Results 1 to 25 of 25
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    So which screws adjust the bumper and headlight position?
    So i was just thinking about which screws are actually used for adjusting certain parts of the bumper or headlight. I'm not talking about aiming, but rather the headlight itself. I want to fix my bumper so its aligned properly so thats why im posting here.
    I saw this pic that fly posted:
    Then there is the screws behind the fender liner.
    I have a non-sline bumper if that makes any difference with screws.
    Any tips?
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Re: So which screws adjust the bumper and headlight position?
    Dont know about the headlight but for bumber height/alingment you cannot see them until you take off the bumber. Or atleast loosen it up. They are black rubber looking things on either side above the crash bar.
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    You cant see either one from that picture. The headlight alignment screws are the big white ones and you'll see the bumper height adjusters after you take the bumper off.
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by 12sA4 View Post
    I know which ones are the bumper height adjustments.
    Which are the big white ones?
    Are they visible on that pic?
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Jul 10 2008
    Austin, TX
    It's the only pic I could find in a reasonable amount of time.
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Perfect. Now you can see both from the pic above.
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by Latin Audi View Post
    *duh* brain fart
    That pic is for aligning the actual headlight housing or aiming the headlights?
    I know how to aim them but im not sure if the housing itself has screws or w/e to keep it flush with the bumper, or do i just tigthen all the screws on the light with no worries ?
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Ive only taken my headlights off to bake them (3 screws) and I believe you just tighten them and the white screw 12sA4 pointed out is for leveling. Someone should chime in.
    Jul 10 2008
    Austin, TX
    Quote Originally Posted by Coderedpl View Post
    *duh* brain fart
    You can't adjust the height of the housing, only the headlight beam which is what that white screw is for.
    Established Member Two Rings Murre R's Avatar
    Sep 22 2008
    Sweden
    The fat blue ones are the headlight-housing alignment (in/out).
    The green ones adjusts the bumper.
    The big white ones ontop of the headlight-housing adjusts the lightbeam, sideways I think. Correct me if I'm wrong!
    Martin
    Phantom Black A4 Avant 2,0TQ -05 Prosport.
    Jul 10 2008
    Austin, TX
    I thought those ^^^ were just securing screws, but I could be wrong also. Bottom line, the white screws are the ones that adjust the headlight beam.
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Fly get your ass in here!
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    what type of screw driver is needed for adjusting the bumper.
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Is it not torx?
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by Murre R View Post
    What kind of adjustment to the bumper?
    I'm not worried about beam adjusting right now, just the bumper and the housing.
    Quote Originally Posted by bengtc View Post
    Torx T25 i believe.
    Look here:
    http://www.audizine.com/forum/showth...ght=diy+bumper
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Should be up and down.
    Jul 27 2007
    Orange County, NY
    Are those screws in anyway connected to the the black height adjusters that are seen when the bumper is off then?
    Sep 22 2008
    Sweden
    Those screws, the green ones, are the hight adjusters! And yes, for the last time, those will be visible once you take the bumper off. And all the screws in the front are T30. The ones inside the wheelhouse are T25 and 10mm nuts
    Martin
    Jul 27 2007
    Orange County, NY
    Ah, I thought the only way to get to the height adjusters is only when you take the bumper off. Guess i was wrong.
    Makes it easier to adjust then.
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Yes, the bumper height adjustment (shown in green with the bumper on on a previous picture) go to the black rubber looking thing that sits on top of the crash bar. That adjusts your bumper height.
    Jul 27 2007
    Orange County, NY
    Ah, I never knew screws actually reach there.
    Guess ill have to play around with them a bit.
    Can they be adjusted with the bumper on but loose at the sides (where the fender liner is?)
    Is that a good approach or will i be forced to pretty much take off the entire bumper.
    Mar 18 2008
    '63 & '75 Nova
    Texas
    I honestly do not know. I would imagine you can use an extension and adjust with the bumper on. Just try it out and if not, its really easy to take the bumper off. Its only held on by ~5 screws.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Having problems with fitting your Dectanes Coder..?
    I see on mine that the fit is not 100%.......You'll have to live with some minor glitches.
    Post up if you can adjust the bumper with it still on. I think I did.....Can't really remember.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    May 08 2009
    Iowa
    Can you adjust the bumper height with the bumper still on?
