What you need:
1x 3'x2"x 3/16" "Welding Steel" plate from Lowes (I found it near the mail boxes)
1x 1" hole saw or equivilant to drill a 1" hole in 3/16" steel
2x 6x30mm bolts w/ nuts and lock washers
2x 8x30mm bolts w/ nuts and lock washers
Appropriate drill bit's for both bolt sizes (I cannot read the drill bits anymore sorry and mine were a tiny bit snug which works out pretty well so you know they will not wiggle around in the holes better yet thread the holes)
May be necessary to enlarge image
Steps:
1. Draw out your grid as shown above
2. On the 2 outside lines drill your smaller hole for the 6mm bolt
3. On the 2nd line in drill your 1" hole
4. On the furthest inward lines drill your medium hole for the 8mm bolt
5. Place you 6mm bolt in it's appropriate hole then put a lock washer on and the nut and tighten but do not over tighten I made this mistake and had to get another bolt (impacts are bad!)
6. Place your 8mm bolt in it's appropriate hole then put a lock washer on and the nut and tighten.
Final product
