Results 1 to 40 of 62
    Jul 06 2009
    NH/CT
    Stripped License Plate light screw
    My driver's side license plate light went out, and I am trying to replace the bulb but the screw is stripped and stuck..here's a pic for reference. Any ideas guys?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Stripped License Plate light screw
    I have an idea
    Audi does not sell the screw by itself. The light assembly is about $15.
    2002-2003 8E0 807 430 A (left) 8E0 807 430 B (right)
    2003 up 8E0 943 021 B (left) 8E0 943 022 B (right)
    Oct 19 2005
    niagara
    have fun with that, both sides of mine stripped and then if its rusted im sure the entire bulb along with the connector is rusted. Cost 180 to replace i just never put new bulbs in, and its been over 2 years
    Jul 06 2009
    NH/CT
    Quote Originally Posted by 400HPA4 View Post
    I have an idea
    Yes I know the assembly exists..i got the picture from ecs. what good is a new assembly if you cant take out the screw in there now?
    May 16 2009
    Maine aka Canada Jr.
    all you need is a good screw extractor bit for a power drill:
    http://www.amazon.com/gp/product/B000KKR7JM
    pulled my ass out of a jam numerous times when working on computers/electronics.
    Senior Member Two Rings beegeezy's Avatar
    Apr 26 2009
    Austin, tx
    ^yeah, you can get those at sears btw. I think I paid $7 for mine. (the screw extractor, not the drill)
    Slow and ugly...
    Established Member Two Rings Leeber's Avatar
    Mar 19 2009
    boards, beach cruisers and B7 S4
    Southern Cali
    yeah these screws suck, its almost like they were made to strip!
    Oct 15 2006
    From a few to one...
    Arlington, VA
    same thing just happened to me. i'm gonna call the dealer and see if i can pick one up, then try to figure out how to get that damn screw out.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    i am glad that i am not the only person that had this issue. the first time i tried to even look at it i almost stripped the screw... that thing is retarded.
    Senior Member Three Rings AMESSA4_NJ's Avatar
    Jan 11 2009
    03 A4 B6 1.8TQ , dirtbike & a bunch of rims
    exit 91 , NJ
    i dealt with this and its not fun ..
    "life is nothing but fast cars & cashflow....at least for me"
    too many parts too list and too many parts on my mind to buy..
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    I used a phillips head on a ratchet. Works fine.
    High speed Ferrari movement...
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    haha i just put LED's in mine and almost striped both those stupid screws out
    good luck with those
    Please Drive Right
    Veteran Member Three Rings rpetral0's Avatar
    Jul 25 2009
    Just had the same issue!!! Beyond frustrating. Finally just got pissed, soaked it in break free and wd-40, let it sit for 10 min and bam, out with a jewelry screwdriver. Good luck!
    ...I'm listening
    Senior Member Two Rings Juggern@ut's Avatar
    Aug 10 2009
    80 Corolla
    Dirrty Jerzee
    Quote Originally Posted by etnies View Post
    My rear has been dark for a year now
    it puts the lotion in the basket...
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    Just pry the corner of the assembly, crack it in half, use snips to clip away all the plastic, then you have enough space to just use some needle nose pliers and unscrew/yank it out. Go buy a new assembly at the dealer for $15 and save yourself the hassle.
    2003 A4 1.8TQM
    Markham, Ontario
    This was discussed on one of the other forums (AW I believe) and one of the posters went out and sourced some replacement screws - stainless if I recall - think they were M3 x 15, but I could be wrong.
    Once I find better screws, I'm ordering LED's and replacing both of mine - might have to get medival on the one that's stripped out...
    Jun 08 2008
    Calgary AB Canada
    i used some RC screws for mine and they worked like a charm
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    wish they had replacement screws with an allen wrench head, such a shitty/awkward space to work in with a screwdriver anyway. I have the same problem, somehow got them out today, cant forsee them coming out ever again unless i want to drill them out.
    Established Member Two Rings a4cruiser's Avatar
    Feb 03 2009
    99 gsx600
    St. Louis
    striped mine and had to drill out. not fun
    If it isn't broke, don't fix it... EDIT. It will be broke soon.
    3.0 Group Member
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by Peacob View Post
    you can find some. thats what my RC screws are
    Stock. For now...
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    Drilled mine out as well. One of the most poorly designed components on the B6, IMO. I bored out the old screw and drilled in new ones at different locations using better screws (Robertson head FTW, btw).
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    mine are on their way out too. will b stripped if i touch them again....
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    This happened to me. I took a small drill bit and drille a hole right into the head. Make sure the bit is smaller than the screw shaft (dont laugh!!) so that you're not actually drilling it out. Then find a star bit small enough to wedge in there with enough grip to unscrew it.
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Aug 26 2005
    Drill the broken/stripped screw out. With either new light assemblies, or to repair the existing lights, use SS socket button head machine screws retrofitted to all four screws. Use a 2mm X 10mm screw and pre tap the light housings if needed. It's easiest to remove the entire lid switch/lamp assembly from the lid to to a proper repair. Remove the lid liner to access the bolts for the assembly.
    Veteran Member Three Rings burns420's Avatar
    Oct 20 2007
    I stripped mine to. i ordered some led lights and used a torch to heat the screw and it came right out(you need a very small tip) and melted the housings at the same time and the just fell off. Ill be using robertson screws since they dont strip(if you can use a screwdriver).
    PM me for A/C service in the Greater Toronto area. Residential, commercial and automotive HVAC service and installations, big discounts for AZ members!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I found it easier to just remove the the whole assembly as diagnosticator suggested. Only takes about 20 minutes and everything is much easier to access.
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Happened to me....I just drilled out the screw and used a silicone adhesive to hold it back in. Just needs a screwdriver to pop out now...and re-glue for reinstall :P
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Established Member Two Rings 1.8WAGA4's Avatar
    Feb 20 2004
    2002 A4 Avant 1.8T
    Mtl, Can
    old guy, can you explain how to remove that back panel / lid? I see some clips in between but have no clue on how to remove without damage. Thank
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by 1.8WAGA4 View Post
    It's been a few years since i removed the trunk lid liner but I will do the best I can from memory. There were two alignment bumpers on the left and right outer edge that removed with a Phillips head screw. The glow in the dark cover on the interior trunk safety release handle snaps off there is a screw underneath the cover that has to be removed. Take out the safety triangle and remove the holding bracket by pressing up on the two plastic tabs in the lower edge of the holder. I think there was a screw underneath the bracket that had to be removed. I believe that was all that had to be removed. Next just pull down on the edges of the liner to release the plastic snaps holding it in place. Start in one corner and work your way around until the liner is free. You should then have access to the release mechanism and liscense plate lamp holder/release holder bracket.
    Good luck!
    Senior Member Two Rings Red Rings's Avatar
    Sep 07 2009
    chicago
    Good luck!
    wtf that was from memory..(damn robots with mustaches) i would of been like i think there is 2..no 4.. wait i think 7 clips. someone on the the trunk...
    Veteran Member Three Rings KGB's Avatar
    Apr 18 2007
    B9 S5
    Ottawa, ON
    Shit, I thought I was the only one this happened to. Both lights went out at the same time and I fcuking stripped both! Then the one on the left came back on and I didn't get a light out message on the dash. Let's hope it stays like that (knock on wood) cause I dont wanna deal with this.
    Quote Originally Posted by AudiBama View Post
    Ghetto, but I like! Will probably do this.
    PS - WTF is up with all the lights going out in these cars?! Driving me nuts! Every time I turn the car on I know I'm gonna hear that dreadful beeeeeeeep.
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    the screws on my headlights were all stripped
    ended up fixing it with some sort of putty
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Good luck getting the stripped screws out. The angle is awkward which makes removal difficult but not impossible. Best to remove the housing first. I ended up replacing the entire housing and the light covers. When you reinstall, anti-seize is your friend.
    Here are instructions for removing everything.
    Aug 26 2005
    Allen/socket button head stainless machine screws in metric size are available from most Ace Hardware stores, and other sources.
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Quote Originally Posted by Alkivar View Post
    these work great and i highly recommend getting a set. and pickup a set of these while you're at it. both have saved my ass so many times.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Feb 20 2004
    2002 A4 Avant 1.8T
    Mtl, Can
    Thank you guys for your help, but I realized that most of you have a sedan and I need to find the info regarding an Avant. Seems to be different to remove the interior door/trunk panel and that's where i got problem now. After removing the triangle and the 4 screws, I'm able to pry a little bit and see that there is 6 clips retaining the panel. 1 out the 6 is already broken and need to find out how to remove the other 5. Is there a special tool for that?
    Mar 26 2009
    NuYawk
    I have had this problem, like many others (Avant). If you drill the heads off of the screws, you can remove the lens itself. This will allow access to the 'headless' screw shaft. The screw shafts can be extracted with a pair of small needle nose pliers; you can turn them out with the pliers.
    Note: the screw extractor noted above is excellent, as well.
    '01 TT Quattro/Roadster/Stock
    '03 1.8tqm Avant/Not Stock
    '13 Allroad - work in progress
    Feb 20 2004
    2002 A4 Avant 1.8T
    Mtl, Can
    Quote Originally Posted by TTurn2 View Post
    I know that sounds like the easiest way to change bulbs, but in my case, like many others, I need to change the entire unit because the sockets are grilled. In fact, I need to remove the intérior panel of the tailgate to access the screws that retain the unit in place. Anyone with a Bentley manual showing how to remove those interior clips?
    Registered Member One Ring joelashin's Avatar
    Oct 27 2010
    2007 lexus rx 400h, b7 a4 stasis
    queens ny
    Quote Originally Posted by Leeber View Post
    they were made in france :o D:
    RAWRmy car goes RAWR
    Oct 09 2008
    Quote Originally Posted by joelashin View Post
    The Awesome™
