Results 1 to 25 of 25
    Dec 05 2007
    DIY: Non-Fouler Mod to Remove CEL for Test Pipe or High Flow Cat
    Chrome extension to get photobucket pics to show up: https://chrome.google.com/webstore/d...alioapbifiaedg
    When people place a HFC or TP onto their exhaust system, a CEL for Catalyctic Converter Effeciency Below Threshold usually pops up. Not in all cases, but in many cases it does. You recieve this code because with the addition of a tp/hfc the exhaust flow increases and the 02 sensor feels that there is something wrong with your stock catalyctic converyer. This mod basically fools the secondary 02 sensor by placing the 02 sensor further back, where the 02 sensor is no longer in direct path of the exhaust flow. This mod does not only remove the CEL, but also lets you pass readiness for the catalyctic converter when inspection time comes around. [Please note, that this has been known to not work in some cases for the AWM. But I have an AWM with HFC, and this mod works for me.]
    Total time: 30min-1 hour
    Difficulty on scale from 1-5, with 5 being the most difficult: 1
    Tools needed:
    Help! 42002 Spark Plug Non-Foulers (2 in box)
    7/8" Socket/Open End Wrench
    Power Drill
    1/2" Metal Drill Bit
    High Temp Anti-Seize
    Vice Grip (not necessary)
    PB Blaster (to remove 02 sensor from bung)
    1. The first thing you want to do is spray your secondary 02 sensor with PB Blaster and let it sit for an hour, to be able to take it off the bung. That is if it is burnt onto the 02 sensor bung, which more than likely it is.
    2. Spark plug non-fouler before pic
    3. Now, you will need to drill the ID (inner diameter) of it to 1/2". I used a power drill with a 1/2" metal drill bit. I also don't have a vice clamp, so I used a different technique. Of course it would be better to place the non-fouler in a clamp and drill it from there. But for those whom don't have one, what I did was hold the non-fouler in place with a 7/8" socket wrench and drilled with it planted on a flat surface (it may be best to use a wood prop underneath it). Then clean off any metal shavings left over from drilling.
    3. The spark plug non-fouler after drilling
    4. Next thing, is to remove the 02 sensor (you may want to unclip the conector before doing this, as to not kink/twist the wires) using the 7/8" wrench or an 02 sensor removal tool. In the picture, I purchased a new 02 sensor because my old one was done for. Place High Temp Antiseize on the threads of the 02 sensor and thread your 02 sensor onto the non-fouler (be sure not to touch the head of the 02 sensor nor get any antiseize on it) and toque them together nicely (I used an adjustable wrench and the 7/8" wrench to tighten them together).
    5. Now you are ready to place the 02 sensor back onto the bung. Place high-temp anti seize onto the threads of the non-fouler, simply place the 02 sensor and non-fouler back onto the secondary 02 sensor bung, torque it down with the 7/8" wrench and you are done (if you disconnected the 02 sensor, simply plug back in).
    In some cases, 2 non-foulers may be needed. But I only needed one. Also, I removed my stock air box for more room to work, but it is not necessary. If this is the case don't drill out the second one, but stack them.
    *Disclaimer: Neither Audizine, any of it's members, nor myself will be held liable for any mishaps which may incur.
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    Re: DIY: Non-Fouler Mod to Remove CEL for Test Pipe or High Flow Cat
    1/2" may not be quite big enough to fit the sensor, mine needed to be drilled a bit larger diameter and I've read other people on this forum also having to drill the hole slightly larger than 1/2" but it's a good starting place.
    Dec 05 2007
    I had mine drilled at 1/2" for over a year and a half now. Passed inspection and all with no issues. I just made this DIY because I replaced my 02 sensor, and figured "why not?". I needed to replace that thing with a new one anyways.
    Senior Member Two Rings slideitsidewayz's Avatar
    Jun 30 2008
    1998 Audi A4 1.8tqm gt2871r
    North Jersey
    should this work on an AEB engine? if so...im doing this tomorrow! haha....good write up!
    Dec 05 2007
    This mod should work with just about any vehicle. I am not sure how advanced monitoring systems get (as in sensitivity), but B6 guys can do this 2.8 guys, B5 S4 guys, etc. If you are doing this mod because you have a turbo-back exhaust (no catalyctic converter), you wil need to place 2 non-foulers onto the secondary 02 sensor bung.
    This mod is essentialy the same thing as purchasing this: Clicky Click
    Jun 30 2008
    North Jersey
    AWESOME! thanks dude...yeah i looked at my car before and i have an O2 sensor right after the turbo...so thanks for answering my question before i asked it lol.
    Dec 05 2007
    You don't place this onto the sensor right after the turbo (this is called the primary 02 sensor). You place this on the secondary 02 sensor (downstream 02 sensor).
    Senior Member Two Rings SnowBum124's Avatar
    Sep 14 2006
    1999.5 A4 1.8t avant
    seattle
    ya i did that over a year ago and it worked great
    BetaAlphaTau member # 40
    love my shag-in wagon
    GT2871R turbo, 630cc Siemens injectors, 034 Downpipe, SPAmanifold, TR11 FMIC, Maestro7, south bend stage 4, VR6 TB
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    Quote Originally Posted by slideitsidewayz View Post
    it works on an AEB cuz I did the exact same thing for AEB A4, same parts and everything, I got a Labree HFC and this mod works great no CEL at least regarding the O2 sensor. Great write up.
    99.5 A4 1.8 TQM
    Eliminator GT2871R, UNITRONIC "440cc" tune, FMIC, 2.5" exhaust, SB Stg 4, Gutted LaBree, B&M short shifter, 034 Snub Mount, AWE DTS, LLTEK FR Strut Bar, Synapse DV, SCAT Rods, 034 HF Exhaust Manifold
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Sorry to thread resurrect, but i have a few questions. Im going to have my exhaust redone on my 2.8 30v. im taking stainless pipe straight from the block to the muffler. i cannot have CEL's, cause i have to pass emissions.
    So. on a 2.8 30v, where do i need these things? How many do i need? Is it a matter of drilling and tapping and threading them into the pipe? or welding them on somehow?
    i really need some help and imput. i gotta have this done soon, and i gotta tell the guy whos doing it what todo so i dont end up with a car that wont pass inspection. THANKS
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Dec 05 2007
    So, you are removing your catalyctic converters and am making a header back exhaust (in a nutshell)? If this is correct, you would need to have your welder install 4 02 sensor bungs in total in the same place they would have been on your stock exhaust system. You will need 2 bungs on each side. One where the pre-cat bung used to be and one where the post-cat bung used to be. I am not too fluent on how the 2.8 will react, so I would suggest you go a different route (just a suggestion).
    Check out this link. You would need "2" regular 02 sensor bungs to be welded onto the straight pipe for the primary 02 sensors (bank 1 and bank 2), as I mentioned above at the correct spots. Then "2" of the j-piped sensor bungs to be welded in for the secondary 02 sensor bungs (bank1 and bank 2).
    You would also want to look into your state emission laws to see if a visual inspection of the catalyctic converters are required for the smog test. In my state, emission tests are simply done via OBD II port and I can fail 1 readiness (I need to pass 9/10). But they also do a visual test of a catalyctic converter. So I can pass my readiness, but would still fail emisssions (in your case) test do to not being able to pass the visual test. They just need to see that I actually have one.
    Oct 03 2008
    what garage?
    Pittsburgh
    Appriciate the imput!
    Well, honestly the only thing im trying to avoid is the extreme rusting of a traditional exhaust system. I thought removing the cats was a good idea due to them going bad and restricting flow, but if its a bad idea, just forget it. I just have to find a way to go stainless.
    16' Silverado HD
    Dec 05 2007
    You can always have a system built with high flow catalyctic converters installed. I find a complete exhaust system to be really enjoyable on a vehicle. It grants a way better throttle response than the stock system can ever grant. Maybe still go the custom 2.5" route, and just have the high flow catalyctic converters installed. And still do as I mentioned above.
    http://vibrantperformance.com/catalo...b2518f861a6a37
    There is nothing wrong with having the cat converters removed, if that is what you want. It decreases back pressure, but at the cost of increased noise and cabin drone. The main thing to take into consideration is your state emission laws. For example, I live in NY and am required to have a cat converter during inspection. Just as the next, I eventually want a BT. I will have a 3" HFC welded into the dp, and that should grant me no issues to passing emissions in my state.
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    Just a question, I wonder how you get a wrench all the way down there?
    My hands/forearms aren't that big and I can hardly get mine down there for the WB install.
    NB: We don't have secondary O2s, so I'm using this bung for my WB.
    Did you have to remove the PCV hard line and/or airbox?
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
    Dec 05 2007
    Yeah, I removed the top portion of the airbox.
    Deactivated Two Rings Broccolihash's Avatar
    Jun 10 2009
    Ann Arbor, MI
    Completed this mod last weekend! Works great so far!
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    This doesn't work on my AWM a4 since my 02 is longer than the one you have. I would need a longer part to work on mine.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Dec 05 2007
    I have an AWM and have 2 spacers currently on mine. I got tired of having be cautous of the way I drive, to avoid a CEL with one non-fouler. Oh, the freedom of cruising in 3rd gear for as long as I want.
    Sep 23 2007
    Quote Originally Posted by gmx View Post
    Its a pain in the ass put a open box wrench on there take a pipe and bash it loose. Thats how i did mine
    Quote Originally Posted by a4_1.8t_01 View Post
    a hexedit mod would work. ;) hit me up.
    contact via email please.
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    Quote Originally Posted by k0mpresd View Post
    You don't have the same mod for ATW? I have the spacer (it's baked in after several years of being there) and I have the occasional code pop up. I'd be so relieved to have it gone forever.
    sent pm.
    Mar 07 2014
    Ok thread resurrect, I just bought a test pipe and a used APR chip. I'm reading some ppl used 1 non ffouler and others have used 2. I want to be able to do this once and done. I have an 01 Quattro 5spd. What is the best route to not have a CEL. Also is it possible to go to APR and have them program the chip to delete the 02 code? (The only code on my car now is P0420)
    Dec 05 2007
    With the AWM and test pipe, use two. Only drill the one the sensor will sit in.
    Jul 28 2024
    Latvia
    So in conclusion, you need to stack 2 spacers on the second o2 sensor, nothing else?
