Results 1 to 17 of 17
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    What is the purpose of the N112 valve?
    according to this picture
    The "after simplification" picture on the right side,
    the Crankcase breather goes from
    Crankcase -- > Atmohsphere
    But it's also connected to the N112.
    What's the direction of flow here? N112 --> then Crankcase --> then both out the dump (to exhaust or intake)?
    I have no freaking clue what the N112 does in this instance.
    #2: the Pancake valve (PCV) that works with the crankcase breather hose. What's it's purpose? Does it stay shut under vacuum(idle) ? And open when positive crankcase vapors are exerted on it?
    Bottom line: I'm trying to remove, Suction jet pump ONLY, and I'm trying to figure out which way the check valves restrict air, so that I can leave 1 -2 in there for each independent connection.
    Thanks
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: What is the purpose of the N112 valve?
    The N112 is the on/off switch for the combi valve. During a cold start the ECU activates the N112 which in turn provides a vacuum signal to the combi valve. The combi valve opens up and lets air into the exhaust as supplied from the SAI pump. If you follow the line from the N112 closely you will see that it is connected to the vacuum canister. the side connection on the line to the vacuum canister is the vacuum source for charging the canister.
    What you are calling a pancake valve is actually the crankcase breather pressure regulating valve. It allows regulated air flow in both directions. Under vacuum conditions it allows clean air to enter the block and exit through the PCV Crankcase breather (#13 on the diagram). Under boost conditions it allows air flow out of the block through the TIP connection.
    Here is an explanation based on the AWV motor but the AMB functions essentially the same way.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by A4 Moda View Post
    Whomever drew that right side chart is incorrect. The line going from the intake manifold to the brake booster should NOT be connected to the crankcase breathing system unless you continue to use the 'suction pump'.
    I have a single line going from the IM to a check valve to the brake booster.
    Another line from the IM going to the DV and N75.
    Then I have a crankcase breather line going from the block to a 'T' joining in with the valve cover. That line then goes to a filtered catch can. There is then a line going from the filtered catch can to my exhaust.
    -Doug
    Dec 28 2006
    Western Maryland
    Good morning Doug! If you look real close at the line going to the brake booster you will see that it goes over the breather tube line rather than intersecting with it. The drawing isn't real clear.
    Jun 11 2005
    Thank you. That was a perfect explanation. Turns out, it was completely my fault. I misread the picture. What I was calling N112 is actually the Crank case breather vent.
    I'm trying to remove the suction jet pump from the car. With it's million check valves, i have more than enough leaks to compromise my system.
    My question is, if I run one single line between the brake booster and the intake manifold, Which was is the air actually flowing? How will I orient the check valve?
    2003 1.8T
    Jun 11 2005
    Doug,
    Under vacuum though, doesn't the engine draw air through the Pancake valve into the crankcase? And then under boost the TIP will suck the crankcase vapors through the breather tube and back through the turbo.
    But with your current setup, wouldn't your car be drawing exhaust gases while it's idling?
    2003 1.8T
    Dec 28 2006
    Western Maryland
    You want the flow to go toward the manifold so you can maintain a vacuum in the brake vacuum booster.
    Dec 28 2006
    Western Maryland
    Doug,
    It won't as long as there is no manifold vacuum line connected to the block breather lines. The manifold vacuum is what draws fresh air into the block via the pressure regulating valve.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Good Evening Fletcher. You are right. It appears that the diagram shows two different lines. My eyes were not open yet. I am sure the original post which contained that diagram specified its not part of the crankcase system but the image alone is kind of misleading pending the users interpretation.
    I found out today that even Valeo SMFW OEM replacement clutches can get the stack height wrong . My friend, who's car it was, was not happy but we came to a good resolution. Why can't manufacturers get anything done correctly?
    Doug,
    I failed to mention that I have a check valve welded onto the downpipe so nothing can go up the lines towards the engine. Only gases can go out of the lines into the exhaust stream of the car.
    -Doug
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    If I'm not mistaken, the brake booster has an internal check valve, so you do not NEED to put another one inline.
    Am I correct Oldguy?
    Jun 21 2008
    ^^ Can anyone confirm this?
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    Quote Originally Posted by [email protected] View Post
    I wish someone confirmed this lol
    Aug 26 2005
    Quote Originally Posted by jpulll View Post
    It is not clear what you want clarification for.
    Vorsprung durch Technik
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    The brake booster does not have an internal check valve. The factory hose going to the brake booster is where the check valve is located.
    Dec 28 2006
    Western Maryland
    The brake booster does not have an internal check valve. It has a vacuum passage that connects either side of the diaphragm and an atmospheric vent. When you press the brake pedal the vacuum passage closes and the vent to atmosphere opens. This puts all the vacuum on one side of the diaphragm and assists the pedal pressure to help stop the vehicle.
    If you remove the SJP you should most certainly add a check valve. Otherwise you can apply a boost signal to the diaphragm instead of a vacuum signal if you press the brake pedal any at all while the manifold is under boost. I doubt that is very healthy for the brake vacuum booster.
    And yes I am aware that the question was asked 6 years ago. Sometimes I am a little slow.....
    Jun 30 2008
    Erie, Pennsylvania
    On my B5, there exists a check valve in the OEM hard line that goes in between the brake booster and the false firewall. I'm not sure if that is true for every configuration, but in my case, the check valve function of the SJP was redundant. Upon deleting it, I did not replace it with another.
    Redundancy would not be a bad idea though. These are your brakes, after all! If I had to choose a valve to install, I'd probably favor a booster check valve of full metal construction from an older Toyota (like an 85-95 Toyota Hilux).
    Jan 24 2008
    Pennsylvania
    Walky is right. The B5 1.8T brake booster to IM line has an integrated check valve. Perfect OEM part for those who remove the SJP from their B6.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
