great addition to the color display...
    thank you in advance
    Barry
    Senior Member Two Rings CharlesP2009's Avatar
    Sep 22 2012
    2009 Audi A4, 2009 BMW 335i Convertible
    The Copper State
    Ancient thread bump: I'm hoping someone out there knows how to enable a digital speedometer on our lowly Premium package A4's. I discovered today that the analog speedometer is 3-4mph off and it's driving me insane! Constantly resetting the average speed display helped me confirm my speedo was off, and since the car is able to figure out a more accurate speed digitally I'd really, REALLY like a digital speedo like our newer and more expensive brethren!
    Jan 24 2012
    Connecticut
    You can get the P3 cars vent gauge and switch it to speedo.
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    torque has speedo and you can use it as a hud
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
    Veteran Member Four Rings jrtrainor's Avatar
    May 07 2011
    94 yj 88 bronco 15 fusion
    The mountains, CO
    Digital Speedometer
    I want to just replace the gauge cluster with a newer one that enables such features the difficulty will be getting the car to work with it.
    Sent from my iPhone 5 using butt plug powers
    B7 A4, GTX2867R 8.3:1 CR 2.149L motor Build
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    "Call him the Redneck mechanic with the beard of glory"
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    Quote Originally Posted by jrtrainor View Post
    If you are trying that route, might as well get the RS4 cluster so you have have a laptimer and oil temp display.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    theres a way to get a digital speed readout on the radio, for some reason it still shows km/hr on US cars.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    May 07 2011
    The mountains, CO
    Digital Speedometer
    Rs4 has digital speed readout?
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    Quote Originally Posted by Jay-Bee View Post
    dafaq
    Registered Member Four Rings BoSNiaN's Avatar
    Jun 02 2011
    2012 Benz ML350, 2007 BMW 325xi, 2006 Audi A4 2.0T
    This. If you have a Symphony II+, you can just vag-com the radio to show your speed. Only displays it in KM/h but it is realiable appearently.
    2006 A4 2.0T 6 SPD MT // Dolphin Grey on Black // Sport + Premium Package // Quattro
    ==> Complete Mod List <==
    Jul 13 2011
    Huntington Beach, CA
    does this work with navigation?
    Aug 12 2010
    Bucks County, PA
    Not 100% sure, but you need the RS4 cluster in order to activate the laptimer and oil temp display. The byte's are there in VCDS, but you need the RS4 cluster to display.
    May 07 2011
    The mountains, CO
    Digital Speedometer
    Quote Originally Posted by J.Owen View Post
    Eh not worth the cluster hassle. This is my new solution.
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Man, I hate the digital speedometer option. I change it anytime I get a loaner. It reminds me of my '86 Cavalier Z24's speedo that would flash at me whenever I exceeded 85mph.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Aug 12 2010
    Bucks County, PA
    Quote Originally Posted by doughboy17 View Post
    ha, every time I get a loaner I make sure to set the speed warning to 35mph before I drop it back off.
    May 07 2011
    The mountains, CO
    Digital Speedometer
    Your evil and I'm gonna start doing that now.
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    I accidentally turned on the speed warning at 5mph in the RS4 on my way back from LA while stuck in traffic. Worst thing ever.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Jul 19 2011
    Northern Minneapolis, MN
    ha ha ha x2
    Sep 22 2012
    The Copper State
    My Audi dealer only gives me a Toyota Corolla for a loaner. I can't be evil and set a really low speed warning
