Results 1 to 9 of 9
    Registered Member One Ring TheTidesOfWar's Avatar
    Aug 28 2009
    1997 Audi A6 2.8L Quattro
    Huntsville,Alabama
    Question A few questions about a 97 a6.
    I got my first car, a 1997 a6 quattro, not to long ago. I always wanted an Audi and finally found one I could afford. That being said its not in the greatest shape (good but not great), but I wanted to learn more about it and fix it myself. So here are my questions, hope you can help...
    1. The previous owner let the power steering pump go out on it, I already bought the pump and put it on and it works great, except when I turn I hear like a grunt sound if i turn to far, it also makes that noise when I brake sometimes and when I hit bumps sometimes. Could that be my shocks or what? Another thought I had was since there was no power steering fluid running through my car for so long maybe it messed something up, but I dont know what, or how to fix it.
    2. This hose was pieced together with larger fittings than its supposed to have and it wont let my engine cover snap in properly, I am going to replace it. What is this?
    3. No clue where this hooks up or what it does, its under all of my reservoirs.
    4. Last but not least, what is this where the rings are on the opposite side of the engine from the oil? I know its a filter of some type, but what?
    Sorry this is so long, all your help is much appreciated!
    Established Member Two Rings SPRX's Avatar
    Aug 11 2009
    A6 2.8 30v quattro AVANT
    Ireland
    Re: A few questions about a 97 a6.
    I can't see any pictures to have a go...
    Aug 28 2009
    Huntsville,Alabama
    Should be in my photo album. Links must be messed up sorry
    Active Member Four Rings kingofnyc's Avatar
    Jul 01 2007
    Queens, NY
    Quote Originally Posted by TheTidesOfWar View Post
    That wire looks like ether turn signal or for the foglight.
    The plastic hose coming from the valve cover was cracked and taped together. they brake all the time.
    I have a 96 A6 im rebuilding.
    Aug 28 2009
    Huntsville,Alabama
    So the wire you think goes to one of the back of the lights, what's the actual piece of hose called so I can try to track one down? Nobody knows about the grunting coming from around the wheels? Thanks everyone
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    It often takes quite a bit of time to get all of the air out of the power steering system after a pump replacement. Take the cap off of the power steering reservoir and slowly turn the steering wheel lock to lock several times and keep checking the fluid level. Otherwise, it's possible that the steering rack was damaged when the pump failed, but I'd check the fluid levels first.
    - Pat -
    2016 RS7
    -Previous-
    2013 S6 Prestige, 2010 A6 Prestige/Sport package, 2012 A4 Avant S/line, 1991 Coupe Quattro, E55 AMG, 2009 A4 Prestige, B5 S4 avant, B6 S4, C5 RS6, B6 S4 avant, 71 El Camino SS
    Aug 28 2009
    Huntsville,Alabama
    Alright, I'll give that a try tomorrow. Thanks for the help!
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    another big point is to use the correct fluid, audi uses mineral oil not atf fluid for steering, you can get it euro parts stores
    http://www.ecstuning.com/Audi-C4_A6-...teering/Fluid/
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Aug 28 2009
    Huntsville,Alabama
    Yeah I believe they used the incorrect fluid before, that's what messed up my pump. The dealership replaced my engine right after I bought it because the cam shaft locked up. They claimed I just had a leak, but it was the pump. Now I drained my reservoir and put in the mineral oil. The sound seems to come from around my front two tires. The power steering is working though. I tried to get any air out, but that didn't work. I don't know much about cars but I am trying to figure out what it may need in hopes of not spending a fortune in a shop diagnosing the problem, then having to buy the parts and fix it.
