Results 1 to 8 of 8
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    Real deal on GL-4 and GL-5 gear oil
    Can somebody fill me in on the differences between gl4 and gl5 rated gear oil. I accidently put in gl5 75w90 mobil1 gear oil in my transmission. should i be worried and change it out right now or i will be fine runninging it? thanks
    2014 Audi S4 DSG
    Senior Member Two Rings Jman25's Avatar
    May 18 2009
    98 A4
    PDX
    Re: Real deal on GL-4 and GL-5 gear oil
    is your car manual? I put redline gl5 75/90 into my diffs front and back and the front shares the transmission so if youre running a manual then youre fine, dont know about if its an automatic since I dont have one.
    Sep 21 2006
    Lyons, IL
    yes im manual. ive heard that gl5 is thinner than gl4 and might wear out transmission faster
    2014 Audi S4 DSG
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    uhm im pretty sure thats just the rating, gl4 and gl5 75-90 should both have the same viscosity hence they share the same 75-90 weight rating
    like royal purple has a gl4 and gl5 rating: http://www.ecstuning.com/Audi-B5_A4-...sion/ES263484/
    from mobil 1 site: http://www.mobil.com/USA-English/Lub..._LS_75W-90.asp
    "Applications
    * Mobil 1 Synthetic Gear Lubricant LS 75W-90 is recommended for use in modern high performance automobiles like SUV's, Vans and Light duty trucks requiring API GL-5 and MT-1 level performance
    * Mobil 1 Synthetic gear Lubricant LS 75W-90 is intended for initial fill, topping-off or refilling differentials, final drives, transfer cases and other gear applications where lubricants meeting API Service GL-5 and multi-purpose or mild EP gear lubricants are recommended
    * Mobil 1 Synthetic Gear Lubricant LS 75W-90 can also be used in rear axles where API Service GL-4 lubricant is recommended
    * Not recommended for automatic, manual or semiautomatic transmissions for which engine oil or automatic transmission fluids are recommended
    * Where extended service intervals and warranties are required"
    direct from there site, look at bullet point number 3
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Dec 05 2007
    Property values are different and you should change to GL4 asap. The compound element eats at a part of the transmission (can not recall what part) if you place GL5 in there.
    Place GL4 in the tranny and GL5 in the rear diff.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Gl-5 oils contain more sulfur which eventually eats away at the brass syncros. Gl-4 is better formulated for the transmission. You don't have to go out immediately and change it out, but long term it would be a good idea to replace it with a Gl-4 gear oil. Gl-5 is fine for the differentials.
    Feb 22 2013
    wantagh, ny
    i changed my gear oil in my trans when i did the clutch. i put pennzoil gl5 75w-90 in. about a year later i have no second gear syncro and my center diff knocks like fuck when i turn. change it the fuck out now.
    Feb 22 2013
    wantagh, ny
    Quote Originally Posted by tttomdemaria View Post
    also, sorry to bring this shit back from the dead.
