Results 1 to 18 of 18
    Registered Member Two Rings
    Oct 06 2008
    2005 Audi A4 B6 1.8t 6sp
    Audi A6 2.7T Torque Converters
    Hey my dad has a 2004 Audi A6 2.7T with 66,000 miles that is automatic and his check engine light just came on a few days ago. The dealer said that he needs to replace his Torque Converter and they were going to charge him $3,200 for to fix it/replace.
    Is this a common thing to go on the A6?
    Isn't 66K soon for something like this to go?
    Is there a cheaper way to fix it?
    Any ideas or thoughts?
    Thanks
    Jun 24 2008
    E46 M3
    Woodinville WA
    Re: Audi A6 2.7T Torque Converters
    Unfortunately the torque converters used with the 5HP-19 (01V) transmission were a common problem. Though the problem was mainly isolated to the 01 - 02 model year cars. There was a manufacturing defect with ZF (the company who makes this transmission) which seemed to affect mostly just the 01 - 02 model year cars. There is a new updated torque converter to cure the issue. An 04 model should have already have the latest updated converter but I have heard of a few isolated cases where even the new updated converters fail as well.
    The issue is a small seal inside the converter, which is supossed to hold hydraulic pressure to lock the clutch inside the converter under certain driving conditions, will fail and the clutch won't lock up. There is a Service Bulletin about this.
    Driving around with this issue will ultimately lead to transmission failure as the fluid gets contaminated with excessive clutch particles (since it slips when it's supossed to be locked). Though, with 66K on the ticker, it needs service soon anyways.
    The cost of the torque converter itself ranges anywhere form 950 - 1200 green jelly beans. Don't waste your time and money with aftermarket or "rebuilt" torque converters in this case. By the time you add up the converter, 9 - 10 liters of fluid (should be about 10 liters since 2.7T A6's have a secondary tranny cooler also), pan gasket, filter, other misc. parts, labor and tax, it quickly gets to be well over 2 grand. Soooo, in the real world and considering how long it really takes to do this job (not 12 hours like "book time), 3200 sounds a bit ambitious, even for a 2.7T car.
    Did they include any other "little thing" with that estimate???
    After the repair, you'll notice a slight improvement in mpg and slightly better throttle response mainly at highway speeds, well, not so much throttle response but rather better response in power transfer to the wheels........
    Also, after the repair, set the transmission coding to 01032 instead of 01002. Think of it as the "Dynamic Sport Mode" that Audi/VW will never admit can be set on US/CDN market cars. It's not a huge improvement. The car will finally shift the way it should. Some people may know about the "Paul Waterloo's A8 trans coding tweak". It actually works for most all 5HP-19 and 5hp-24 trans controllers with tip tronic. Though, controllers using the 7 digit coding like yours should be being an 04 (0001032) seem to be real "finicky" to accept the coding change. Sometimes you just have to try several times using the latest vagcom version or beta version................
    blah blah blah
    sorry to be so long winded
    good luck
    C
    Fellow Audi Nut turned to the Dark Side!!!
    Aug 31 2007
    2001 Audi A6 2.7t
    New Jersey
    try searching, there are a ton of posts about this.
    In short:
    Yes it is a problem, I'm getting mine done this weekend actually.
    And don't take it to a dealer, they will rip you off. Find a transmission shop or if you upgrade, the place that you get it from could do it for you. It shouldn't be more than $1600 for parts and labor for the upgrade. Try 517trans.com, I am getting mine from them.
    2001 Audi A6 2.7t Stage 2+: Special Edition, Sport Package, Winter Package, Luxury Package, APR 93 octane program, Navigation, Bose Audio, IPP Intercoolers, APR Bipipe, 710N's, Custom 2.5" Exhaust, Piggie Pipes, Upgraded Torque Converter, Stage 2 Darintake, ABD Racing big bore intake, H-sport sway bar kit, Slotted/Drilled Rotors
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    I have posted so much on this. Try a seach. I have replaced mine and all my research is in a thread. I chose 517
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Sep 04 2011
    2003 A6 2.7T Quattro
    Delafield, WI
    Is 517trans installing the converter or just selling it to you? I just received a quote from torquecoverter1.com and the quote was about $280 with S&H?
    Senior Member Two Rings TozoM8's Avatar
    Sep 17 2010
    Black on black 01 Twin Turbo S8, 6MT, built in SRX 01' allroad 2.7T
    Chicago
    Quote Originally Posted by akaudi6 View Post
    They send you one and you have to send back your old one. Bring it down to Chicago and I change it for you for $1200 including fluid.
    01' black on black twin turbo S8 with 6 speed manual (euro TDI 6th gear), RNS-E, Passport SRX
    Nov 01 2012
    philadelpia,PA
    my tranny just went out due to this problem and is also pulling side for incorrect gear ratio , I was quoted 2750 -3000 to rebuild is that a fair price ?
    Mar 07 2013
    Chicago, Illinois
    Cool my 2004 A6 2.7 T needs torque converter
    Quote Originally Posted by TozoM8 View Post
    I am in Chicago, will you change mine? I don't seem to have any noticeable symptoms, but they tell me the torque converter needs changing. Three shops have said it is not a problem with the electronic system.
    lmganda
    Established Member Three Rings MCargill12's Avatar
    Nov 10 2012
    Tools
    Northshore MA
    I feel like shops that think torque converters are bad throw the car on the lift, turn it on, and give it gas and if all 4 wheels dont spin at the same speed/time/whatever they automatically think its a torque converter.
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    Quote Originally Posted by MCargill12 View Post
    A diagnosis of a bad/failing torque converter is usually the result of the following DTCs:
    P0741
    P1624
    Basically, the lockup clutch is no longer functioning efficiently, as there is still slip detected after the tcu requests lockup.
    I don't think anyone would diagnose a failing converter by lifting the car.
    Nov 10 2012
    Tools
    Northshore MA
    Alllllright my point proven wrong. Thank you ddillenger. lol
    Quote Originally Posted by ddillenger View Post
    P0741
    P1624
    Oct 14 2012
    Upstate NY
    May 16 2008
    South Texas
    That's the dumbest diagnostic test I've heard of.
    Apr 16 2013
    stafford va 22556
    Hello.my name is adrian and i have2002 allroad audi. Anybody around stafford virginia who can give me a price to replace torque converter? And where i can get the part from? Thank you
    May 16 2008
    South Texas
    I've got a few conveter options.
    AAM Torque converters
    I searched far and wide to find a company that updates the seal as well as the friction lining in the clutch.. Most converter companies re-use the factory friction lining.
    Aug 05 2008
    18 Q5 2.0t quattro
    Shrewsbury, NJ
    I have seen the Audi A6 come in with a faulty torque converter fault P0741 and or a driveabilty issue. Stalling at a stop or shutter while driving on the highway. Most of these vehicles have had the faulty torque converters replaced with newer units.
    Have any technical questions or repair questions, message me! 10 year veteran Audi Tech or ASE Master Technician.
    Mar 15 2016
    Bolingbrook, IL
    Still in Chicago? I may need this done soon.... price still the same?
    Mar 15 2016
    Bolingbrook, IL
    I've had that weak reverse gear or slow to engage delay when shifting drive to reverse or reverse to drive with no codes for months. now I get the p0741 - kind of think the fluid level was not corrected after having the timing belt and water pump done - but never had any other trans codes or issues - right before the code came I got a clunk like a hard shift - it happened on 2 different occasions then the code. with these symptoms - do you think just TC or entire transmission job? I was thinking about Level10 products. Any thoughts? Also - I did replace the filter and fluid to see if level was the issue - code came back after about 10-15 miles. No clunking (yet) maybe a higher than normal rpm before shifting between 1-2...
