Results 1 to 40 of 45
    Jul 31 2009
    Adaptive Cruise Control Retrofit?
    Well, as everyone who bought a B8 A4 in Canada probably knows, we don't have Adaptive Cruise Control as an option at all here on the '09 A4 (why?!). This got me thinking if anyone has been doing a retrofit for ACC in their B8 A4?
    I've seen a number of people retrofitting (generally older) A6s and A8s and I imagine for the A4 it would be a similar type of job: New gauge cluster, control module, wiring, harness, cruise control stalk, camera and a different cover over at the front-right fog-light (where I believe the ACC camera sits).
    This is one feature I would kind of like to have, even though my right leg is fully capable of handling the job itself, haha.
    Mar 02 2007
    Fresno, CA
    Re: Adaptive Cruise Control Retrofit?
    Quote Originally Posted by Pahnda View Post
    I haven't seen that retrofit done by any forum members yet, but as you said it should be possible (with enough time and money). It's one of those options I found completely worthless when placing my order and probably wouldn't use if my car came equipped with it. Is that what appears to be an extra fog light on some cars?
    Jul 31 2009
    If it's by the passenger-side (for us LHD fellows) fog light, I believe it is. Which would make it an easy fit! Just need to get the proper plastic cover to replace the stock one.
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    This is what it looks like:
    Op: Hate to burst your bubble, but there is nothing easy about it. You have to essentially rewire the entire car, not to mention cutting into the exterior/interior, recalibrating the ECU, etc. This is just a rough diagram.
    Not saying it cant be done, but probably not worth it.
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    start a poll asking Adaptive Cruise Control owners if they like/use it.
    I reckon you'll find the poll comes back 80% don't like/use it.
    Jul 13 2009
    Ottawa, Ontario
    Quote Originally Posted by sakimano View Post
    There are that many people that use it? I find 20% to be pretty high.. if I'm on the cruise control and catch up to the car in front of me, I don't want to slow down, I want to pass it!
    Jul 31 2009
    >>12sA4
    But that's what us engineering types are known for... Taking something we REALLY don't need (or necessarily really really want) and spending an inordinate amount of time making it work! haha... But in all honesty, I agree that I would probably not use it too often if I had it; it could imagine it would be a pain in a standard tranny A4 regardless, haha.
    Account Terminated Two Rings
    Aug 25 2018
    Portugal
    Hi Guys,
    Does anyone completed the ACC retrofit for the A4 FL 2015?
    If so, do i need to replace my instrument cluster with one who supports acc? My cluster ref code is 8K0920932D, do i need to change it?
    I cannot find any information on the instrument cluster part number compatibility with ACC function.
    Aug 19 2016
    Newport Beach/CA/USA
    yes i completed it.
    it’s somewhat complex for A4 only from a parts collection point of view.
    the correct cluster for A4 is 8k0920982F you can’t find these used. it’s damn near impossible. have to buy new from europe costs 1,100
    the windshield if your doing the lane assist with it can’t be ordered in the usa under any circumstance. i tried for a month. had to order from europe. had a friend help. i don’t know about canada. windshield plus shipping is $1,500. i’ll leave lane assist out of it since it’s another thing.
    the radar sensor is about $300.
    the mount for the radar is $185 also can’t find used anywhere.
    i have an extra one for sale if you go down this road for $145. the wiring is actually insanely simple. i also have the wiring harness. one power, one ground, can bus hi/lo
    coding is simple and straight forward. the stalk is hard to find. it took 6 weeks to find one used. the stalk new is around 600 used 200 if you can find one. the correct clock spring i have again if you want to go down this road.
    i have all the part numbers all the instructions and can answer any questions if you choose to do this.
    mine works perfectly and i use it constantly. it’s my favorite feature on the car.
    Aug 19 2016
    Quote Originally Posted by brownishwater View Post
    your completely incorrect on all accounts here brother. sorry to burst your bubble. i did it. wiring is the simplest thing in the world. four wires. power, ground and can bus hi/low. programming is super simple.
    part research and collection was the hardest part. price is the only thing difficult because finding these parts used is extremely difficult. once you have the parts the retrofit is one of the easiest to do. nothing needs to be done in the ecu at all.
    Aug 19 2016
    here’s a picture of it working.
    Attachment 94198
    Aug 25 2018
    Portugal
    Quote Originally Posted by prkieffer View Post
    yes i completed it.
    Hi prkieffer,
    Thanks for the info, i already have the radar, the mounting bracket, and the stalk is already ordered, only thing missing is the harness (thinking on kufatec), but the instrument cluster is the only thing that is missing, i will try to find here in europe the part 8k0920982F that you mentioned, however i thing that part is already on revision T (8K0920982T) but i am unsure it will fit my 2015 A4 facelift 2.0 Diesel, i saw on a german blog that the petrol and diesel car variants, have different instrument clusters (tachometer/speedometer markings), maybe you or someone here can shed a light on this.
    If i keep my old instrument cluster, will ACC work? I known that there are some missing LEDS/resistors on the pannel display, but other than that, will the color display with the radar lines/distance work since my instrument cluster is a colored one?
    Thanks for the help
    jcarreira
    Aug 19 2016
    i can sell you the harness. i have it. save you a few bucks. send $40 to [email protected] i’ll ship today.
    Aug 19 2016
    i don’t know if it will work. you would have to test that one.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    No need to offer US cluster part number to EU guy:)
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Aug 19 2016
    US doesn’t have this cluster for some reason. bought it from u.k. A4/S4 in US might have an ACC but i could never figure out the part number for it if they do.
    Aug 25 2018
    Portugal
    Quote Originally Posted by Gunnark100 View Post
    True, but after some digging on the internet for part numbers i got the correct one for ACC for my car variant: 8K0920932G
    The original i have is 8K0920932D, so just a change in the last letter to go from standart cluster to ACC cluster.
    For future reference:
    Non ACC cluster: http://www.oemepc.com/audi/part_sing.../251891/lang/e
    ACC cluster: http://www.oemepc.com/audi/part_sing.../265160/lang/e
    500€ for the damn cluster is a bit priced, i just finished a MMI3G to MMI3G+ retrofit, ADS retrofit, screen mirroring for android/IOS, if i spent more money/time in the car my wife will put me in the doghouse for a month...
    When i assemble all the parts i will let you know if it works with the non acc cluster (fingers crossed).
    To mount the radar securing bracket is it an easy task to do, or do i have to take out the bumper on a jack lift to access the mounting point?
    Thanks guys.
    Aug 19 2016
    i couldn’t use km i had to use the mph so mine was different
    Aug 19 2016
    you need pressure fittings and a special tool to install them. my bumper was already off when mine was installed.
    do you want the wiring harness?
    Aug 19 2016
    Attachment 94338Attachment 94339
    here’s the wiring if you want to buy it.
    Aug 25 2018
    Portugal
    Hi Guys,
    Im just about finishing the ACC retrofit , only thing left is to remove component protection from the radar and do the calibration. However i´m having errors with the code for the radar module 13. Can someone provide the code for an European 2015 Audi A4 S-line FL 2.0 Tdi, Manual transmission, FWD, no trailer hitch?
    Thanks
    Jcarreira
    Active Member Two Rings ijosito's Avatar
    Jul 31 2017
    PSL Florida
    Know nothing Know it all
    Lol. You can hate all you want but only bubble you’re busting is your cognitive bubble. You’re a know nothing troll.
    Jul 31 2017
    PSL Florida
    Quote Originally Posted by Jcarreira View Post
    Thanks guys.
    How did you do the screen mirroring?
    Aug 25 2018
    Portugal
    With a 56$ car wifi display i got from ali express:
    Carlinke Car WiFi Display iOS AirPlay Mirror Link for Car Home Video Audio Miracast DLNA Airplay Screen Mirroring 5.8G
    https://www.aliexpress.com/snapshot/...Id=32796660693
    Works just fine and for 56 bucks its a bargain
    Aug 19 2016
    Quote Originally Posted by ijosito View Post
    i completed the retrofit with a picture of it working. explain yourself - your comment made no sense.
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    There is coding reference in this archive.
    http://www.audizine.com/forum/archiv...t-426875.html?
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
    Aug 25 2018
    Portugal
    Well after applying a formula I saw in another forum, the coding for my vehicle is:
    00A0D0
    A4 FL 150hp 2.0tdi, manual gear, no trailer hitch
    Jul 31 2017
    PSL Florida
    My comment was meant to the individual busting bubbles.
    2014 A4 Quattro Premium Plus
    Ice Silver Metallic
    Established Member Two Rings lowlife89's Avatar
    Jun 01 2013
    EU
    Is anyone interested in a set of stalk controls (used), S-line ACC
    foglight grille (brand new) and sensor mounting kit (brand new)?
    8K0953568G
    Aug 25 2018
    Portugal
    00A0D0
    Well, went to an audi dealer to remove CP and found out that the radar unit is from a stolen car, i got another radar unit this time a 8K0 907 561B instead of a 8K0 907 561 , problem is now i got the: "controle module incorrectly coded". I tried my previous unit code but this error keeps popping up, tried also other codes which are accepted but this error keeps coming back what do you guys think? If i remove CP will this error go way?
    thanks
    jcarreira
    Aug 19 2016
    you have to remove cp first.
    Aug 25 2018
    Portugal
    Well i removed the CP but the error "controle module incorrectly coded" remained, however when i looked at the original code that came on the radar unit was different, i noticed that the coding changed from radar "8k0907561" to the B version of the radar 8k0907561b (newer)
    To summarize:
    8k0907561: coding A0A0D0
    8k0907561B: coding 00A8A0
    The difference is:
    00A8A0 = 43168
    00A0D0 = 41168
    Seems to me that Audi changed the 4th position bit for this new radar revision 8k0907561B: 4(1)168 to: 4(3)168
    After i changed the bit and converted the number to Hexadecimal i finally got the code accepted)))
    Aug 19 2016
    strange. nice job!
    Aug 25 2018
    Portugal
    strange. nice job!
    Strange indeed...I think sometimes Audi likes to throw a curved ball at us, just to dry out our patience...
    Aug 19 2016
    i’m having an intermittent issue where the radar sensor loses connection every 6-8 weeks. only way i can get it back is to pull the grill off disconnect the plug and reconnect then clear codes and it comes back.
    only thing i can figure is the sensor is failing slowly. bummer because i can’t pin it specifically. i hate chasing problems.
    Aug 25 2018
    Portugal
    Well, dont talk to me about radar issues, this is the 3rd unit i bought, the first 2 couldn´t remove CP ( they came from stolen cars), a hell of a mess to get refunds and ship the parts back...
    Ufffff...
    Aug 25 2018
    Portugal
    Hi guys,
    Did anyone here manage to solder the missing leds and resistors on the tacho (not the ones around the speedometer)?
    Aug 19 2016
    interesting.. i’ve never seen them got a picture?
    Aug 25 2018
    Portugal
    You can check it out in this forum´s page:
    ***.audi4ever.com/blog/eintrag/25824-blog/
    Aug 25 2018
    Portugal
    Well guys,
    After checking the work involved in soldering the missing leds to get the ACC leds in the tacho i took the plunge and bought a new tacho for 300€ with 30km on it.
    For the adaptation of the tacho you need a proper soldering station as the leds and resistors are very small and you easily might end up damaging the board...
    Just finished to install the new tacho, removed CP, copied coding and adaptations (KM, service intervals) everything is working fine, ACC full retrofit done))
    Next retrofits on the pipe: lane assist and side assist
