So I have a 2003 with the 3.0 and I did a full timing belt job about 3 months ago. And yes I used the proper cam locking and crank locking tools. Everything seems fine with install and the car runs great, but I get a check engine light that comes on and goes off randomly. Well I pulled the codes with vag-com an I got:
Address 01: Engine
Control Module Part Number: 8E0 909 559 E
Component and/or Version: 3.0L V6/5V G 0003
Software Coding: 0016584
Work Shop Code: WSC 00672
3 Faults Found:
19757 - Exhaust Camshaft Position Sensor Bank 1 (G300): Open or Short to Plus
P3301 - 001 - Upper Limit Exceeded - Intermittent
18404 - Friction too High; Intake Cam Adjustement Bank 1
P1996 - 008 - Implausible Signal - Intermittent
18406 - Friction too High; Intake Cam Adjustement Bank 2
P1998 - 008 - Implausible Signal - Intermittent
Any ideas? Is replacing the cam sensor a good place to start, or do I have another problem that I should be looking at? The "friction too high" kind of freaks me out. I have cleared the codes but they will come back in a couple days. Any help is appreciated
