Results 1 to 40 of 42
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    P0441 error and CEL?
    I have had no engine issues, or real mechanical issues at all since buying my car two years ago with 64k miles on it. I'm up to 88k now, and the CEL came on this morning. Went to Autozone and had the codes pulled, and this is what came up:
    P0441
    The good news is that this is the only code that popped up. I baby this car with Royal Purple, and whatever the highest octane gas is that I can get wherever I am. It has a Stratmosphere intake and Thermal catback, but no other engine mods. I have had no issues, misfires, or other noticeable engine problems. So does anyone have any idea what happened?
    -Tim
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Re: P0441 error and CEL?
    Evaporative Emission Control System Incorrect Purge Flow - that's what the code means.
    Check your suction jet pump (do a quick search and you'll find the location) to make sure it isn't cracked or coming apart.
    Also, do a leak test. You have a leak somewhere around the suction jet pump that's not sending the needed amount of vacuum to the evap purge valve.
    Should be a pretty easy fix...once you find the problem that is.
    Jun 21 2008
    Here you go:
    The first pic will help you see where the suction jet pump is.
    The second pic is the suction jet pump. It usually cracks or begins separating on the left side (the larger side of the suction jet pump).
    Hope this helps!
    Mar 13 2007
    And this is the same on a 3.0?
    -Tim
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    So apparently this system is what stops the unburnt fumes from going into the atmosphere. If the above recommendation doesn't work I would clean the MAF. Oh yah, I don't think the location of these hoses is the same as the 1.8T. Also something tells me that your gas cap has something to do with this...
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Veteran Member Three Rings gray6spd's Avatar
    Jan 18 2009
    is nonexistent
    texas
    Here is someone that had a similar problem. http://www.audizine.com/forum/showth...ect+purge+flow
    PREVIOUS:
    2004 1.8T Dolphin Grey- Quattro - 6MT - Sport Package - K&N - 35% - Stage: still in college and broke -
    2015 S4 3.0T Sepang Blue Pearl - DSG - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber - Totalled by a damn F150
    CURRENT:
    2015 S4 3.0T Daytona Grey Pearl - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber
    2012 Infiniti G37 Sport 3.7L Obsidian Black - Eibach Springs - K&N -
    Proud of my pink coolant.
    Jun 21 2008
    Yeah, didn't realize you had a 3.0. Next time, make sure you post that up.
    It's probably different and that's out of my league...sorry.
    Jun 21 2008
    Or I could have read it underneath your avatar...my bad...
    Veteran Member Four Rings Vince Stark's Avatar
    Jul 30 2009
    Dallas
    Quote Originally Posted by 04b6sport View Post
    shit but you helped me alot
    i keep getting thesame code over and over
    i also have a question
    i have a BOV, could that be a problem too?
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    BOV isnt the problem , def a evap issue. If the code comes back quickly every time you erase it that means you have quite a big leak in the system. You need to check for leaks (nitrogen smoke machine works best). If you don't have access to one then unplug your purge solenoid on the tank side, not engine side, and blow compressed air into the hose ( very low pressure i.e. less than 15psi.) You will hear a hissing noise where the leak is
    NOTE: you will also hear a hissing noise at the far end of the car where the vent solenoid is located, this is normal since it is in open mode while the car is turned off. If at all possible use VAG-COM or any generic scan tool to shut the vent solenoid which will help greatly in finding the leak;
    Hope this helps!
    Jul 30 2009
    Dallas
    Quote Originally Posted by Valve_Cover View Post
    Hope this helps!
    Thanks +1rep
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    my pleasure! let me know if you need any more help
    Jul 30 2009
    Dallas
    did the leak test today found shit load of leaks
    main thing was the FMIC sensor and the piping
    now i have to change the injector seals and change the oil return line cause it leaks alot of oil
    Jun 21 2008
    Quote Originally Posted by kievskij View Post
    Was it leaking oil before you did the test?
    Did you remove your oil cap and plug off the PCV return hose before starting the test?
    Jul 30 2009
    Dallas
    yeah it was leaking before
    and i did remove the cap
    Jun 21 2008
    Did you plug the PVC return hose?
    Jul 30 2009
    Dallas
    no i actually neglected that and ended up with a smoke screen but after 3m of driving it went away.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Quote Originally Posted by sandspeed View Post
    P0441
    I have gotten the same code. I am actually in the process of getting that fixed. You need to either, replace your N80 purge valve OR/AND replace your gas cap...
    The N80 Purge Valve is right about the airbox and it makes a definite "ticking" noise when it is working. replacement can be found online for about 80 dollars from www.purems.com
    Jun 21 2008
    Be careful...it's easy to mess your seals up. Putting the crankcase under pressure is a horrible idea. But it's okay...now you know.
    I thought the oil started leaking as a result of the test, because you didn't plug the return hose, but that's not the case.
    Jul 30 2009
    Dallas
    yeah man, audis are very complecated cars even a slight mistake can cost you alot of money.
    Jul 30 2009
    Dallas
    fuck me twice the code came back again
    i went a whole day without it and today i went over a bump and it came on
    Jun 21 2008
    I'm assuming you fixed ALL the leaks you found?
    Jul 30 2009
    Dallas
    thats the thing. i did.
    Jun 21 2008
    Did you simplify the evap/vacuum system at all? Or is everything still stock?
    Jul 30 2009
    Dallas
    stock
    Jun 21 2008
    stock
    Well, I'm afraid you didn't fix all the leaks then. I know this isn't what you want to hear, but do another leak test, MAKE SURE there are no more leaks and let us know what happens.
    The only reason why you are getting the code is because there is not enough vacuum present when the purge valve opens. The only reason why you aren't getting enough vacuum is because there's a leak somewhere...
    Sorry buddy, I don't know what else to tell you. Oldguy or diagnosticator may step in soon and have a theory that's beyond me...but I do know the reason why you are getting the code.
    Maybe post up a pic of your purge valve and your suction jet pump. Something's wrong in that whole tangle of vacuum lines...
    Good luck!
    Jul 30 2009
    Dallas
    Good luck!
    Thanks dude
    ill try to get some pics up
    and ill do the test tomorrow and let you know what happens
    btw do injector seals have any impact on the leak issue?
    Jun 21 2008
    Can't help you there...sorry. Just make sure to plug the PCV return hose and take off your oil cap.
    Jul 30 2009
    Dallas
    That i will do
    Jul 30 2009
    Dallas
    did another test
    no leaks anywhere dont know what to do
    got another code though
    P0411
    secondary air
    injection system
    incorrect flow
    Jun 21 2008
    did another test
    P0411
    secondary air
    injection system
    incorrect flow
    Something is definitely going on with your suction jet pump. All of the systems you have been getting codes for, are in some way or another, attached to the suction jet pump.
    Here's what you should do: Remove every check valve, and the suction jet pump, and check for functionality. Make sure they are all working properly, I'll bet one of them isn't.
    How many pounds did you pressurize your system to successfully?
    You might need to do one more leak test. Pour soapy water on every check valve, including the suction jet pump, and look for bubbles.
    I'm really thinking it's the suction jet pump on this one...
    Jul 30 2009
    Dallas
    i sprayd windex on everything including the suction pipe and the only bubles i saw were next to the fuckn injector seals
    the max i put was 15 psi
    Jun 21 2008
    Okay, so you don't have leaks then.
    I would remove those plastic pieces and check for proper function.
    Jul 30 2009
    Dallas
    i just spoke to the previous owner and he told me that he used the sock seals with the new injectors so im going to buy the new ones tomrw
    what plastic pieces are you talking about?
    Jun 21 2008
    Suction jet pump, check valves, T splittings, ect.
    They might not be leaking, but if a check valve is bad, then it's possible your evap purge valve is getting a boost signal. If it gets a boost signal, it'll throw a code.
    If ANY of the plastic pieces involve with that system are not functioning properly (take em all out and test em) it will affect everything else.
    Jun 21 2008
    Actually, I'm betting that's your problem...
    Hence why you've gotten evap and SAI codes...one of the PLASTIC pieces is bad.
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    I failed emissions a couple weeks ago with a P0411. Can you tell me what this plastic peice that looks like its broken is and what it does. I noticed this part being in one of the pictures above. I have a funny suspicion that this is caused the CEL. Another this i noticed is that it starts to tick for about 60 seconds and stops.
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Jun 21 2008
    Quote Originally Posted by bmags88 View Post
    That's a one-way check valve, that restricts boost signals from reaching your EVAP purge valve. You received that code for incorrect flow. There's a good change it's causing your CEL.
    May 12 2008
    Thats the best news I've heard since it failed. And the ticking? I'm assuming that there should be a part # on this? I wonder how much it costs.
    Off the subject...Loving the gauge!! I had a Autometer before and this one blows it right out of the water!
    - Mags
    May 12 2008
    Sorry Greg I forgot... +1 rep!
    - Mags
