Results 1 to 12 of 12
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    BBS RC center caps?
    finally pulled the trigger on a light weight set of wheels for my 02, BBS RC 17 X 8's from the classifieds. Decided I didn't want to run 40 series tires on 18's on our crappy roads around here, and I actually like the look of the right style wheel in a 17 inch size. 17's are lighter too. My new tire wheel package will weigh about 48 pounds less than my factory sport wheel heavy tire combo I have now (52 pounds!)
    Anyway, the wheels are missing two of the big BBS caps. anyone got one or two still laying around they could part with? Know of a good place to get them?
    Also, I saw somewhere that some BBS owners have gone without that heavy cap and found a 60mm cap that fits the small center hole and ran that with a BBS or audi 4 ring sticker and left the lugs exposed. Anyone done that and have info on what they used?
    Dec 19 2007
    York, PA
    Re: BBS RC center caps?
    Apr 05 2009
    SF BayArea
    ebay, never heard of that web site :)
    Already checked there, and only found some lame looking black plastic snap in ones that were expensive and in England.
    Dec 19 2007
    York, PA
    hmmm...what size you looking for? Most ARE plastic iirc?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We stock all the BBS center caps you need..
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I have some BBS RC caps but only 3 They are on our 337...I have one extra if it is a help...on one side of the car we run the BBS caps and the other I run the VW...kinda ghetto but one of each of my caps has turned up missing.
    Apr 05 2009
    SF BayArea
    Greg, 1 is a start, and it makes it easier to find a single later to complete the set. Does it look like this?
    PM me with what you want for it.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Yes, i think we can just bring it your way...I'll tear apart the garage today and see where I put it, I have the one spare VW one in the trunk on my spare wheel.
    Apr 05 2009
    SF BayArea
    if anyone has a VW one, I think i can also just swap the cap out for a BBS one, so that might be a viable option as well. the logo caps are cheap, the full spin on thing isn't.
    Apr 05 2009
    SF BayArea
    Just found out the ones for the factory BBS RC VW wheels don't fit even though they look identical to the ones I have on my other wheels. the center hole is smaller on the factory ones where the thing screws in.
    These wheels have about a a 70mm threaded hole for the cap screw, and the VW ones are about 55 mm.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    That sucks, I tore apart the garage today to uncover a couple for you. I just measured these and the center bore is 54mm.
    Apr 05 2009
    SF BayArea
    anybody with factory Audi BBS RC, can you measure the OD of the threaded part that screws the center cap in?
