Results 1 to 40 of 69
    Active Member Two Rings ozone's Avatar
    Oct 20 2007
    S4, M3, NSX, RR
    Conesus Lake NY
    Remote Key Not Working After Battery Change
    I just had my battery changed at a non-Audi dealer. Neither of the key fobs are working anymore. Is this is a simple setting I can fix or will I have to take it to the dealer to get them reprogrammed or something? Thanks...and I did check both and they were working previously.
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    Re: Remote Key Not Working After Battery Change
    Quote Originally Posted by ozone View Post
    give them some time they will start again mine does the same things... about a day tops
    Gcc's blacksheep
    The keys need to be re-programmed. Here is how you do it...
    You have to put the key in the ignition, turn the key to the "accessory position" , and hold the unlock button for at least 5 seconds. This should do the trick.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    ^correct
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Quote Originally Posted by joeycuccaro View Post
    +1.
    Oct 20 2007
    S4, M3, NSX, RR
    Conesus Lake NY
    Thanks guys...that worked exactly. I did a search right after posting and found the solution. I should have searched before asking, but I was too impatient. Props to Audizine guys
    May 19 2009
    Alabama
    the keys need to be re-programmed. Here is how you do it...
    thanks dude i didnt know this either
    Gcc's blacksheep
    No problem guys! Glad it worked out for you.
    Oct 08 2008
    B7 S4
    Excellent!
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    Does this method work for new keys also? Why do some dealers want $$$ to reprogram a key if it only takes few seconds?
    Veteran Member Three Rings Veereihen6's Avatar
    Mar 06 2009
    Long Island, NY
    With a new key I think the RFID immobilizer chip in the new key needs to be programmed for your car.
    the above procedure is reprogramming an existing fob if the remote part stops working.
    2004 B6 S4 Avant 6MT Moro Blue - mostly stock for now
    1998 VW GTi-VR6 - mmmmm....listen to that VR6 growl! -sold-
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    When I bought my car CPO, they sent me a brand new key fob.
    Before I tried the new fob, I had the VAG window option done and had a RNSE put in. When I tried the new fob, it doesn't work -- do I have to have my original radio in there first?
    FS: Audi TT 225Q Roadster
    Senior Member Three Rings Tek4ever's Avatar
    Mar 02 2008
    Silver 2004 S4
    Chicago
    I've tried everything but this...going to try it tonight. The "unlock" button on the door or remote?
    B6 S4 | MT6 | F.I. Full Exhaust | ECS Snub | JHM LW Rotors | JHM Chip | JHM SS | JHM LW Pulley | JHM Stage III Clutch | LW OZ Ultraleggeras | K&N Filter | Uber Cabracco85 MAF MOD
    Mar 06 2009
    Long Island, NY
    The unlock button on the remote.
    Established Member Two Rings mike's_red_S4's Avatar
    Aug 01 2009
    2006 audi S4,1996 audi URS6
    Quebec,Canada
    same thing if you change the batterie of the remote you have to reprogram it
    Mar 02 2008
    Silver 2004 S4
    Chicago
    How soon after holding the 'unlock' button - should this work?
    Oct 20 2007
    S4, M3, NSX, RR
    Conesus Lake NY
    Quote Originally Posted by Tek4ever View Post
    I did this yesterday. Put key in ignition, turn on electricals and then hold unlock door on remote for 5 sec, and then I tapped it a few times for good measure. Turn key/car to off. Take out key and you should be good. I did this with both sets of keys and worked fine.
    Established Member Two Rings Babyfoood!'s Avatar
    Sep 21 2008
    Southern California
    Exactly! I went through this last week.
    Veteran Member Three Rings clumpymold's Avatar
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Ditto. Pays to read the manual. ;)
    Mar 02 2008
    Silver 2004 S4
    Chicago
    Tried it on both of the keys I have and it didn't work :( Held it for 5-10 seconds, and even tapped it a few times as well. I'm open for any other suggestions. I'm sure the batteries are still good on both keys because the problem started when I disconnected the battery.
    TIA
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    TIA
    Yeah, it took me a while to get it figured out as well. I think it worked when the door was open or closed when I started it. Forgot now though. And then I tried holding the key unlock and then letting go before AND after taking the key out of the ignition. Eventually, one of those combinations worked.
    Oct 01 2009
    Milwaukee
    First post here. Anyways, have exhausted all options using the search function and I'm out of ideas. I just picked up a CPO '06 2.0T Tip sedan. Only one of the remotes works to lock and unlock. Both keys work just fine. I replaced the battery on the second, non-working remote and am getting blinky blinks (on the key, not the car) now so I know it has juice. It just doesn't seem like it's transmitting. Things I've tried.
    Reset procedure from the owners manual:
    Press unlock on fob
    Insert key and turn to Acc
    Turn ignition off and remove key
    Press lock or unlock on fob
    no dice
    Reset procedures from this site:
    Hold Unlock on remote for 5 seconds (does it have to be exactly 5 or just a min of 5?)
    Turn off key and test.
    no dice
    Insert key in door
    Lock door with key
    Press lock button
    Unlock door
    Press unlock button
    no dice
    Turn key to Acc
    Lock and unlock door with door switch
    no dice
    I guess the easy answer is take it to the dealer. It's still under warranty until next June before the CPO kicks in. It's just a PITA in a new-to-us vehicle.
    Any ideas besides "take it in?"
    Thanks,
    Matt
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    I was having trouble doing this as well when my battery died. I THINK I did this and it worked:
    Insert key and turn to Acc WHILE holding the unlock on remote for 5+ seconds
    Try that? Let me know. I believe you're getting there. It's one of those options.
    Quote Originally Posted by UWSkier View Post
    Press unlock on fob
    no dice
    no dice
    Insert key in door
    Lock door with key
    Press lock button
    Unlock door
    Press unlock button
    no dice
    Turn key to Acc
    no dice
    Thanks,
    Matt
    Senior Member Two Rings S4rings-B6's Avatar
    Apr 14 2007
    '00 MB ML
    LA Area
    You know I had changed the car battery and then thought I had to reset the key fob but you really don't have to because for me the spare key still work without reprograming it. However my daily use key didn't work and I tried reprograming it and it wouldn't reprogram. I thought it might be the key battery and I replaced that and it still wouldn't work. While I was reprograming the key I can hear a clicking noise when I try the buttons, but the key still does not respond.
    So I brought it in to the dealership and they told me that the key remote is bad and needs to be replaced?
    My spare key still works without any problem but for whatever reason right after I changed the battery and try to reset the daily use key it wouldn't reset. There's got to be some connection between changing the battery and shorting the key remote. Or is it just a freak coincidence?
    So your remotes might need to be replaced.
    Jan 03 2009
    camry
    I'm having the same issue. I can't lock/unlock/open trunk with the remote and if I try to use the valet key I gate a "SAFE" message on the dash. I tried replacing the battery and re-programing it by following the directions above but that didn't work either.
    But here's one thing I noticed......you guys say to put the key in and turn to ACC position. I don't know about your cars but my s4 doesn't have an ACC position. It has OFF, ON, START. So I'm assuming by ACC you guys mean to ON(which turn on all the lights on the dash).
    Any ideas on what else I should try?
    Dec 28 2009
    2005 Audi A4 1.8T Tippy, 2004 Chevy Trailblazer, 1996 Ford Ranger
    DFW, TX
    Worked for me (second try). Thanks AZ!
    Live dangerously enough to make a difference...
    Senior Member Two Rings Naudi04's Avatar
    Dec 02 2009
    2004 S4 6MT
    Oregon
    Quote Originally Posted by road race s4 View Post
    Same issue I'm having with my spare remote fob, unlocks the drivers door, but putting it in the ignition gets a "safe" message on dash. If I try to start the car with this key now, the car shuts off after a second. WTF... Tried all these possible solutions and none are working. All I did is replace the battery, and this happened.
    Leave it to Audi to make a key that cost hundreds of dollars each and when a battery dies, the key doesn't work anymore.. LOL
    2004 Audi S4 6MT 40k miles, Light Silver (Metallic) w/Black-Silver Alcantara
    For Sale <- click link
    Jan 03 2009
    camry
    None of the methods to reprogram the keys worked for me. So I found a guy that does this for the dealerships in the area nd paid him $100 to do it.
    So for $100 he programed my remote, got the valet key to start the car, cut/programmed a blank key I purchased on ebay AND he cut/programed another key that he gave me. He also cancelled the keys that were supposedly lost or whatever. Whole process took less than half hour and he come to me.
    Registered Member One Ring b7newB's Avatar
    Jun 01 2009
    05.5 b7 2.0t quattro
    b a rock, MA
    I had this problem when I bought my 05.5 2.0t last may, Try this.... with the door already locked you put the key in the doorlock turn it left to unlock remove key and get in the car. insert key into ignition, turn to "ON" hold the unlock button for 5 seconds then take the key out of the ignition, get out of the car close the door put the key in the door lock turn it right to lock the door. hold it there for a few seconds and you should be good. Hope this works 4 u.
    Veteran Member Three Rings Brian0473's Avatar
    May 09 2009
    San Antonio, TX
    I know this is an old thread but I just replaced the battery in a key and was having this same issue. Here is the combo that worked for me:
    Car is already unlocked...
    open door
    get in
    insert key (that has new battery)
    turn key to accessory position (don't start the car)
    now push in unlock button on the key remote
    hold button in 10 seconds
    let button out
    press button in and out 10 times
    turn key off and remove it
    get out
    enjoy your working remote
    I actually replaced both key batteries at the same time and this same procedure worked for both.
    ______________
    Current: '18 Raptor; ‘06 F430; ‘80 Bandit T/A; Porsche Cayenne; ‘95 Ducati SS Custom
    Past: RS4#1 = '07 Misano Red (SOLD); RS4#2 = '07 Phantom Black (SOLD); '08 C63 (SOLD); '09 997.2 Carrera S (RIP); '09 SL63 (SOLD); '92 Spec Miata (SOLD); '10 M3 DCT Coupe (SOLD);
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Quote Originally Posted by Brian0473 View Post
    open door
    get in
    let button out
    get out
    Nice. Just followed this with my spare key and it worked perfectly! :)
    Jul 28 2009
    Jupiter Florida
    I didn't change my battery but the battery died due to leaving my lights on and I jumpstarted it, ever since my remote would not work, I tried every single method on this thread and it wouldnt work.
    I tried one method that worked at first (but then after testing the remote function more than twice it stopped working). Can anyone else give me a suggestion, this is becoming very frustrating!
    How do I reprogram the remote control?
    1. Take the valet key, put it into the ignition and turn the key to the "on" position, just prior to starting the car.
    2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
    3. Exit the car and close the door.
    4. With a second key, physically lock the doors (don't use a remote).
    5. Take the first remote to be programmed, press one of the buttons and the lights will flash once. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I pulled my battery out to show a customer how to do it.. remote didn't work. Then I drove home with it and it reprogrammed itself.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Jul 28 2009
    Jupiter Florida
    So you pulled out your battery, then put it back in, and manually unlocked your car, and just drove it, when you got back the remote started working?
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Quote Originally Posted by audifan22 View Post
    Have you tried what I did (see post #31)?
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    And why would leaving your lights on kill your battery? Don't our lights turn off automatically after a while?
    Jul 28 2009
    Jupiter Florida
    Quote Originally Posted by clumpymold View Post
    Yup tried post 31 and it didnt work, the method I posted last might have actually worked this time im not sure if it'll last...I also thoughts the lights turn off automatically after a while but apparently not. I took it to valet and when he brought my car back to me he switched the headlights from the "auto" setting to the setting where you force them to turn on, and I didnt realize that. When I parked my car at home the next morning the car was completely dead, so I figure it had to be because of the headlights staying on all night...but maybe I'm wrong and it was a freak coincidence?
    Jul 28 2009
    Jupiter Florida
    Weird just went to test the remote again after it seemed to be working directly after I tried the valet key method, and now it doesnt work again...it's a mystery i guess ill have to go to the dealer and suck it up
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Wow, that sucks. Glad to know that. I always thought the headlights would turn off after a certain time. I never have mine on Auto anymore anyway. My damn Ziza city lights throw a code if they're turned on automatically. Hope you figure our your remote issue though.
    Jul 28 2009
    Jupiter Florida
    I've tried absolutely everything and the only method that worked for a few minutes was the last method, but then the remote wouldnt respond again. My audi dealership wants $160! Should I give it one last attempt by buying a new key remote battery and trying to resync it with the fresh battery? Do you think a brand new key remote battery would make any difference?
