Results 1 to 40 of 43
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    Cupra Lip Install DIY
    This is a very simple install, but I find myself answering questions on the install often, so I figured a DIY would be helpful and hopefully cut back on some of the repetitive questions about it.
    ** 1) Shave down the center posts of the lip. They are too tall for the car so they need to be cut down. I shaved mine down to about half their original size. Just place the lip under your car to see how it lines up and you can play around with how tall you want them to be depending on the look you like, but it will be necessary to cut off some of the length. It's just all preference as to how much to shave.
    You will also need to shave down all of those drill tabs along the lip so the lip can sit flush and smooth against the bottom of the bumper.
    I used a dremel for all of this and it was pretty simple.
    I also pre drilled some holes in the lip until just when the screws were about to peak through the other end. This just makes drilling MUCH easier when your under the car and gives you some guides when drilling.
    Now the lip is ready to be installed.
    ** 2) Jack the car up in the front. This isn’t necessary, but will make drilling into the bottom of your bumper much easier. - I just jacked up one side of the front and I was able to get under my bumper just fine.
    ** 3) Use duct tape to position the lip onto your bumper. Use plenty and get a good snug fit. Step back and take a look at it and keep correcting its position using the duct tape until it sits basically how you will want it once it's drilled.
    ** 4) You will need 3/4" self drilling screws (preferably stainless steel to avoid any future rust issues). I used about 16 total (8 on each side). Some may use more or less, it all just depends. I didn’t drill into every drill tab on the lip. I skipped a few and just drilled in the ones I felt were necessary.
    ** 5) So now your lip is taped to the bumper, and your car is jacked up so you can drill underneath it. So stick your head under the bumper and start drilling the lip into place. You should have small pre drilled holes in the lip as a guide, but pre drilling into the bumper is NOT necessary since you have self drilling screws.
    I started with the tabs closest to the middle of the lip and worked my way out a bit. Then I went to the ends of the lip and made sure to position those nicely. Then I went back and drilled in a few more holes in the middle of the lip to ensure everything was tight and drilled down nicely.
    The lip is not a perfect shape for the bumper. So dont be afraid to bend it some (especially at the ends) and shape the lip as you are drilling so it can follow the lines of the bumper nicely.
    I think thats everything. I will update with some pictures later. Feel free to ask any questions, or to let me know if I missed anything that I should add. Hope this helps someone.
    ASE All Same Everything | Est. 2011 MA to FL
    Senior Member Two Rings prospero's Avatar
    Apr 13 2009
    Denver
    Re: Cupra Lip Install DIY
    I wouldn't recommend duct tape, there's a high-risk of leaving residue behind, please use blue painter's tape.
    See this thread:
    http://www.audizine.com/forum/showthread.php?t=284949
    And this post:
    http://www.audizine.com/forum/showpost.php?p=3745262
    The above thread has everything you need instructions + pictures + part #'s + where to find.
    current // 06 a4 2.0t quattro 6sp | brilliant black | dtm rear lip | euro cupra front lip | K&N | greddy tt | hoen xenonmatch fogs | vag'd' | 30% tint
    soon // unitronic stage 1 | rs4 rear sway | oem rev 'D' dv | awe vent boost gauge
    Jun 09 2008
    b8
    Quote Originally Posted by prospero View Post
    See this thread:
    And this post:
    http://www.audizine.com/forum/showpo...2&postcount=25
    hmm, i didnt have any problems with any residue. nothing a good wash couldnt take care of. i just cant imagine blue painters tape being able to hold that lip in place . thats why i used duct tape because you have to be able to bend the lip a bit to get a good fit on the bumper, so i needed duct tape to hold those bends in place while i test fit it before drilling.
    Senior Member Three Rings Gingerkid's Avatar
    Apr 22 2009
    2007 2.0T A4 quattro 6MT
    Atlanta, GA
    Automotive (paint safe) goo gone would correct the residue problem. I had to use it on some wheels last night to remove adhesive from balancing tape weights.
    Apr 13 2009
    Denver
    It's up to you, I'm just saying I wouldn't recommend it. Blue tape worked fine for me. With duct tape residue varies based on which brand you buy, there's a million different brands and some I have issues with, some I don't. Just trying to give people a heads up.
    You also forgot part #:
    1ML805903 (Seat)
    And where to find:
    I got mine from goingfast.com for $79+shipping
    Veteran Member Three Rings SDA4's Avatar
    Jan 04 2009
    I didn't need to jack my front end up to install it, and I didn't use any tape at all. Just get a friend to hold it in place for a second as you screw down the two ends to get it centered. I did it all by hand with a screwdriver as well, so it should be easy if you have the right screws. I scrape it and drag it on driveways all the time and its holding strong.
    Brilliant Black A4 // Rieger // 19" VMR V715 // Falken FK452 // H&R // Custom Magnaflow // Blackout Headlights // Debadged // FLY's LED's // Penny Mod // Cupra Splitter
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    I used ramps and 4 pieces of electrical tape (by myself) - shit was WAY easy to install - took about 15 minutes total. GREAT MOD - I'm lovin it.
    2015 S3 - Panther Black P+ / LED Lights / B&O / APR Stage 1 ECU & TCU / APR Turbo Muffler delete / CTS Turbo Inlet/Discharge/Intercooler Pipes / X34 Intake / Superpro end links / VWR springs / 35% Tint / ED CF rear diffuser / 034 CF engine & fuse box covers / ECS CF battery cover / BBS SR's
    Senior Member Three Rings dtrizzo's Avatar
    Dec 24 2009
    2025 Daytona SQ7 //, 2024 Toyota Tundra
    Wichita, KS, USA
    Quote Originally Posted by SDA4 View Post
    . I'm diggin these headlights bro! Think they'll fit on an RS4? (btw, what're they called and/or where'd you find them?). Thx.
    Veteran Member Three Rings Mezzer's Avatar
    May 23 2008
    19 SQ5 & 08 RS4
    Gas station
    ^^ They're custom made by fly300kts. Search his screen name and you'll find them. They'll fit the RS4.
    OP... Car looks great, good job on the Cupra lip.
    Old enough to know better... Young enough to do it again, just getting harder to recover.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    how do you prevent the center post from sagging?.....
    Veteran Member Three Rings brucebanner's Avatar
    Sep 09 2009
    Bellingham, WA
    what are the best screws to use, someone said stainless steel someone said automotive black ones, but with those dont you have to drill the holes? for just stainless steel self drilling screws, what size did you guys use? i know you say 3/4, but i was at lowes today and they got 12-3/4 and 10-3/4, im not sure what that means. i know i can manage the install as long as i know what to get
    Sep 09 2009
    Bellingham, WA
    Quote Originally Posted by brucebanner View Post
    anyone?
    Apr 13 2009
    Denver
    used 3/4" self-drilling screws and #10 washers, used 1" or 1-1/4" self-drilling screws for the pillars
    #12 3/4" vs. #10 3/4"
    #10-#12 is the width of the screw
    3/4" is the height
    either should be ok, although I'd recommend the #10. if you get #10 screws get #10 washers, if you get #12 screws get #12 washers. i got the pan head philips type screw:
    Sep 09 2009
    Bellingham, WA
    3/4" is the height
    thank you very much
    Jan 05 2010
    brooklyn, ny
    Becarefull when screwing! Punctured my aux radiator
    thank you very much
    Well i was down to the last few screws ( goth the "3/4 self tappers from this thread). I drilled into the aux radiator on the passenger side and fluid started coming out. This is on my b6 s4. Make sure you check before you drill. I'm sure alot of people who screwed this in probably have screws touching it and eventually with vibrations or bumps it will puncture it. The aux radiator bottom is prett much touching the underside of the car. And it's made of thin plastic.
    You can pull back the wheel well on pass side and look in to see it.
    Senior Member Three Rings A4_Ti's Avatar
    Mar 15 2011
    Ouch that sucks, thanks for the heads up though, I wouldn't have even thought of drilling into something like that
    2007 Audi A4 | 3.2 | S-Line | Titanium | 6MT
    Veteran Member Three Rings ignus99's Avatar
    Nov 08 2009
    Calgary/Alberta/Canada
    ... way to revive a dead thread.
    Mar 15 2011
    Wow really? the guy had a good tip, and who cares if it's an old thread, it's not like the install is any different these days
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    Quote Originally Posted by ignus99 View Post
    Wow... revive an old thread, get crap for it. Post a new thread that already exists if you had used the search button to find the old thread, get crap for it. Sounds like a lose lose situation. You should keep your useless comments and posts to yourself.
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Veteran Member Four Rings NickyAsixx3sixx's Avatar
    Oct 16 2011
    Levittown, NY
    Quote Originally Posted by Jay B7 View Post
    hahaha i always think that!! people on here forums piss me off sometimes with that shit
    2001 A6 2.7T - EPL TUNED, Bright Blue Metallic Vinyl Wrapped, ST coilovers, Miro 111s 19x9.5s all around on 225 tires, 3" SRM downpipes, AEM Meth kit, Magnaflow mufflers, JHM LWFW, JHM Stage3 clutch, B7 RS4 PP, SRM bipipes, JHM Solid linkage
    Sep 30 2009
    Calgary
    Now that this thread is alive, I may as well throw a question out there :)
    I just did the install this weekend, everything went great. Just wondering for the Az'ers out there that have this mod, does the middle of the lip dip down a bit? the middle is not held by anything and no the tabs are not pushing it out. I did a pretty decent job sanding and cutting down the tabs. Did anyone use double sided tape to hold it in place?
    Veteran Member Four Rings Audi_509's Avatar
    May 20 2010
    2008 A4-sold. 2019 A5-sold,: '23 S5
    WA
    I used screws and a washer for those two tabs.
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by yimsum View Post
    Even 3M Tape won't work. I used black zip ties through holes I drilled through the sides of the tabs and into two small holes I drilled for each tab into the bumper cover. Sounds crazy, but worked beautifully and the lip now sits flush in the center. Sagged way down before. :D:thumbup:
    From a two feet away, you can't tell they are there.
    Jul 19 2011
    Northern Minneapolis, MN
    I used double sided tape for fitment before drilling, once perfect I drilled holes and used screws and washers, then I realized that screws and washers suck, and I replaced them with 1/4" bolts and washers. Now it is Super solid and I can go through snow piles with no thoughts.
    Nov 08 2009
    Quote Originally Posted by NickyAsixx3sixx View Post
    ... did you just necro bump, a necro'd bump?
    - Karl
    Engine: GT28RS by ATP / Turbosmart 38mm dual BOV/Recirc / Carbonio CAI / APR TBE / APR Testpipe / REVO St2+ / Snow Performance ST2 / APR HPFP
    Body/Suspension: KW V2 / DPE ST-10 19x8.5 et35 / Thor Skid Plate
    Pretty Stuff: AWE Vent Boost Gauge / OEM Bixenon + V4 LED / Supertones / Votex SS / CF Hood & Mirrors / RS4 Grille & Fogs
    Sep 30 2009
    Calgary
    What did you do about the middle of the lip there since there are no screws there
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    nothing... its held by about 12 screws on each side.
    Aug 22 2010
    Piscataway, NJ
    Seat Cupra R Lip Spoiler
    Front lip from the European Seat Cupra R. Installs perfectly on many US Audi and VW models. Imported directly from Europe.
    This spoiler will ship in a sturdy bend-proof box so order with confidence.
    Jul 19 2011
    I shaved them down first to get my lip almost completely flat, then I used bolts and washers. Cutting them makes a tapered gap, but it is tight so I drilled through it for the bolt.
    Sep 29 2010
    Mission Viejo, CA
    I was just on the oemplus site and noticed they had these now listed for $72. Mine is getting pretty damaged from the last 2 years of being scraped so I might pick up a replacement.
    Jul 19 2011
    Quote Originally Posted by BandW View Post
    mine is my scrape guard! I have had it for almost a year now, but definitely after 2 I will need another.
    Sep 30 2009
    Calgary
    Joe, thats pretty creative, I would have never thought of that. Mines not too bad. I will post a picutre later tonight
    Established Member Two Rings ginsta's Avatar
    Jun 02 2012
    Toronto Ontario
    is there any way to do a group buy for Cupra lips shipped to Ontario?
    Apr 17 2008
    Central, NY
    Wow $50 for shipping from Jersey to NY??? Anyone know a place that ships for cheaper. I know the box may be on the long side , but it can only weigh like 2 pounds.
    Senior Member Three Rings DrZEUS's Avatar
    Aug 18 2011
    B8.5 S4
    Mississauga
    Quote Originally Posted by ginsta View Post
    I'm in for this if it happens!
    Jun 02 2012
    Toronto Ontario
    Quote Originally Posted by DrZEUS View Post
    thats 2 for sure
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by i_audi View Post
    The box is 30x54x9 which goes under "oversized" ... The box itself weighs more then 2 lbs. Since you're in NY you can always pick it up..
    Active Member Two Rings audipwr87's Avatar
    Nov 11 2012
    2002 Audi A6 4.2, 1989 Ford Bronco
    Renton, wa
    I know I'm bringing back a semi-dead thread but if people are still having issues finding them in stock, there's are a few sellers on eBay with em. I picked mine up for $110 with free shipping.
    2002 Ming Blue Audi A6 4.2 with Magnaflow exhaust and KN drop in airfilter, 18x9.5 Black TSW Stowes, 5 mm H&R spacers rear, 5 mm in the front, H&R Street Performance coil overs, 20% tint all around.
    Established Member Two Rings toastedzen's Avatar
    Mar 16 2013
    San Diego County, California
    Thread is never dead as long as these cars exist and people purchase and mod them. I am about to install one of these lips myself. Thanks to the OP and (most) of the commentators to follow. Good info.
    - Timothy
    2008 Audi A3 3.2 S-Line quattro Ice Silver Metallic
    2014 Audi Allroad quattro Brilliant Black
    | RIP: 1971 Porsche 914 Red | RIP: 1991 BMW 318is Red | RIP: 2005 VW Jetta TDI Grey |
    Southern California A3's on Facebook
    Established Member Two Rings 05b7x614's Avatar
    Jan 13 2014
    Quote Originally Posted by audipwr87 View Post
    Ecs is selling them for like $70 plus shipping
